Mjx Bugs 3
- C0ckpitvue 777
02 Jan 2017 00:52 #57444
by C0ckpitvue 777
Mjx Bugs 3 was created by C0ckpitvue 777
If anyone is interested and has the Mjx 3 bugs and willing to take captures,I am willing to have the tx shipped to a willing reliable source if the gurus are willing to deviate this monster.
- SeByDocKy
02 Jan 2017 17:03 #57481
by SeByDocKy
Replied by SeByDocKy on topic Mjx Bugs 3
It's no more compatible with the former MJX protocols ?
- Moeder
02 Jan 2017 19:05 #57484
by Moeder
Replied by Moeder on topic Mjx Bugs 3
I doubt it, since is advertised with some kind of drone battery voltage telemetry (alarm). I guess someone needs to do a capture first.
- SeByDocKy
02 Jan 2017 20:04 #57488
by SeByDocKy
Just made a test .... neither the X600 or X800 protocols are working
.... I will try to capture some SPI data .... but I have so much works front of me that I can't promise
- C0ckpitvue 777
02 Jan 2017 20:23 #57489
by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Mjx Bugs 3
Thanks Seby,I just ordered the TX from Aliexpress,I will also take some captures once it arrives.If you need an extra Tx I will order 1 and send it to you.
- C0ckpitvue 777
18 Jan 2017 01:22 #58100
by C0ckpitvue 777
My bugs 3 tx just touched base,I opened it up and unsure where to solder the pins for captures.I took some pictures any help is greatly appreciated.
- ajtank
18 Jan 2017 03:34 #58104
by ajtank
Replied by ajtank on topic Mjx Bugs 3
We can tell the 2nd pin from the top is GND. If you can determine which one is V+ then connect the rest to the analyzer and post the file.
- goebish
- NRF Weirdo
18 Jan 2017 03:36 - 18 Jan 2017 03:46 #58105
by goebish
Replied by goebish on topic Mjx Bugs 3
You can also connect vcc to the analyzer if not sure, no problem, but I think it's the top pin on ajtank's picture
Last edit: 18 Jan 2017 03:46 by goebish.
- C0ckpitvue 777
18 Jan 2017 11:16 #58116
by C0ckpitvue 777
Ok,found the vcc its the first 1 on top did not solder a wire to it,the 2 solder point on the left are also giving me voltage readings,do I also solder them.
- goebish
- NRF Weirdo
- C0ckpitvue 777
19 Jan 2017 01:39 #58155
by C0ckpitvue 777
These are test captures just want to know if they are ok.
www.mediafire.com/file/mp1dk9crrmdd78q/1...%5D%282%29.logicdata
- C0ckpitvue 777
19 Jan 2017 02:32 #58157
by C0ckpitvue 777
I took these captures with version 1.21 and took this 1, www.mediafire.com/file/gosphirqwcbned7/test.txt with salae 1.115C0ckpitvue 777 wrote: These are test captures just want to know if they are ok.
- goebish
- NRF Weirdo
19 Jan 2017 02:40 #58158
by goebish
I only had a look at the 1.21, looks fine, seems it's a A7105.
- goebish
- NRF Weirdo
19 Jan 2017 02:43 #58159
by goebish
confirmed, this is an a7105:
www.dropbox.com/s/8sppfb7d9vj8yjz/mjxbugs3.txt?dl=0
- C0ckpitvue 777
19 Jan 2017 02:58 #58161
by C0ckpitvue 777
Thanks Goebish,will upload the true captures hopefully this weekend.The spare transmitter beat the quad here,lol.Waiting for the quad to touch base.
goebish wrote: confirmed, this is an a7105:
- coryroyce
06 Feb 2017 16:10 #58824
by coryroyce
Replied by coryroyce on topic Mjx Bugs 3
I'm interested in knowing if the Bugs 3 will be added to Deviation. Can some one let me know the current status?
Also, does Open TX use all the same Deviation updates so if this model is added to Deviation, then it will be available on Open TX at the same time.
Thanks in advance for the help.
- C0ckpitvue 777
06 Feb 2017 22:55 - 06 Feb 2017 22:57 #58834
by C0ckpitvue 777
I'm waiting for my bugs 3 to arrive to continue taking captures.Tomtop must of put it on the scenic route half way past Pluto and a mile away from Venus, lol.It's taking forever.I ordered an extra tx and I did test captures that goebish said looked good.I'm just waiting last tracking info I had was on January 21st but soon a I get it I will post the captures.
Last edit: 06 Feb 2017 22:57 by C0ckpitvue 777.
- C0ckpitvue 777
26 Feb 2017 02:22 #59632
by C0ckpitvue 777
Hey fellas sorry for the delay,I finally got the quad.I'm taking all captures tonight but want to know if these 2 are ok before I move on.Any feedback is greatly appreciated.
www.mediafire.com/file/3c3gab9rf4ier40/Arm+and+Disarm.logicdata
www.mediafire.com/file/peyqx4to0qm28sd/T...uad+Tx+off.logicdata
- goebish
- NRF Weirdo
26 Feb 2017 02:38 #59634
by goebish
Doesn't look good, I think you have SCS wrong, but I'm not sure.
Also, start capture before switching the transmitter on.
- goebish
- NRF Weirdo
26 Feb 2017 02:43 - 26 Feb 2017 03:07 #59635
by goebish
My mistake, your captures are fine.
edit: only the 1st one is fine.
Last edit: 26 Feb 2017 03:07 by goebish.
Time to create page: 0.493 seconds
- Mjx Bugs 3
