Flysky AFHDS 2A, protocol as used i10, i6, iT4,
06 Aug 2016 12:43 #52496 by Maveriick
Replied by Maveriick on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Can we downgrade the RX in factory mode? (On TGY-I10)
On rx update (factory mode) requires a password?
Does anyone know which is the password?
Only numbers.
06 Aug 2016 15:20 - 06 Aug 2016 15:22 #52499 by anthony7288
Replied by anthony7288 on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
hi goesbish
i wan to ask for chip stm32 , i killed chip stm32 on RX ia6b because i power wrong polary , now only find a chip STM32F030R8T6 LQFP64 and STM32F051R8T6 LQFP64 at electric store . So it can replace orginal chip ? i will load firmware that you post , it can work ?
Last edit: 06 Aug 2016 15:22 by anthony7288.
06 Aug 2016 16:18 #52501 by goebish
Are you sure only the MCU is dead ?
Given the price of a new RX I'm not sure that's worth the effort to try to fix it ;)
06 Aug 2016 16:24 #52502 by anthony7288
goebish wrote: Are you sure only the MCU is dead ?
i ' m sure Mcu died , when i remove Mcu , circuit is not short . I buy Mcu cheap than buy new RX .So it Yes or No ?
06 Aug 2016 16:33 #52503 by goebish
You can try to replace and reflash it, but there's not only the MCU on the board, there's also the RF part (a7106 + pa/lna + switch) and other parts (vregs ...)
06 Aug 2016 16:41 #52504 by anthony7288
goebish wrote: You can try to replace and reflash it, but there's not only the MCU on the board, there's also the RF part (a7106 + pa/lna + switch) and other parts (vregs ...)
ok , i will try , Uhm maybe STM32F030R8T6 LQFP64
06 Aug 2016 20:53 #52506 by Fernandez
Replied by Fernandez on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Thanks for post #52457 , firmware for U7E, but before I flash it, does it include the switches mod for 7e?
www.deviationtx.com/forum/how-to/5824-ul...witch?start=40#50865
it getting bit of difficult to cope with 7e and too many mods versions.......
anyway do not want to take your time, otherwise just will wait to fly AFHDS 2a, until all is sorted.
06 Aug 2016 20:59 #52508 by goebish
If this mod isn't in the nightly then it isn't in my build.
07 Aug 2016 11:05 - 07 Aug 2016 11:05 #52530 by goebish
@Fernandez, here's an ultimate 7e test build for you:
www.dropbox.com/s/js3fbi6oatkogwc/deviat...0.0-1906eb4.zip?dl=0
It is the latest nightly + afhds2a + this pull request .
Last edit: 07 Aug 2016 11:05 by goebish.
07 Aug 2016 13:25 #52541 by goebish
I've updated the i10 to 1.0.8 and I think I found how to enable SBUS, but I've to find a solution for this problem first:
www.deviationtx.com/forum/7-development/...-storing-rx-id#52540
07 Aug 2016 14:30 #52542 by joloebig
@goebish, check the telemtie, on my system it was gone on 1.0.8.
reg
jo
07 Aug 2016 14:38 #52543 by goebish
@joloebig, it's still working fine here, I updated the TGY i10 from 1.0.7 to 1.08 and tried with an iA6B on 1.6 firmware and iA10 on 1.6 and 1.8 firmwares.
- Int. Voltage
- Signal strength
- RSSI
- Noise
- SNR
07 Aug 2016 17:15 #52547 by goebish
Here's a new test build, with SBUS output option.
Devo 6
Devo 7e
Devo 7e "ultimate" (includes silpstream switch mod ;))
... to be continued on the next post ...
07 Aug 2016 17:16 #52548 by goebish
Devo 8
Devo 10
Devo 12
source
I had to merge PPM & SBUS output options into the same item, so this is a 4 choices option:
  • PWM + IBUS (default)
  • PPM + IBUS
  • PWM + SBUS
  • PPM + SBUS
I only checked with an iA6B on the scope but it seems to work (UART signal is inverted when SBUS is selected)
07 Aug 2016 18:45 #52549 by joloebig
goebish wrote: @joloebig, it's still working fine here, I updated the TGY i10 from 1.0.7 to 1.08 and tried with an iA6B on 1.6 firmware and iA10 on 1.6 and 1.8 firmwares.
- Int. Voltage
- Signal strength
- RSSI
- Noise
- SNR
sound good to me, maybe it other 1.0.8 than my, i read somewhere that tgy was not consist in ther versions.
btw did you check the telemetrie in flight. i check with a i6 on 1.07 with the tgy tx an the devo 12.
on the i10 there was a stable indication up to 73-75% (~90db) error rate, on the devo 12 it was intermitted fron the start.
07 Aug 2016 18:49 - 07 Aug 2016 19:06 #52550 by goebish
I've never checked in flight, but perhaps this is a problem with the A7105 module (or its antenna) in your Devo12 ?
Also, I think we can't expect the same kind of performance as with an i6 or i10 because we're using "simpler" a7105 modules, with only 1 antenna and no rf switch.
Last edit: 07 Aug 2016 19:06 by goebish.
07 Aug 2016 18:52 #52551 by joloebig
maybe... servos working fine, no timeouts, failsaves nothing only the telemetrie is intermitend
07 Aug 2016 19:30 #52552 by joloebig
goebish wrote: IAlso, I think we can't expect the same kind of performance as with an i6 or i10 because we're using "simpler" a7105 modules, with only 1 antenna and no rf switch.
if it is because off our 7105 modul so i think it wasting time to work on the external telemetriie, maybe someone else can do a test flight and iss able to compae to i6 or i10.
if can do anything to helpö find out it is problejm or not let me know.
08 Aug 2016 09:02 - 08 Aug 2016 09:08 #52570 by goebish
anthony7288 wrote: ok , i will try , Uhm maybe STM32F030R8T6 LQFP64
That's a LQFP48, not 64.
joloebig wrote: sound good to me, maybe it other 1.0.8 than my, i read somewhere that tgy was not consist in their versions.
Downloaded from hobbyking.
Last edit: 08 Aug 2016 09:08 by goebish.
08 Aug 2016 11:02 #52574 by Ryou
:cheer:
@goebish
'S. BUS 'operation verification did. It is operating correctly.
Thank you for a wonderful achievement.
Telemetry is not confirmed, but i confirm the 250m range of at the surface in the module of 16dbm output. (Receiver: FS-IA6B and iA10).
By visual flight I think that radio waves reaching distance is no problem.
goebish thank you.
Time to create page: 2.709 seconds
