holystone hs170 predator
- nashad822
22 Mar 2016 04:45 #44967
by nashad822
holystone hs170 predator was created by nashad822
is there a protocol for the holystone hs170 predator out there? it is a very common quad and rated number 1 on amazon canada.
- NightFlyerRC
25 Nov 2016 13:04 #56271
by NightFlyerRC
Replied by NightFlyerRC on topic holystone hs170 predator
It sure would be nice if someone found settings needed to fly the HolyStone HS170 Predator and the new HS170C Predator 2. These are both great flying drones that are very popular and which I believe use the A7105 module with either the Hubsan or Flysky protocols.
The quads would be an awesome and much appreciated addition to the current Deviation supported models and I hope someone figures this one out soon.
Thanks, and soft landings.
- ClittleJ
- Danik
18 Mar 2017 05:59 #60311
by Danik
Replied by Danik on topic holystone hs170 predator
Agree. Would love to have this in our database of drones
- NightFlyerRC
24 Jun 2017 12:17 #63106
by NightFlyerRC
Yeah, I have been hoping to find those settings for a while now.
- goebish
- NRF Weirdo
24 Jun 2017 22:12 #63114
by goebish
Replied by goebish on topic holystone hs170 predator
That won't happen automagically, someone has to check which rf IC is in the Tx first, then provide a dump if this chip is supported.
- Stormin
26 Jan 2019 08:47 #72533
by Stormin
Replied by Stormin on topic holystone hs170 predator
i Have photos of the board and the IC. It is a 16 pin set up but has no identifying maker or part number. I can provide the photos staright away but don't have the skills to dump the chip. I can send you the board if you would like to try to decode it.
- goebish
- NRF Weirdo
26 Jan 2019 09:53 - 26 Jan 2019 14:16 #72534
by goebish
Please send pictures of the boards (TX & Quad), even if there's no marking on ICs.
Last edit: 26 Jan 2019 14:16 by goebish.
- Stormin
26 Jan 2019 17:40 #72547
by Stormin
- Stormin
- Fernandez
26 Jan 2019 18:42 #72552
by Fernandez
Replied by Fernandez on topic holystone hs170 predator
to me it seems you need to focus your camera and can read the chips
- Stormin
26 Jan 2019 19:19 #72554
by Stormin
I get that the photo could be better but I assure you, the chips have been etched or bleached. I've tried different lighting and no go. I will try a uv at work Monday. I have a good magnifier and in white light its just an illegible shadow. I'll get some clearer pics with a better photo rig and re up, but it wont help with the chip label.
- goebish
- NRF Weirdo
27 Jan 2019 01:48 - 27 Jan 2019 02:19 #72569
by goebish
I'm not 100% sure but looks like Panchip ICs (xn297l compatible).
Can you read PAN159CY on the bigger IC in the quad ?
Anyway, there's no SPI bus, if someone can send one to a dev maybe it can be deviated.
Last edit: 27 Jan 2019 02:19 by goebish.
- Stormin
27 Jan 2019 07:58 #72571
by Stormin
Trust me...you can't read the chip labels...
I think it would be a blessing to all the folks that like this drone to have an open tx option; and I'm not at all pleased with the fact that the maker has gone to some lengths to disguise the chips.
Taken together, these points make this easy...shoot me an address and I'll drop ship the boxed drone to the dev team.
- goebish
- NRF Weirdo
27 Jan 2019 10:37 #72573
by goebish
I'll send you my address in PM, I believe this is XN297L compatible, but I can't be sure if the marking is unreadable, so there's no guaranty I will succeed.
- solderflux
12 Feb 2019 15:47 - 23 Feb 2019 01:09 #72873
by solderflux
Replied by solderflux on topic holystone hs170 predator
Last edit: 23 Feb 2019 01:09 by solderflux.
- goebish
- NRF Weirdo
12 Feb 2019 15:56 #72874
by goebish
That's a tlsr8368 MCU with builtin RF transceiver, I've never seen one before, no idea if it can be emulated with one of our 4 supported transceiver until someone dumps the signal with a SDR device.
I can take a look if someone sends one to me, but without any guaranty I can make it work with Deviation.
- solderflux
21 Feb 2019 19:36 #72959
by solderflux
unfortunately I cannot buy another one at the moment..
hopefully someone else will read this thread and send one in
I read that the previous poster was going to send an HS170 , do you think the protocol will be the same as HS170G ?
- solderflux
22 Feb 2019 22:51 - 23 Feb 2019 01:07 #72975
by solderflux
Last edit: 23 Feb 2019 01:07 by solderflux.
- solderflux
23 Feb 2019 01:46 - 23 Feb 2019 01:56 #72978
by solderflux
if it can be useful I found the datasheet and product brief for the TLSR8368 (that is in the transmitter) :
www.telink-semi.com/2-4g
on the drone receiver board there is the TLSR8568 instead, which I only found referenced here:
fccid.io/YVYHYXHK8019/Operational-Descri...cription-3073980.pdf
Last edit: 23 Feb 2019 01:56 by solderflux.
Time to create page: 0.613 seconds
- holystone hs170 predator
