New FrSkyX protocol
- Alexandro
06 May 2016 06:12 - 06 May 2016 06:13 #47861
by Alexandro
Replied by Alexandro on topic New FrSkyX protocol
Test Ver. 18a
DEVO8s
AD2GAIN at 1000 shows Volt3 / 10 . The Calculation is ok, but the 1/10 Divider does reduce the Voltage around 0.4X Volt to the AD2 Input Pin.
Here we need a bit more Room with the 1000 at AD2GAIN. May be 1500 ?
I think we need a little AD2 Adjust to compensate the Volt loss of the Divider Board to get better on Point of the real Volt.
DEVO7e
Menu is now ok.
yes , i think it is better to remove all things who are not supported by the System to get not confused .
doing a deep Test later
greetings Alex
Test Ver. 18a
DEVO8s
DEVO7e
Menu is now ok.
greetings Alex
Last edit: 06 May 2016 06:13 by Alexandro.
- Fernandez
06 May 2016 07:44 - 06 May 2016 09:25 #47862
by Fernandez
Replied by Fernandez on topic New FrSkyX protocol
To get it fully correct, in addition to the divider ratio, might be needed an offset field in +/- 0,01 Volt correction steps. I believe Taranis radio has this option.
However AD2 Volt just as purpose end of flight empty battery indicator, adgain setting only is probably accurate enough.
Last edit: 06 May 2016 09:25 by Fernandez.
06 May 2016 21:06 - 06 May 2016 21:06 #47905
Test build is updated - 070.
- Removed extended telemetry values from 7e telemetry and main page config pages (except Volt2 - see below)
- Set max AD2GAIN to 2000, corresponding to a multiplier of 20.00
- Restored normal function for Volt3 telemetry value
Decided against further AD2GAIN changes at this time. A fixed offset doesn't seem right because then a zero input would not read 0. There are only 255 ADC steps so error is about 4% anyway. For 3S that's about 0.04 volts.
The 7e telemetry still shows Volt2 available because this code is shared with Frsky (D8) and there the 7e does receive Volt2 telemetry. I didn't want to add a runtime check to several places in the code. The other values are excluded at compile time.
Thanks again for all the testing!
Last edit: 06 May 2016 21:06 by hexfet.
- Arakon
06 May 2016 22:04 #47912
by Arakon
Replied by Arakon on topic New FrSkyX protocol
Went flying with 18a earlier today, put 8 packs through 2 quads, XSR and X4R receivers.. no issues. Only using RSSI telemetry, though.
07 May 2016 01:11 #47936
Good to hear. Thanks!
- Arakon
07 May 2016 16:35 #47974
by Arakon
Could you create a Devo 7e-256 test file please?
- Alexandro
07 May 2016 17:33 - 07 May 2016 17:35 #47979
by Alexandro
Test Ver. 070
Devo 7e
PWM out 1 to 8 : ok
Volt1 : ok
RSSI : ok
-> looks good , time to Test fly it . Maybe Tomorrow
Devo 8s
PWM out 1 to 8 :ok
Volt1 : ok
Volt2 : ok <- it is the best to calibrate it at the Volt you need ( 3.6 for 1 s, ........ ) The difference is not par. with the Voltage drop ( Batt full to Batt low) , but i think it is ok.
RSSI : ok
Alt : looks good
Dis : looks good
Vspeed: looks good
-> all in all looks good, doing some deep Test (Alt,Dis,Vspeed,SBUS ) tomorrow to cross check with Taranis. Maybe i do a Devo 10 Test to
greetings Alex
Test Ver. 070
Devo 7e
PWM out 1 to 8 : ok
Volt1 : ok
RSSI : ok
Devo 8s
PWM out 1 to 8 :ok
Volt1 : ok
RSSI : ok
Alt : looks good
Dis : looks good
Vspeed: looks good
greetings Alex
Last edit: 07 May 2016 17:35 by Alexandro.
- Arakon
08 May 2016 13:54 - 09 May 2016 13:10 #48032
by Arakon
Nevermind, just managed to get it compiled myself.
If anyone wants to try it on an "Ultimate" 7e, I attached the file.
Edit:PB removed attachment
Arakon wrote: Could you create a Devo 7e-256 test file please?
Last edit: 09 May 2016 13:10 by PhracturedBlue.
- Alexandro
08 May 2016 16:14 #48044
by Alexandro
@Arakon
Maybe some Days at looking at 7e 256 i cant resist to fire up my hot Air Station
Thanks for the File, i saved it at my Destop
greetings Alex
greetings Alex
- Cereal_Killer
08 May 2016 17:06 #48052
by Cereal_Killer
Replied by Cereal_Killer on topic New FrSkyX protocol
Hi, quick question about this...
I have a X9E and have X4R's installed in all my models which is why I'm so interested in this now. I have the blue CC2500 module from BG en route via fast shipping and expect it this week. My concern is the "model match" feature of the frsky receivers.
