Traxxas TQ
- izzy84075
17 Aug 2016 02:51 #52831
by izzy84075
Traxxas TQ was created by izzy84075
Uses the CYRF6936 and appears to be pretty simple, so far. Still learning my way around this radio, but looking at the other protocols using this radio, I think I picked a good one to start with.
Only have a sample size of 1 so far, but here's my notes so far.
The "01 00" it starts with looks like an ID field, and then it looks suspiciously like 7 2-byte data fields. Possibly the first four bytes are something special and then 6 2-byte fields, as the trigger is wired to "channel 1" on the board, and comes out as "channel 1" on the receiver...
More experimentation to follow as I have time!
mfg_id: 7a b3 92 43 23 fd
sopcode: {0xEF, 0x64, 0xB0, 0x2A, 0xD2, 0x8F, 0xB1, 0x2A},
"Idle" packet: 01 00 02 fb 02 f5 02 ee 00 00 00 00 02 ee 00 00
"Trigger somewhat pulled" packet: 01 00 02 f6 03 19 02 ee 00 00 00 00 02 ee 00 00The "01 00" it starts with looks like an ID field, and then it looks suspiciously like 7 2-byte data fields. Possibly the first four bytes are something special and then 6 2-byte fields, as the trigger is wired to "channel 1" on the board, and comes out as "channel 1" on the receiver...
- izzy84075
17 Aug 2016 19:08 #52844
by izzy84075
Replied by izzy84075 on topic Traxxas TQ
Updated notes from today~!
All of my capturing so far has been with no receiver turned on, so there's probably a bunch that I haven't seen yet.
While idling(With no receiver on, at least), it appears to alternate between two SOP code/CRC seed sets every once in a while:
crcseed: 0x27fe
sopcode: {0x97,0xE5,0x14,0x72,0x7F,0x1A,0x14,0x72},
crcseed: 0xa5a5
When in "bind" mode, it uses this SOP code/CRC seed:
Binding sopcode: {0x3C, 0x37, 0xCC, 0x91, 0xE2, 0xF8, 0xCC, 0x91}
Binding crcseed: 0x5a5a
The transmitter appears to wait for the receiver to initiate binding, not the other way around.
The transmitter never sent anything while in binding mode, only continuously checked for received packets.
"Steering right" packet: 01 00 03 dc 02 f8 02 ee 00 00 00 00 02 ee 00 00
"Steering left" packet: 01 00 01 f5 02 f8 02 ee 00 00 00 00 02 ee 00 00
Trim adjusts steering output, as expected.
WIP Packet architecture: aaaa cccc bbbb eeee dddd gggg ffff hhhh
aaaa
Packet type and/or "channel" ID?
Never seen anything except 0x0100 here, but I only have one transmitter/receiver pair.
bbbb
Channel 1
Range: Unknown, seems centered on ~0x02f5, probably roughly the same as Channel 2.
Used for: Throttle
Higher value is forward, lower value is reverse.
cccc
Channel 2
Range: Seems to be roughly 0x01f5 - 0x03dc, center is ~0x02fb
Used for: Steering
Higher value is right, lower value is left.
dddd
Channel 3?
Never seen anything except 0x0000 here
Transmitter has an unpopulated "Channel 3" input marked on it's PCB, haven't tried hooking anything up to it yet.
eeee
Channel 4?
Never seen anything except 0x02ee here
ffff
Channel 5?
gggg
Channel 6?
hhhh
Channel 7 or unused checksum?
Never seen anything except 0x0000 here.
This being channel 7 would not match the pattern of all the other channels, might be an unused checksum field?- izzy84075
18 Aug 2016 01:08 - 18 Aug 2016 01:55 #52855
by izzy84075
Hooked a pot up to the unpopulated CH3 input on the PCB, and nothing happened in the radio packets. Looking a bit closer at the pinout of the MCU, it wouldn't even actually be able to read a pot there, so I'm not sure what's going on there... Oh, it's an STM8S005K6 , by the way. The receiver has the same radio/processor pairing.
I do have an ST development kit, I should try connecting to this and see if I can dump it...
EDIT: Flash is protected on the MCU, sadly.
Last edit: 18 Aug 2016 01:55 by izzy84075.
Time to create page: 0.062 seconds
- Traxxas TQ
