Cheerson CX35
- goebish
- NRF Weirdo
08 Jan 2017 13:01 - 08 Jan 2017 13:18 #57692
by goebish
Replied by goebish on topic Cheerson CX35
At least I know how to generate IDs that do have 0x23 as base frequency... I could implement it like that and that should be fine, but I'd prefer to crack it thoroughly, nice brain teaser
Last edit: 08 Jan 2017 13:18 by goebish.
- ajtank
14 Jan 2017 05:24 #57921
by ajtank
Replied by ajtank on topic Cheerson CX35
I have uploaded the capture of another transmitter in a new folder. Hope it helps, thank you.
- goebish
- NRF Weirdo
14 Jan 2017 12:34 #57934
by goebish
Thanks, even if I don't understand the mapping thoroughly yet (that may require up to 32 extra Rx captures ...) I think I should be able to make a test build during the week-end and there should be enough entropy to be able to fly with several deviated transmitters in the same area without interferences.
- ajtank
14 Jan 2017 13:16 #57935
by ajtank
I can make further capture if necessary. I can also ship you the FC board if it is easier for you. By the way I have received the Q303 board, thanks.
- goebish
- NRF Weirdo
14 Jan 2017 23:18 - 14 Jan 2017 23:20 #57957
by goebish
Here is a test build, please test with several transmitter IDs:
www.dropbox.com/s/snbibjalkippmg6/deviat...0.0-2fe169c.zip?dl=1
diff
It's not thoroughly cracked, but if it works that should be fine for now ...
diff
Last edit: 14 Jan 2017 23:20 by goebish.
- ajtank
15 Jan 2017 09:57 #57961
by ajtank
Performance of the new build is good. I have spent 30 minutes playing with ID's made up of 1 to 6 digits and all can bind. Great job !
- goebish
- NRF Weirdo
15 Jan 2017 11:34 #57963
by goebish
Cool !
That is good enough for now... now to the CX10D
Time to create page: 0.428 seconds
- Cheerson CX35
