Flysky AFHDS 2A, protocol as used i10, i6, iT4,
07 May 2017 15:18 #62103 by Fernandez
Replied by Fernandez on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
I'll tested this version and flight performance, betaflight + ibus inc new telemetry X6B it seems reliable.
Had a quick look at the LQI, it is 100% at few meter and a few hundred meters it is down to 60%, not sure where the thresholds for range warning to be set, but seems a quite stable readout getting down with range, probably logarithmic?
07 May 2017 15:27 #62104 by goebish
I'm not sure, but I think 100 = 100% of expected packets have been received (it's named "error rate" on actual AFHDS-2A transmitters), so unlike RSSI it's not logarithmic.
07 May 2017 18:52 #62112 by Fernandez
latest firmware the external RX Volt, it is still C1, don't see a difference.
07 May 2017 19:24 #62114 by goebish
Have you checked AllCell ? It should be the sum of C1...C6
07 May 2017 21:18 #62117 by Fernandez
hmm I get 0V at All cell, C1 is still displaying correct voltage as before.
07 May 2017 21:22 #62118 by goebish
Weird, I'll try to debug that.
Thanks for testing ;)
07 May 2017 21:36 - 07 May 2017 21:39 #62119 by goebish
Well, it should work, when I set AllCell in the code I can see it here:
Are you sure you're testing with the d1edbbc version ?
Last edit: 07 May 2017 21:39 by goebish.
07 May 2017 21:44 #62120 by goebish
Ah Ok, I think I found my mistake ... I'll build a new version :)
07 May 2017 21:50 - 07 May 2017 21:51 #62121 by Fernandez
No I do not see that as you show, I double checed and confirm use your firmware ending "edbbc" that field is at 0V.
I still have the third field row 1, C1 displaying the ext Rx voltage.
I also select mainpage config AllCell and also, here displayed 0V.
******Edit forgot this post, waiting to test******
Last edit: 07 May 2017 21:51 by Fernandez.
07 May 2017 21:51 #62122 by goebish
Please check this one, I'm pretty confident it should work now:
www.dropbox.com/s/s06er6pg3gnr2mi/deviat...0.0-b6829cc.zip?dl=1
07 May 2017 21:59 - 07 May 2017 22:05 #62123 by Fernandez
Yes it works the AllCell Field and Cell1 field contain same value.
AllCell field can be used now to trigger battery lipo empty alert and it works.
I have no Flysky sensors to connect, so I can't do more testing from my side.
But I am wondering what happens if connecting a Flysky "lipo" sensor to the balance lead.
Maybe some others can help.
At least for me this is a very useable system now Pack Voltage and Range alerts !
Btw when connecting an Rx at the table, I connect the same volt to RX and to the Vbat port, I read: 5.07V Rx 5.01 V Cell1, to give idea about accuracy same voltage.
Last edit: 07 May 2017 22:05 by Fernandez.
07 May 2017 22:06 #62124 by goebish
All good, so it's ready to be merged now :)
... should appear soon in the nightly builds.
07 May 2017 22:08 - 07 May 2017 22:42 #62125 by goebish
Fernandez wrote: But I am wondering what happens if connecting a Flysky "lipo" sensor to the balance lead.
It should appear in TelemV2 (and TelemV3 if you daisy chain 2 of them), and not counted in AllCell.
Last edit: 07 May 2017 22:42 by goebish.
10 May 2017 15:15 #62209 by Quadman
I have the QX 95 which binds on the Flysky AFHDS 2A, protocol is this available for my devo 7e I have the 3 in one module connected and run all 4 chips?
10 May 2017 15:19 #62210 by goebish
Yes, the AFHDS-2A protocol should work, but I don't know if telemetry is available on your Rx, and even if it is, C1 and AllCell telemetry are not available on the 7e (no HAS_EXTENDED_TELEMETRY because of limited memory)
10 May 2017 15:37 #62211 by Quadman
Has it recently been added or is it the original flysky protocol, in the menu, I believe my devo is running version 5 and one of the nightly builds from 11/2016 ?
10 May 2017 15:38 #62212 by Quadman
Oh and telemetry does not matter as the QX 95 does not have.
10 May 2017 16:00 #62213 by goebish
If it is from 11/2016 then AFHDS-2A protocol should be available (not the same than FlySky, which is older AFHDS)
10 May 2017 16:30 #62215 by Quadman
The only Protacol for Flsky my 7e has is flysky, WLToys ext V9x9 V6x6 and V912, looks like I need to load a nightly build?
10 May 2017 20:11 - 10 May 2017 20:13 #62218 by goebish
Yes, flash the latest nightly, you'll also have to copy layout and media folders to the filesystem, they've been modified recently.
AFHDS-2A is a new protocol, not of sub-format of Flysky.
Last edit: 10 May 2017 20:13 by goebish.
Time to create page: 1.180 seconds
