Flysky AFHDS 2A, protocol as used i10, i6, iT4,
- anthony7288
08 Aug 2016 13:22 #52583
by anthony7288
thank , i confuse .
i wonder : why pin Boot0 connect Gnd still can load program with stlink ? i remember devo 7e have to set Boot0 to 1 to load program ?
Replied by anthony7288 on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
goebish wrote:
anthony7288 wrote: ok , i will try , Uhm maybe STM32F030R8T6 LQFP64
That's a LQFP48, not 64.
joloebig wrote: sound good to me, maybe it other 1.0.8 than my, i read somewhere that tgy was not consist in their versions.
Downloaded from hobbyking.
thank , i confuse .
- anthony7288
09 Aug 2016 14:59 - 09 Aug 2016 15:00 #52616
by anthony7288
it fail
22:01:49 : Device family :STM32F051x4/F051x6/F051x8/F030x8
22:01:49 : Failed to read memory @08000050!
22:02:04 : Flash memory erased.
22:02:13 : [iA6B_1.6.bin] opened successfully.
22:02:13 : [iA6B_1.6.bin] checksum : 0x00431566
22:02:40 : Memory programmed in 9s and 703ms.
22:02:40 : Verification...OK
22:02:40 : Programmed memory Checksum: 0x00431566
22:02:40 : Failed to read memory @0800004C!
22:02:53 : Disconnected from device.
Last edit: 09 Aug 2016 15:00 by anthony7288.
- goebish
- NRF Weirdo
09 Aug 2016 16:05 #52619
by goebish
Replied by goebish on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
I don't know, maybe there's a short somewhere else on the board, I'd check the regulators ... but if you replace half of the parts on the board just to find the RF part is also toast in the end, that's really not worth it.
- anthony7288
09 Aug 2016 16:16 #52620
by anthony7288
i guess stm32f030c8t6 not enough memory for code . . i can load program but it has a problem with memory .
- goebish
- NRF Weirdo
09 Aug 2016 16:19 #52621
by goebish
No, it should be fine, it has 64kB of flash while 32kB are enough.
- Fernandez
09 Aug 2016 19:47 #52633
by Fernandez
Replied by Fernandez on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Thanks Goebish!
The U7E + Extra Switches Pull request, it runs ! Switches still work and the AFHDS 2a it binds. (no flights yet but all seems fine)
Now I need to flash my Ia6b to get the RSSI, if I update using your instruction, do I get also the SBus? Is 1.6 still the latest version?
www.rcgroups.com/forums/showthread.php?t=2677694
btw, for people who want to read the pack voltage, easy mod here:
www.rcgroups.com/forums/showpost.php?p=33432940&postcount=23
- goebish
- NRF Weirdo
09 Aug 2016 19:48 #52634
by goebish
Yes, it's the latest version and has SBUS support
- Fernandez
09 Aug 2016 20:51 #52636
by Fernandez
I flashed using your procedure with 1.6firmware.
One comment to your instruction you can easily edit the ID in the STM-32 ST link utility itself, no need to go to hex editor.
So open the file, scroll to field 0x1C00, than change the 8 digits here into any hex nr except FFFFFFFF
Then must press save first.
Then this file can be flashed.
I have no idea about what the RSSI value means and where to set the threshold for alarm to warn for dropouts or problematic control. When at the table close to my Rx I get value -60d in my Ultimate devo 7e telemetry monitor.
- anthony7288
10 Aug 2016 12:24 - 10 Aug 2016 12:26 #52650
by anthony7288
So result is chip stm32f030c8t6 48pin can not replace for stm031c6t6 orginal
You can see led blink very strange
Last edit: 10 Aug 2016 12:26 by anthony7288.
- goebish
- NRF Weirdo
12 Aug 2016 08:27 #52694
by goebish
At least it seems the MCU is executing some code, I suppose the led flashing 5 times is an error code, maybe because the A7105 is toast as well and doesn't reply to the RF calibration sequence ?
- anthony7288
12 Aug 2016 09:15 #52696
by anthony7288
a7105 not died . I'm sure . because i try it with project Multiprotocol , bind with rx v911 , it work .
i looking for datasheet between Stmf030c8t6 and stm32f031c6t6 . Not diffirence much for two this chip.
- goebish
- NRF Weirdo
12 Aug 2016 09:33 #52697
by goebish
I'm talking of the A7105 (well, A7106 actually) that's inside the iA6B, under the RF shield, not the A7105 in your Devo
- anthony7288
14 Aug 2016 12:44 - 14 Aug 2016 13:12 #52741
by anthony7288
i think i find a problem . IC I2C on rx maybe died .Chip Stm32 can not reply
Last edit: 14 Aug 2016 13:12 by anthony7288.
- djdazzy
18 Aug 2016 12:42 #52869
by djdazzy
Replied by djdazzy on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Can someone please confirm if the AFHDS 2A protocol is in the nightly build now for the 7e?
- goebish
- NRF Weirdo
18 Aug 2016 12:48 #52870
by goebish
No, it's not in the nightly, just download the test build above.
- djdazzy
19 Aug 2016 13:04 #52899
by djdazzy
Thanks Goebish
- Arise
21 Aug 2016 09:34 #52965
by Arise
What is SBUS used for in Flysky/Turnigy Remote? Or is sBUS only for the receivers so they can be paired with sBUS remotes?
Replied by Arise on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
goebish wrote: Yes, it's the latest version and has SBUS support
- Fernandez
21 Aug 2016 09:53 #52969
by Fernandez
The nice thing is that these cheap RX, can output ppm channels, cppm sum, ibus and sbus.
The tx is used to setup the mode of the Rx.
Fantastic isn't it ? much better than keeping buttons on RX pushed forfew seconds etc etc.......
- joloebig
27 Aug 2016 20:44 #53157
by joloebig
Replied by joloebig on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
anyone tested the telemety with a 3in1 modul?
reg
jo
reg
jo
- ketsa
10 Sep 2016 18:01 #53756
by ketsa
Replied by ketsa on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
I'm building a new quad with an FS-IA6B, I have it bound to my Devo7E with AFHDS2A build and A7105, no problem.
But I cannot get any signal in cleanflight receiver page. I tried with PPM and with PWM connected to a SP Racing F3.... no results.
What am I missing ? is my IA6B DOA ?
Time to create page: 0.604 seconds
- Flysky AFHDS 2A, protocol as used i10, i6, iT4,
