Mjx Bugs 3
26 Feb 2017 04:01 #59640 by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Mjx Bugs 3
Ok,here's is all of the captures,I re did the second 1,if you need anything just let me know.Thank you very much.
www.mediafire.com/file/7alwthsya324tqd/M...3+capture%282%29.zip
28 Feb 2017 16:40 #59715 by C0ckpitvue 777
Hey guys I know you are very busy,just wanted to know if you think this protocol will be deviated in the future,if I can assist in any other way monetary funding for proper equipment or any more captures to implement this protocol I am very willing to contribute.Thank you.
28 Feb 2017 17:33 - 28 Feb 2017 17:37 #59718 by goebish
Replied by goebish on topic Mjx Bugs 3
I only checked that the captures were correct, I've no idea of the amount of work required to deviate it.
Next on my list are JJRC H20H, JJRC H20/H30 mini, AFHDS 2A telemetry, Hubsan H501 then the Mjx Bugs 3, so don't hold your breath.
You can pledge my patreon account if you want to (really appreciated !), but that usually doesn't change anything to my priorities ;)
www.patreon.com/goebish
Last edit: 28 Feb 2017 17:37 by goebish.
28 Feb 2017 17:57 #59719 by C0ckpitvue 777
goebish wrote: I only checked that the captures were correct, I've no idea of the amount of work required to deviate it.
Thanks for the reply,I appreciate your work and time.
02 May 2017 21:27 #61944 by coryroyce
Replied by coryroyce on topic Mjx Bugs 3
Is there any update on the schedule for when the Bugs 3 protocol will be added?
05 Aug 2017 03:30 #63737 by kiwi-craig
Replied by kiwi-craig on topic Mjx Bugs 3
hi guys any update on this ?
05 Aug 2017 14:55 #63744 by C0ckpitvue 777
To busy enjoying my phantom and 3dr solo,I took the captures it's up to the gurus,like goebish told me don't hold my breath and I didn't,lol.
15 Aug 2017 20:49 #63810 by Hypnotoad
Replied by Hypnotoad on topic Mjx Bugs 3
Just received mine. Maybe this is off topic, but I just unboxed it, set it up, and connected to the mjx bugs. As soon as it connects, the motors spin at a low rate. Its like there is a tiny bit of throttle on. Not enough to lift off, but certainly enough to bash your fingers pretty good. I have tried the controller calibration, but that did nothing. Any ideas? This is yet another reason for the deviation.... The mjx bugs 3 controller has a fake button where the throttle calibration should be!
16 Aug 2017 00:41 #63812 by kiwi-craig
the red button top left enable - disengages the motors and is part of the arming sequence, motors spinning = armed, push and hold the red button until the motors disengage
11 Sep 2017 03:08 - 11 Sep 2017 03:26 #64319 by Hypnotoad
Im trying to research a ton of stuff all at once and i know that this forum has some of the best gurus around, so maybe you could point me in the right direction.
First, what are you using to take captures? Logic analyzer?
Second, is it possible to take captures from a non programmable FC? (like the bugs 3)
I assume that if this firmware can be flashed, then you could modify the captures and maybe add some kind of acro mode. I cant be the first person who has thought about doing this, yet I cannot find any info for the MJX Bugs 3 FC. (I believe its the MJX B30012) Has anyone ever tried connecting with a st link?
So, I guess my final question is, would this work?
Last edit: 11 Sep 2017 03:26 by Hypnotoad.
16 Nov 2017 06:49 #65870 by Moeder
Replied by Moeder on topic Mjx Bugs 3
I haven't done an A7105, but took a look at the captures. Most seems pretty straightforward, but I'm missing a true bond sequence.
16 Nov 2017 11:44 #65887 by C0ckpitvue 777
16 Nov 2017 11:47 #65888 by C0ckpitvue 777
If that doesn't work i will try to recapture if i still got the modded tx.Thank you for giving this thought.It's greatly appreciated.
16 Nov 2017 14:38 #65897 by goebish
Bad capture, are you sure ground was connected ?
16 Nov 2017 19:01 #65903 by Moeder
Indeed, bad capture.
@goebish: have you done any work on this protocol already?
16 Nov 2017 20:25 #65904 by goebish
Nope, I haven't done anything.
16 Nov 2017 22:14 #65908 by Hypnotoad
I have already put mine through its paces. I ended up removing the guts and putting in a F3 flight controller and upgrading the ESCs along with a camera and vtx. Worked great, but after a few flights, I crashed and something happened to a motor. I have too many other builds to worry about replacing the motors right now, but thats one way to get better range and performance. I cant justify buying a set of motors for it right now, but maybe down the road I will fix it up with some low KV motors and use it for a filming rig. Adios Bugs. For now....
17 Nov 2017 00:13 #65915 by C0ckpitvue 777
Ok fellas sorry for the long delay, I just got in from work went downstairs and found the tx and the bugs3.I will recapture the bind sequence and give it to you hopefully tonight.Just wondering if you guys can resend me the link to the analyzer software,it was on my other laptop and the screen is about to go,I greatly appreciate it.
17 Nov 2017 00:15 #65916 by goebish
17 Nov 2017 01:29 #65917 by C0ckpitvue 777
Thank you for the link,Try this if not good let me know.
drive.google.com/file/d/1eA7Zxe3wh0-FkyS...v8h/view?usp=sharing
Time to create page: 0.289 seconds
