DEVO7E+S-FHSS ENDPOINT
- micro heli club
05 Sep 2016 10:35 #53497
by micro heli club
DEVO7E+S-FHSS ENDPOINT was created by micro heli club
Can not set the end point from 1000 to 2000 in a DEVO7E + S-FHSS + F3 EVO Brush Flight Control Board + Cleanflight (CF).
Fixed in 1110-1930.
Not reflected be set to MAX-250 ~ + 250.
Fixed in 1110-1930.
- aMax
05 Sep 2016 10:41 #53499
by aMax
Replied by aMax on topic DEVO7E+S-FHSS ENDPOINT
... and if you use subtrim to midpoint 1500 it will be even more less on top.
- micro heli club
05 Sep 2016 10:52 #53502
by micro heli club
Replied by micro heli club on topic DEVO7E+S-FHSS ENDPOINT
Thank you!!!
Again from 1110 to 1930 it does not change.
It is always 1110 to 1930.
Setting of Cleanflght (CF) is 1,000 to 2,000.
05 Sep 2016 10:55 #53503
Replied by FDR on topic DEVO7E+S-FHSS ENDPOINT
Have you calibrated your sticks?
- micro heli club
05 Sep 2016 11:30 #53506
by micro heli club
yes~~~
If DSM2 receiver will operate normally.
I think that due to the S-FHSS of protocol.
Original 100 size (Gravy100)
- Ryou
- micro heli club
05 Sep 2016 12:21 #53508
by micro heli club
Oh my god ~ ~ ~http://www.deviationtx.com/media/kunena/emoticons/pinch.png
Change to DSM2.
Thank you!!!
Change to DSM2.
Thank you!!!
- victzh
07 Sep 2016 20:45 #53601
by victzh
Replied by victzh on topic DEVO7E+S-FHSS ENDPOINT
This can be fixed - I indeed did not test it on the original Futaba receiver - I don't have one. We have the protocol value calculated as
(u16) (496 - (ch * 410 / CHAN_MAX_VALUE))
which limits it by 86-906, while I suspect the actual range is 0-1023. So the range in internal units - 820 - matches the range in ms, also 820.
- Ryou
08 Sep 2016 12:54 - 08 Sep 2016 12:57 #53633
by Ryou
Replied by Ryou on topic DEVO7E+S-FHSS ENDPOINT
I'm sorry will not be improved.
More than 100% of the scale will not be reflected.
100% scale is the same as the FUTABA 1.52ms + -0.41ms.
FUTABA You can configure up to 140%.
The 140% setting is 1.52ms + -0.57ms.
Last edit: 08 Sep 2016 12:57 by Ryou.
- micro heli club
08 Sep 2016 13:10 #53634
by micro heli club
Thank you
DSM2 is operating normally on the satellite receiver.
- victzh
08 Sep 2016 16:02 #53641
by victzh
@Ryou, @micro heli club, what receivers do you use?
- Ryou
09 Sep 2016 02:55 #53664
by Ryou
I'm sure in OrangeRx SF700S receiver.
It compares the FUTABA T8J transmitter in the same receiver.
PWM width has been observed by the digital oscilloscope.
victzh wrote: @Ryou, @micro heli club, what receivers do you use?
- micro heli club
09 Sep 2016 02:56 #53665
by micro heli club
・ElgaeRX FUTABA S-FHSS 8Ch receiver⇒DEVO7E Deviation NG、FUTABA T14SG OK。
・SPEKTRUM DSM2 satellite receiver⇒DEVO7E Deviation OK。
・SP RACING F3 EVO Brush Flight Control Board
- victzh
09 Sep 2016 20:11 #53702
by victzh
OK, I will try to tune it with SF700S I have.
- micro heli club
02 Oct 2016 00:26 #54489
by micro heli club
Again I want to use the S-FHSS (S-BUS) receiver. Is there a way?
Time to create page: 0.181 seconds
- DEVO7E+S-FHSS ENDPOINT
