Flysky AFHDS 2A, protocol as used i10, i6, iT4,
15 Jun 2017 08:15 #63002 by Fernandez
Replied by Fernandez on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
At least I can confirm that in my case Betaflight + ibus + failsave it works, but only way to do it is to setup the failsave, per channel inside the Tx. So when link lost throttle will go down to zero. (or any predefined value as you like). Not sure if it is a real Betaflight failsave, but at least no signal = my motors stop.
Before setting failasave in Tx (while by default) , at signal loss, it continue sending last received value.......(=dangerous)
15 Jun 2017 16:54 #63008 by magic_marty
Replied by magic_marty on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
After you set up failsafe on your tx did you have to rebind to the rx before it would work?
15 Jun 2017 17:04 - 20 Jun 2017 16:46 #63009 by goebish
Failsafe settings are sent regularly every few seconds, it should work instantaneously, no need to rebind or even switch the receiver off/on.(but of course you'll have to switch off the transmitter to check if it works as expected ;))
Last edit: 20 Jun 2017 16:46 by goebish.
15 Jun 2017 17:07 #63010 by magic_marty
So i goto channel failsafe and set it to -125 on throttle and it should drop the throttle when i power off my tx?
Or i can set the Aux channel i have set to Arm and it would dis-arm when powering off the tx?
15 Jun 2017 17:13 #63011 by goebish
If you're arming with an AUX channel then yes, better use that.
Or if you're using cleanflight / betaflight, go to the failsafe tab (enable expert mode) to configure channel value below 950µs as invalid and set failsafe to -125% on any channel on the Devo.
15 Jun 2017 17:29 #63012 by magic_marty
On betaflight when watching the receiver inputs and powering off the tx they all hold and none drop like expected..
I'll do some more testing before i do any test hover ect..
I set my Aux channel that i use to arm at - value ant tested it and it seems to be working with a 2 second delay which is better then before it just keep running..
20 Jun 2017 14:32 - 20 Jun 2017 14:33 #63055 by Arise
I would like to connect to a x6b receiver, I've soldered the wires to it and set Address field to 0x08000000 and Size to 0x8000.
Then I was able to connect, but when I hit save to dump the firmware (bin file) I get an error.
It seems if I try with a hex file dump it works, it produces a 78KB file.
Anything wrong I'm doing?
I powered the x6b also from USB device (STLink) from 5V pin, should that be an issue?
Please look at the attachements...
Last edit: 20 Jun 2017 14:33 by Arise.
20 Jun 2017 14:50 #63056 by goebish
I'm not sure what the problem is... but if you can produce a .hex file without error then that's fine.
20 Jun 2017 16:44 #63057 by Arise
I had to downgrade to ST-Link Utility 3.9.0 from 4.0 and now I can dump the firmware successfully.
20 Jun 2017 17:06 #63058 by magic_marty
Anybody figured out a simple way to get the RSSI out of the X6B rx to an OSD?
20 Jun 2017 17:10 - 20 Jun 2017 17:12 #63059 by goebish
That's possible with the x6b with betaflight + osd (built-in or minimosd ...)
set the LQI Output protocol option to a free channel and setup betaflight to use this channel as RSSI in the receiver tab.
www.deviationtx.com/forum/protocol-devel...-it4?start=480#62318
Last edit: 20 Jun 2017 17:12 by goebish.
20 Jun 2017 17:25 #63060 by magic_marty
Will the LQI still be available on the tx for alarms ect..?
20 Jun 2017 17:36 #63061 by goebish
Yes.
21 Jun 2017 06:34 #63067 by magic_marty
Thanks for all your help and hard work i setup the LQI to ch8 and then proceeded to setup Betaflight to display RSSi and wala it works! Matches my tx LQI display ...Quick question sometimes my telemetry displays turn red but no alarms are triggered cause nothing drops below the settings i have set to sound alarm, then after a few seconds they go back to the normal white display..Any idea what could be causing it?
21 Jun 2017 08:54 #63071 by goebish
That's because your Tx doesn't receive telemetry data for a few seconds, check your antenna.
Also, if you've one of the firsts x-in-1, the LNA is not working for the nrf24l01 and the a7105, this is a known issue, this has been fixed in the last revisions.
21 Jun 2017 16:27 #63077 by magic_marty
Any way to tell if i have one of the early ones? I bought it Dec30th 2016..And got another one for my other tx on Mar 19th 2017..
21 Jun 2017 16:29 #63078 by goebish
Sorry, no idea, you should ask in the 4-in-1 thread.
21 Jun 2017 17:32 #63079 by magic_marty
Both modules i have are doing it but it rarely happens so not to worried about it as long as if don't affect the range of the control inputs..
25 Jun 2017 00:15 - 25 Jun 2017 00:15 #63115 by anthony7288
Replied by anthony7288 on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Last edit: 25 Jun 2017 00:15 by anthony7288.
21 Jul 2017 13:06 #63545 by michel49
I can see alittle difference between the FS and Turnigy Rxs: I can read "Sbus" on the upper connector of the iA6b but I can't run my Corona Sbus servos; is there a way to fix ?
MP
Time to create page: 1.111 seconds
