New FrSkyX protocol
27 Aug 2018 18:21 #70478
This feature will be in the next nightly build.
- Morlacus
27 Aug 2018 19:28 #70481
by Morlacus
Thanks a lot for the info.
Now I hope that Moeder's fix for device=xxx settings in sound.ini for the devo12s is also in the nightlies.
That will enable the use of the buzzer for the vario sound with voices for the other warnings.
Regards
Replied by Morlacus on topic New FrSkyX protocol
hexfet wrote: This feature will be in the next nightly build.
Regards
- Moeder
29 Aug 2018 07:57 #70516
by Moeder
Replied by Moeder on topic New FrSkyX protocol
Sorry, been quite busy these weeks. I haven't pushed the fix to nightlies, please be patient a couple of days, I'll see what I can do.
- Morlacus
29 Aug 2018 09:10 #70519
by Morlacus
Hello Moeder
Thanks for your reply. Pleased to see you again on the forum.
Regards
Morlacus
Regards
Morlacus
- Morlacus
06 Sep 2018 08:06 #70679
by Morlacus
Hello
I have adjusted the Freq-Fine setting with a Frsky Rx.
I have bought another one.
Can I assume that the setting of Freq-Fine will be the same for this new Rx (and any Rx using this protocol) ?
Regards
Morlacus
Regards
Morlacus
12 Sep 2018 02:10 #70822
Probably not. My own experience is two D4R receivers with FreqFine of -42, and one XSR at -15.
- Fernandez
12 Sep 2018 06:55 - 12 Sep 2018 06:56 #70828
by Fernandez
Replied by Fernandez on topic New FrSkyX protocol
I opened topic some time ago, to see what are the fluctuations.
I would expect that each Tx module has it's own (constant) offset.
www.deviationtx.com/forum/3-feedback-que...ncy-tunes-here#68331
Variations then would be variations in each Rx?
I believe the Midelic RX code also has some auto tune and try to bind at center? No ideaif this is also implemented in the major Rx.
Last edit: 12 Sep 2018 06:56 by Fernandez.
- Frantico
28 Sep 2018 16:16 #71084
by Frantico
Replied by Frantico on topic New FrSkyX protocol
Hello
I can’t bind r-xsr receiver to my jumper T8sg plus
I need some help
What I need to try?
I need some help
What I need to try?
- tomy03ful
09 Oct 2020 20:38 - 09 Oct 2020 20:45 #76868
by tomy03ful
Replied by tomy03ful on topic New FrSkyX protocol
Anyone who has a problem with binding should perform a frequency fine tuning (to go to "freq-fine" select the protocol (in this case frskyX) then press enter). It is recommended to perform it even if the default setting is correct.
The freq-fine is 0 by default, and in certain cases with frsky receivers (for example R-xsr), the freq is so bad that the binding is impossible. In some cases the binding is possible, but the connection not as good as it should be. So I recommend to do the freq fine tuning to achieve the best freq for your receiver.
Last edit: 09 Oct 2020 20:45 by tomy03ful.
- seppilin94
17 Feb 2021 21:11 #77259
by seppilin94
Replied by seppilin94 on topic New FrSkyX protocol
I am using a Jumper T8SG Plus v2. Firmware up to date. Frsky xmplus. Tx set to FrskyX with 16ch and RSSI to LastChan. I see RSSI on the receiver tab in Betaflight on Aux12, but I can’t see the RSSI on TelemRSSI output on the Tx. Should I be doing something else?
- Gerry
- Bbrad
17 Feb 2021 23:14 #77261
by Gerry
FFS (Forever Fixing Stuff)
Replied by Gerry on topic New FrSkyX protocol
XM+ does not transmit rssi back to tx, only to bf for use over osd.
- Krejzi
22 Feb 2021 23:14 #77271
by Krejzi
Replied by Krejzi on topic New FrSkyX protocol
I just cleaned my Devo 7E from dust, because I am planning to build mu first quadcopter. Started looking at receivers, initially was planning to go with DSMX, as I know that works fine, but I started looking ad FrSkyX receivers.
I couldn't get that from that topic, but does that latest protocol supports telemetry fully ? (GPS, Voltage etc.), I can see no RSSI but what about GPS?
I want to know that before I will buy CC2500 module.
Time to create page: 0.296 seconds
- New FrSkyX protocol
