Flysky AFHDS 2A, protocol as used i10, i6, iT4,
- joeblack
11 Oct 2016 17:28 #54826
by joeblack
Replied by joeblack on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Thank you for inform us, i also (pre)ordered one for 9 bucks.
Hope i can bind with my Devos with 3in1 Module.
will also report if it works when arrives.
- goebish
- NRF Weirdo
11 Oct 2016 17:31 - 11 Oct 2016 17:33 #54827
by goebish
Replied by goebish on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
I'll try to push AFHDS 2A into nightly builds as it is soon, a few telemetry stuffs are still missing, but the protocol is working well as it is already ...
Last edit: 11 Oct 2016 17:33 by goebish.
- qba667
12 Oct 2016 08:50 #54849
by qba667
Replied by qba667 on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
@goebish
Thanks for reverse engineering of the protocol! Great work!
I would like to change few things in original FS-i6. Have you ever seen commented IDA database of ThomHpl or Dave Borthwick?
Do you know what is the address of method sending configuration packet?
- goebish
- NRF Weirdo
12 Oct 2016 14:54 #54856
by goebish
Sorry, no idea.
- qba667
12 Oct 2016 16:34 #54857
by qba667
Thanks anyhow, I will figure it at my own. Great reverse engineering!
- anthony7288
15 Oct 2016 13:50 #54971
by anthony7288
Replied by anthony7288 on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
hi Goesbish
i read on Rc group , you say
optional: open it in an hex editor then change the 4 bytes at offset 0x1C00 (12 34 56 78) to change RX ID, I think you can use any arbitrary values, just avoid using FF FF FF FF
i still not understand this problem , Open hex editor ? can you show me a photo ?
- goebish
- NRF Weirdo
15 Oct 2016 13:56 - 15 Oct 2016 13:58 #54972
by goebish
Last edit: 15 Oct 2016 13:58 by goebish.
- anthony7288
15 Oct 2016 14:06 - 15 Oct 2016 14:08 #54973
by anthony7288
I open file IA6B , but i see it diffirence your photo ? why on your photo, so much FFFFFFF but i m not ?
Last edit: 15 Oct 2016 14:08 by anthony7288.
- goebish
- NRF Weirdo
15 Oct 2016 14:07 #54974
by goebish
because you've not navigated to offset 0x1c00
- anthony7288
15 Oct 2016 14:18 - 15 Oct 2016 14:22 #54976
by anthony7288
ok , thank you
Last edit: 15 Oct 2016 14:22 by anthony7288.
- goebish
- NRF Weirdo
16 Oct 2016 13:51 #55008
by goebish
The protocol should be in the nightly builds soon, if nobody objects
github.com/DeviationTX/deviation/pull/50
- mazi
17 Oct 2016 11:31 #55042
by mazi
Replied by mazi on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
I get an iA6B receiver from Banggood on Friday and it works fine with my Devo 10 so far. I was surprised I didn't have to update FW to get PPM and sBus working. My only problem is short telemetry range. I suppose it could be because of my multimodule ""burried" under left stick and short antenna inside the transmitter.
The RSSI displayed on my LCD is negative number (-60d), so it is impossible to set alarm for it
- goebish
- NRF Weirdo
17 Oct 2016 11:34 - 17 Oct 2016 12:05 #55044
by goebish
Yes, I think a better antenna is required for telemetry.
This is normal that the RSSI is a negative value, I'll make it positive if required for the alarm. Some work is still required on telemetry anyway ...
Last edit: 17 Oct 2016 12:05 by goebish.
- goebish
- NRF Weirdo
17 Oct 2016 12:35 - 17 Oct 2016 13:08 #55047
by goebish
Also, I've you're using one of the first revisions of the 3-in-1 or 4-in-1 I think there's a problem with the LNA and the A7105, hence bad telemetry range, and there's no easy fix
I've a rev1 4-in-1, I never used it because of that.
Last edit: 17 Oct 2016 13:08 by goebish.
- qba667
23 Oct 2016 19:30 #55315
by qba667
I have digged into telemetry of original FS-i6.
Might be useful for adding other sensors below list of additional ids:
0x0 - Internal Voltage
0x1 - Temperature
0x2 - Mot.?
0x3 - External Voltage
0x7c - Odometer 1
0x7d - Odometer 2
0x7e - Speed
0x7f - TX Voltage
0x1 - Temperature
0x2 - Mot.?
0x7c - Odometer 1
0x7d - Odometer 2
0x7e - Speed
0x7f - TX Voltage
- djdazzy
28 Oct 2016 11:18 #55472
by djdazzy
Replied by djdazzy on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
@goebish has this been done yet please?goebish wrote: The protocol should be in the nightly builds soon, if nobody objects
- goebish
- NRF Weirdo
28 Oct 2016 11:24 #55473
by goebish
Yes
- djdazzy
28 Oct 2016 12:18 #55474
by djdazzy
Excellent thanks !
- Appelmoesman
31 Oct 2016 22:06 #55576
by Appelmoesman
Replied by Appelmoesman on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Tnx Goebish for your work!
After I rewired my A7105 module and build an awesome handcrafted 2.4ghz dipole antenna from some Coax.
I seem to have zero range issues for at least a couple 100 feet!
I used the old wiring for my A7105 chip, and I can recommend everyone to change this to the new wiring as I believe this enables the power amplifier that is build into most DIY A7105 chips.
I have two youtube video's on my youtube video that show, that with the old wiring I had 50M range at most, and with my new wiring Im not noticing any issues as you can tell from the footage.
I've also installed a 1000uF 6V capacitor on the + and - of the chip I believe this might help a tiny bit.
I've build a simple dipole antenna RP-SMA following Wild mania's instructions that he got from old radio frequency school books from I believe russia. anyway the business end is just 29MM and it seems to work very great. He takes in account a certain shortening factor and this increases range for thicker wire antenna's search for him on youtube!
here is my quick demo flight showing that the protocol is super great and that I can now fly High performance quads with 10 euro receivers with my DEVO 7E!!!! YEAAAH
Have fun
Quick demo flight
Im using the TGY Ia6C receiver with BETAFLIGHT and SBUS! I recommend it to everyone that doesn't need PWM and wants to save space
Tnx to goebish im saving allot of money!
Have fun
Quick demo flight
- Fernandez
01 Nov 2016 08:52 #55581
by Fernandez
Replied by Fernandez on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Can you confirm you have Vbat Rx and Vbat Lipo monitoring with the IA6C?
Time to create page: 0.909 seconds
- Flysky AFHDS 2A, protocol as used i10, i6, iT4,
