Flysky AFHDS 2A, protocol as used i10, i6, iT4,
- goebish
- NRF Weirdo
17 Sep 2016 01:15 - 17 Sep 2016 01:15 #53938
by goebish
Replied by goebish on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Press Enter while the protocol name is highlighted, then select PPM+IBUS or PPM+SBUS output.
Last edit: 17 Sep 2016 01:15 by goebish.
- Appelmoesman
17 Sep 2016 01:16 #53939
by Appelmoesman
Replied by Appelmoesman on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Tnx for your quick reply. If it does not work I hope I can update the firmware with my STlink v2
- Alexandro
17 Sep 2016 08:54 #53954
by Alexandro
Replied by Alexandro on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Hello goebish,
I testet the latest Testbuild from you and found the Bug again and i think the Source of it.
If i change the 2nd Big box to RSSi and Powercycle then it gets deleted
If i change it to Volt 1 and Powercycle it goes to RSSI and gets not deleted after a second Powercyle
It looks like there is an Error at the ?assignment? of the Contend of the Saved Box ( german, Zuordnung des Inhaltes falsch definiert )
It looks like the Bug is only showing up on the extra Contend for the A2 Telemetry, because Timers are ok after Powercycle.
-> no Problem with the Dust on the TX
, i do not need it ! I have DeviationTX
Greetings Alex
Greetings Alex
- goebish
- NRF Weirdo
17 Sep 2016 11:42 #53956
by goebish
Yes, looks like it is a indexing bug when it saves the setup.
Problem is that I have no idea where to look at in deviation code as I've never touched that ...
If I find some motivation I'll try to reproduce the issue and find the commit that introduced this bug.
- djdazzy
17 Sep 2016 15:11 #53964
by djdazzy
Replied by djdazzy on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Thanks for all your hard work and effort goebish.
Finally flashed the new firmware on my 7e, works well with a TGY-IA6 and FS-IA6B in both PWM and PPM mode.
- djdazzy
17 Sep 2016 17:56 #53973
by djdazzy
Few quick questions:
Is the range check function supposed to work please? Also does RSSI telemetry come from an IA6B?
- goebish
- NRF Weirdo
17 Sep 2016 18:05 #53975
by goebish
I'm not sure for range check, I wouldn't rely on it as the PA is always enabled.
RSSI is working with the iA6B, but it needs to be updated to firmware 1.6:
www.rcgroups.com/forums/showthread.php?t=2677694
- ketsa
17 Sep 2016 19:23 #53976
by ketsa
Replied by ketsa on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Is it possible to get the Devo to beep or vibrate when RSSI reaches a certain threshold ?
- goebish
- NRF Weirdo
17 Sep 2016 19:31 #53977
by goebish
Yes, just setup an alarm:
www.deviationtx.com/manuals/html-devo10/...y-config-std-adv-gui
- tkuan
18 Sep 2016 03:31 #53992
by tkuan
Replied by tkuan on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
I flashed the FS-iA6B with firmware 1.6 and both PPM and PWM work on CC3D now. I aIso flashed my Devo 10 to the latest build. I can see both RSSI(-60d) and battery(4.97v) from the receiver. I can't make Telemetry config to stay after power cycle. Maybe that is a bug?
- djdazzy
18 Sep 2016 05:50 #53995
by djdazzy
Thanks goebish, does that mean the power is set to full power all the time so the power output setting doesn't do anything?goebish wrote: I'm not sure for range check, I wouldn't rely on it as the PA is always enabled.
- goebish
- NRF Weirdo
18 Sep 2016 09:54 - 18 Sep 2016 09:57 #53999
by goebish
No, that means than minimum power is 5mW actually, that's too much for range test ...
Oops, I'm wrong, minimum power is ~200µW so that should be fine.
Last edit: 18 Sep 2016 09:57 by goebish.
- goebish
- NRF Weirdo
18 Sep 2016 10:02 #54000
by goebish
Yes, there's a bug with that in the current nightly, that's not specific to the AFHDS 2A protocol. (or is it ?)
tkuan wrote: I can't make Telemetry config to stay after power cycle. Maybe that is a bug?
- djdazzy
18 Sep 2016 10:37 #54002
by djdazzy
Excellent, thanks. I will manually set the power to 200µW to range check.goebish wrote: Oops, I'm wrong, minimum power is ~200µW so that should be fine.
- goebish
- NRF Weirdo
18 Sep 2016 10:41 - 18 Sep 2016 11:51 #54003
by goebish
For A7105-D03 module, 100µW setting in deviation is 200µW actually.
I've no idea how much ground range you should expect with that tho.
Last edit: 18 Sep 2016 11:51 by goebish.
- djdazzy
18 Sep 2016 10:44 #54004
by djdazzy
Ok, I will set it to minimum. Thanks.
- Alexandro
21 Sep 2016 06:36 #54086
by Alexandro
@goebish
The Bug with the RSSI only shows on the new A2 modulation.
If i use Frsky and switch the RSSI at Main Screen then all is ok and it gets saved
all tested with Your new Build for the Flysky A2 RX
greetings Alex
p.s. a litte walk around is to use Volt 1 and do a Power Cycle, then it jumps to RSSI and stay saved.
greetings Alex
- TheSFReader
24 Sep 2016 07:07 #54199
by TheSFReader
Replied by TheSFReader on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Just a quick THANK you all for this. the update to 5.0.0 and binding with a new iA6B went really easy and I can control my new frame with great confidence (DSMX without the range mod was really flaky on my 7e)
- ketsa
10 Oct 2016 19:39 #54800
by ketsa
I just pre-ordered an FS-A8S from Banggood.
New, ultra-small and light (1,2g) 8ch AFHDS2A receiver. Pretty cheap.
It should bind, right ?
- goebish
- NRF Weirdo
11 Oct 2016 12:38 #54818
by goebish
Yes it should work, please report
Time to create page: 0.572 seconds
- Flysky AFHDS 2A, protocol as used i10, i6, iT4,
