Eachine E010 inductrix clone data captures
- HappyHarry
27 Aug 2016 13:48 #53135
by HappyHarry
Eachine E010 inductrix clone data captures was created by HappyHarry
hi guys, i have captured the data from the eachine e010 transmitter in hopes of the protocol being hacked, the files, and a description of the settings and capture files are included in the zip file >>
www.dropbox.com/s/37qz9wj2u6v0u6r/E010-Samples.7z?dl=0
if you need any more samples let me know, and thanks in advance if anyone tackles this protocol
- goebish
- NRF Weirdo
27 Aug 2016 14:01 #53136
by goebish
Replied by goebish on topic Eachine E010 inductrix clone data captures
Thank you very much for the captures
I'm very glad to see it's using a xn297l, I'll have a look at your captures and I should receive mine soon, it's been shipped 1 week ago
- goebish
- NRF Weirdo
27 Aug 2016 14:06 - 27 Aug 2016 14:29 #53137
by goebish
Can you recapture with a higher bitrate please ? 200khz is not enough, try 16MHz
Last edit: 27 Aug 2016 14:29 by goebish.
- HappyHarry
27 Aug 2016 15:50 - 27 Aug 2016 16:34 #53139
by HappyHarry
Replied by HappyHarry on topic Eachine E010 inductrix clone data captures
no problem, I'll get them up soon, by the way do the captures look ok data wise? as in will 3wire spi still be hackable?
Last edit: 27 Aug 2016 16:34 by HappyHarry.
- goebish
- NRF Weirdo
27 Aug 2016 17:06 #53143
by goebish
I don't know if data is fine as bitrate is too low.
I don't think it's 3 wire SPI, just that MISO isn't connected, but even if it was 3 wire SPI no problem.
- HappyHarry
27 Aug 2016 18:05 #53144
by HappyHarry
no probs, I was worried when I saw the 8pin version of the xn didn't have the full spi pinout, only clk, csn and data. I'll be home in about 30mins so expect the new captures within the hour bud
- HappyHarry
27 Aug 2016 18:32 #53145
by HappyHarry
ok new captures are up, let me know if they are ok or if you need anything else done
- goebish
- NRF Weirdo
27 Aug 2016 18:35 #53146
by goebish
Looks fine, I'll try to take a further look this evening
- HappyHarry
27 Aug 2016 18:46 #53147
by HappyHarry
many thanks, and good luck
- goebish
- NRF Weirdo
27 Aug 2016 18:47 #53148
by goebish
Seems simple, expect a test build soon
- rasqba
27 Aug 2016 18:54 #53149
by rasqba
Unbelievable, how can I buy you a beer?
Thanks for the work man
Replied by rasqba on topic Eachine E010 inductrix clone data captures
goebish wrote: Seems simple, expect a test build soon
- HappyHarry
27 Aug 2016 19:23 #53151
by HappyHarry
awesome
i have both a modded 7e and an ultimate7e so a build for either of those would be great, or if you push the code to your deviation repo i can pull and build them myself to save you time
awesome
- goebish
- NRF Weirdo
27 Aug 2016 20:33 #53156
by goebish
I'll try to implement it as an mjqx protocol format option, they're quite similar.
- Soulsmoke
27 Aug 2016 21:16 #53158
by Soulsmoke
Replied by Soulsmoke on topic Eachine E010 inductrix clone data captures
Great news!
I have had mine for a day or so and it flies really well, quite smooth and precise once you get past the teeny transmitter. My gimbles felt very dry and creaky out of the box so I whipped it open and lubed it a bit, better now but using the Devo would just be the icing on the cake.
What module will this be using? I have a NRF sitting in my parts box but not having anything to bind it to I am yet to install.
Thanks for the work on this
- goebish
- NRF Weirdo
27 Aug 2016 21:17 #53159
by goebish
It will be using the nrf24.
Stay tuned, I should have something for you to test in a few minutes
- goebish
- NRF Weirdo
27 Aug 2016 21:27 - 27 Aug 2016 21:49 #53160
by goebish
Last edit: 27 Aug 2016 21:49 by goebish.
- HappyHarry
27 Aug 2016 21:46 - 27 Aug 2016 21:47 #53161
by HappyHarry
sorry bud it's not binding, edit sorry i'll try the second version and report back
Last edit: 27 Aug 2016 21:47 by HappyHarry.
- HappyHarry
27 Aug 2016 21:47 #53162
by HappyHarry
the link isn't working bud
- goebish
- NRF Weirdo
27 Aug 2016 21:49 #53163
by goebish
Fixed
- HappyHarry
27 Aug 2016 21:59 #53164
by HappyHarry
still no luck bud, i tried extending the range of the throttle channel to make sure it was recieving a full +100/-100 to see if that helped the bind but no luck
- Eachine E010 inductrix clone data captures
