Flysky AFHDS 2A, protocol as used i10, i6, iT4,
17 Sep 2016 01:15 - 17 Sep 2016 01:15 #53938 by goebish
Press Enter while the protocol name is highlighted, then select PPM+IBUS or PPM+SBUS output.
Last edit: 17 Sep 2016 01:15 by goebish.
17 Sep 2016 01:16 #53939 by Appelmoesman
Replied by Appelmoesman on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Tnx for your quick reply. If it does not work I hope I can update the firmware with my STlink v2
17 Sep 2016 08:54 #53954 by Alexandro
Replied by Alexandro on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Hello goebish,
I testet the latest Testbuild from you and found the Bug again and i think the Source of it.
If i change the 2nd Big box to RSSi and Powercycle then it gets deleted
If i change it to Volt 1 and Powercycle it goes to RSSI and gets not deleted after a second Powercyle
It looks like there is an Error at the ?assignment? of the Contend of the Saved Box ( german, Zuordnung des Inhaltes falsch definiert )
It looks like the Bug is only showing up on the extra Contend for the A2 Telemetry, because Timers are ok after Powercycle.
-> no Problem with the Dust on the TX :) , i do not need it ! I have DeviationTX :woohoo: ;)
Greetings Alex
17 Sep 2016 11:42 #53956 by goebish
Yes, looks like it is a indexing bug when it saves the setup.
Problem is that I have no idea where to look at in deviation code as I've never touched that ...
If I find some motivation I'll try to reproduce the issue and find the commit that introduced this bug.
17 Sep 2016 15:11 #53964 by djdazzy
Thanks for all your hard work and effort goebish.
Finally flashed the new firmware on my 7e, works well with a TGY-IA6 and FS-IA6B in both PWM and PPM mode.
17 Sep 2016 17:56 #53973 by djdazzy
Few quick questions:
Is the range check function supposed to work please? Also does RSSI telemetry come from an IA6B?
17 Sep 2016 18:05 #53975 by goebish
I'm not sure for range check, I wouldn't rely on it as the PA is always enabled.
RSSI is working with the iA6B, but it needs to be updated to firmware 1.6:
www.rcgroups.com/forums/showthread.php?t=2677694
17 Sep 2016 19:23 #53976 by ketsa
Is it possible to get the Devo to beep or vibrate when RSSI reaches a certain threshold ?
17 Sep 2016 19:31 #53977 by goebish
18 Sep 2016 03:31 #53992 by tkuan
I flashed the FS-iA6B with firmware 1.6 and both PPM and PWM work on CC3D now. I aIso flashed my Devo 10 to the latest build. I can see both RSSI(-60d) and battery(4.97v) from the receiver. I can't make Telemetry config to stay after power cycle. Maybe that is a bug?
18 Sep 2016 05:50 #53995 by djdazzy
goebish wrote: I'm not sure for range check, I wouldn't rely on it as the PA is always enabled.
Thanks goebish, does that mean the power is set to full power all the time so the power output setting doesn't do anything?
18 Sep 2016 09:54 - 18 Sep 2016 09:57 #53999 by goebish
No, that means than minimum power is 5mW actually, that's too much for range test ...
Oops, I'm wrong, minimum power is ~200µW so that should be fine.
Last edit: 18 Sep 2016 09:57 by goebish.
18 Sep 2016 10:02 #54000 by goebish
tkuan wrote: I can't make Telemetry config to stay after power cycle. Maybe that is a bug?
Yes, there's a bug with that in the current nightly, that's not specific to the AFHDS 2A protocol. (or is it ?)
18 Sep 2016 10:37 #54002 by djdazzy
goebish wrote: Oops, I'm wrong, minimum power is ~200µW so that should be fine.
Excellent, thanks. I will manually set the power to 200µW to range check.
18 Sep 2016 10:41 - 18 Sep 2016 11:51 #54003 by goebish
For A7105-D03 module, 100µW setting in deviation is 200µW actually.
I've no idea how much ground range you should expect with that tho.
Last edit: 18 Sep 2016 11:51 by goebish.
18 Sep 2016 10:44 #54004 by djdazzy
Ok, I will set it to minimum. Thanks.
21 Sep 2016 06:36 #54086 by Alexandro
@goebish
The Bug with the RSSI only shows on the new A2 modulation.
If i use Frsky and switch the RSSI at Main Screen then all is ok and it gets saved
all tested with Your new Build for the Flysky A2 RX
greetings Alex
p.s. a litte walk around is to use Volt 1 and do a Power Cycle, then it jumps to RSSI and stay saved.
24 Sep 2016 07:07 #54199 by TheSFReader
Replied by TheSFReader on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Just a quick THANK you all for this. the update to 5.0.0 and binding with a new iA6B went really easy and I can control my new frame with great confidence (DSMX without the range mod was really flaky on my 7e)
10 Oct 2016 19:39 #54800 by ketsa
I just pre-ordered an FS-A8S from Banggood.
New, ultra-small and light (1,2g) 8ch AFHDS2A receiver. Pretty cheap.
It should bind, right ?
11 Oct 2016 12:38 #54818 by goebish
Yes it should work, please report :)
Time to create page: 1.227 seconds
