JJRC H6W Protocol
12 Feb 2016 02:46 #43023 by whensgen
JJRC H6W Protocol was created by whensgen
Good Morning!
I'm fairly new to the forums, but I have a working modded 7e to interface with my x600, which works perfectly.
However, I also have a JJRC H6W (wifi FPV) quad. The similar quads to this model (JJRC H6C, H8, so on) all seem to use the 2x2 protocol to communicate, but that protocol refuses to bind to the H6W. Does anyone know for sure what protocol this runs? I'm happy to pull apart the transmitter if that would help.
Thank you!
25 Feb 2016 17:22 #43631 by goebish
Replied by goebish on topic JJRC H6W Protocol
JJRC are known to never use the same protocol :p
Yes, take a picture of the inside of the transmitter, that's the first thing to do, then check this thread:
www.deviationtx.com/forum/protocol-devel...95-spi-capture-guide
25 Feb 2016 17:58 #43636 by whensgen
Replied by whensgen on topic JJRC H6W Protocol
is directly uploading them OK, or is uploading to a host like imgur a better way?
25 Feb 2016 18:02 #43637 by goebish
imgur, then use the img tag to display them on the forum ;)
25 Feb 2016 18:06 #43638 by whensgen
Here you are, then the opened transmitter.
25 Feb 2016 19:13 #43640 by goebish
That's probably a xn297 transceiver, check the other thread if you want to help ;)
25 Feb 2016 19:33 #43641 by victzh
Replied by victzh on topic JJRC H6W Protocol
The visible letters on the radio board - "2420" suggest that it may be something more civilized - Beken maybe.
25 Feb 2016 19:38 #43642 by whensgen
Thanks for the idea. I'll look at that. Any idea what protocol to try and bind?
16 Mar 2016 00:13 - 16 Mar 2016 00:14 #44622 by andremp
Replied by andremp on topic JJRC H6W Protocol
On the quad its a xn297. I´ve cound bind with he protocols i've tried...
Last edit: 16 Mar 2016 00:14 by andremp. Reason: wrong image
16 Mar 2016 07:56 #44635 by SeByDocKy
Replied by SeByDocKy on topic JJRC H6W Protocol
I am not suprized .... JJRC is always changing its protocol. For ex tje JJRC H20, H20C have the same, the H20W another one.
I am sure it's the same than the H20W. I captured SPI data sometimes ago. See JJRC H20W/ Eachine H99 thread in protocol developpement