Before when I was flying DSMX and using my pair of devo's (7E and 10) all I had to do was set the fixed ID the same in each tx .ini then bind one tx after the other (but ONLY ONCE). As long as I turned one of the two tx's on first (and only one at a time) I could pick up and fly any model with either tx just having to sellect the proper model file for that model. I didn't have to re-bind each time I wanted to use the other tx since the fixed ID was set the same, just power it up and go flying.
The question-
Will I be able to do something similar going from X9E to devo back and forth or will I have to completely rebind every time (and if so, what does that do to the telemetey aspect, will I have to re-discover every sensor every time)? I'm concerned about this "model match" feature (I use the term feature loosley), is it going to make it hard for me to switch between tx's? Does devo allow the setting of the "receiver number" somewhere like in have to do in taranis?
The question-
- Fernandez
08 May 2016 18:05 #48057
by Fernandez
Not tested it, but according post Tom Peer, you can use multiple devo bind to same rx,
Type in your hardware.ini file: txid = 86668963 (8 digit code), use same id for your radios.
www.deviationtx.com/forum/3-feedback-que...xedid-question#41711
But not sure how to find the id of your Taranis?
- Arakon
08 May 2016 18:40 - 08 May 2016 19:05 #48059
by Arakon
I'd be interested in how to find your current one so you can adjust it in case of a CPU change.
Edit: Tried to make it write the ID to the tx.ini in a really dirty way, but both MCU_serialnumber and Transmitter.txid seem to return 0 there. Unfortunately I don't know jack about coding, so I'm guessing this is way beyond my ability.
Last edit: 08 May 2016 19:05 by Arakon.
- mickkn
08 May 2016 19:49 - 08 May 2016 19:50 #48067
by mickkn
Replied by mickkn on topic New FrSkyX protocol
Does this protocol work for EU and non-EU RX firmware?
And if not, is there a way to flash a X4RSB without a Taranis?
Last edit: 08 May 2016 19:50 by mickkn.
- Arakon
08 May 2016 20:12 #48068
by Arakon
Only non-eu, I believe. You can flash the X4R either using Frsky's official flash tool and smartport adapter, or a normal FTDI and a resistor.
08 May 2016 20:59 #48069
Test build is updated - b02.
- Added support for 7e-256 with extended telemetry enabled (and included in test build)
- Merged latest changes from deviationtx/master
The merge brought in the changes PB talks about here for buttons and display. Noticed a couple menu titles missing on the 10 but haven't yet looked at the code.
I've created a pull request for the protocol_frskyx3 branch.
- Alexandro
09 May 2016 09:16 #48097
by Alexandro
Deep Test with Ver. 070
Devo 10
Telemetry :ok
SBUS : ok
found some little Error on AMP.
0.2 Amp shows 0.6 Amp at the TX , DIS calculate with the 0.6 A and is then to high.
o.t. the Frsky D8 Telemetry does not get any Data from the X - extension, black Background and showing 0.
greetings Alex
Devo 10
Telemetry :ok
SBUS : ok
greetings Alex
- Cereal_Killer
09 May 2016 13:14 - 09 May 2016 14:16 #48110
by Cereal_Killer
delete
Last edit: 09 May 2016 14:16 by Cereal_Killer.
- Cereal_Killer
09 May 2016 13:25 #48113
by Cereal_Killer
Taranis doesn't have a "fixed ID". For model match, it simply uses what it calls "receiver number" which is just a one or two digit number (that usually corresponds to the model file number but doesn't have to. It automatically chooses the next unused number each time you create a new file). Do you think I should try entering that number into the devo's fixed ID field (for example on my 200 I want to use the devo 10 on it's rx #2, model file 2)
Let's say I can't get it working back and forth, will I have to rediscover all the telemetry sensors each time I bind back and forth? Does devo even require the discovery step? FWIW I don't have a single smart port sensor, I get all my telemetry data from cleanflight and A2 pack voltage.
Fernandez wrote: Not tested it, but according post Tom Peer, you can use multiple devo bind to same rx,
- Arakon
09 May 2016 13:27 #48114
by Arakon
Not for the X receivers.. they use s.port, which is a single wire serial protocol. You need the resistor to join RX and TX into a valid signal for that.
Cereal_Killer wrote:
Don't even need a reaistor, just an FTDI and a program from FDTI called FT PROG to invert the output.Arakon wrote: ...or a normal FTDI and a resistor.
- Cereal_Killer
09 May 2016 14:15 #48117
by Cereal_Killer
Ah yea you got me. I read X series, I typed X4r but because most recently I had flashed a D4r-ii that's the process I had in my head.
-will edit above post to remove incorrect info when I'm at my desk later today
Thx
-C_K
P.s. any idea about fixed ID vs receiver #? Can fixed ID in devo be a single digit number?
Thx
-C_K
Time to create page: 0.891 seconds
- New FrSkyX protocol
