Mjx Bugs 3
07 Aug 2018 12:39 - 07 Aug 2018 12:39 #70149 by xalex75
Replied by xalex75 on topic Mjx Bugs 3
Great! I already put telemetry on mine, I hope that 78 is a safe RSSI value
Last edit: 07 Aug 2018 12:39 by xalex75.
07 Aug 2018 16:16 #70152 by SG
Replied by SG on topic Mjx Bugs 3
Thanks David, now I will test for range
08 Aug 2018 10:00 #70157 by davdrone1
Replied by davdrone1 on topic Mjx Bugs 3
Updated to test build 50f6e42 today. My two Bugs 3s were able to bind and fly without any issues.
My Bugs 6 would not bind until I deleted the fixed id, and replaced it using the new build. It was then fine.
The newly obtained fixed id was the same value as the previous one - fixed_id=-1382767019.
Time flies like a banana
08 Aug 2018 16:30 #70161 by xalex75
did anybody do a range test?
today I had RSSI drop to 68 while flying in the field in fron of my home, i think it was about 100m far.
I'll try to put B3's antenna in vertical and see...
08 Aug 2018 17:32 #70162 by SG
With a horizontal antenna and on the original remote flew too at 100 m. with the vertical antenna on the leg, flew at 300 m. with T8SG v2+ I have not tried, but through 2 walls RSSI sometimes drops to 60, sometimes no response telemetry. This weekend will go to the open field and try
08 Aug 2018 18:06 #70163 by xalex75
With vertical antenna it worked really better, I think that I will mod the canopy.
I just used a drow and hot glue for testing purpose.
I will also do some indoor test through walls, good idea.
08 Aug 2018 21:00 #70164 by RCFUN0102@gmail.com
Replied by RCFUN0102@gmail.com on topic Mjx Bugs 3
so changing t8sg output doesn't make any changes WRT distance? ie 50, 100, 150..
08 Aug 2018 21:07 #70165 by RCFUN0102@gmail.com
Question...Is this where noobs can ask dumb questions? if not please advise, as I was trying to "go for it" today and could not get the jumper to show up in the USB tool.. I was using 2.31 (As I was following Frequent Flyer RC's how to vid) I did try multiple cables with no joy. lastly I am using a WIN7 64 bit machine... any help is appreciated. V/r RCFun's Diversions on YT
09 Aug 2018 00:19 #70168 by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Mjx Bugs 3
@Rcfun,I'm not familiar with the jumper or the windows 7 drivers,maybe davdrone1 can chime in and help you out,in his video it looks like he's running win7.Also which jumper version do you have?
09 Aug 2018 01:05 #70169 by davdrone1
I used a 2009 Notebook with Windows XP Pro when I first learnt to setup my Jumper. Here's a video I made about it.
I did not need any additional drivers, just the Defuse program.
I can't help with any more recent MS products, as I don't use them. I now use my Mint Linux desktop PC - java for flashing new dfu files, and file manager (caja) to copy files back and forth to the Jumper in USB Thumb drive mode.
09 Aug 2018 01:07 #70170 by RCFUN0102@gmail.com
hmmm I got the silver and gray one Version 2 I think as I have a USB port I can access..
09 Aug 2018 01:09 - 09 Aug 2018 01:10 #70171 by RCFUN0102@gmail.com
Thanks ill give it a go tomorrow... I orig tried to load the Dfuse Upgrade tool: 2.31, is that the necessary or optimal version? I also have a Linux fedora laptop
Last edit: 09 Aug 2018 01:10 by RCFUN0102@gmail.com.
09 Aug 2018 01:30 #70172 by davdrone1
Dfuse USB Upgrade Tools 2.31 is all that most people seem to need on a Windows PC.
I hacked my Jumper when the USB port failed, installing an external USB port.
For the Linux option, see -
www.deviationtx.com/forum/7-development/...or-usbcode?start=140
My comment on how I successfully used it is the most recent on the forum. (Page 8).
09 Aug 2018 03:54 #70173 by davdrone1
Discovered quick bind and unbind - useful if you run a fleet ...
09 Aug 2018 06:49 #70175 by SG
Thanks, auto bind when you turn on T8SG very well. This appeared in the latest test firmware ?
09 Aug 2018 12:19 #70179 by xalex75
I noticed that auto bind works in both ways, by switching on tx first or B3 first.
I Think that this could really help in regaining control after loosing connection in flight for few moments.
09 Aug 2018 16:39 #70185 by RCFUN0102@gmail.com
I still cant get Devo DfuSe USB upgrade tool to recognize the T8SG. As I can see the jumper in USB mode, can I simply overwrite the files manually without the tool and get the same results? Thanks in advance.
09 Aug 2018 17:04 #70186 by SG
To turn on the DFuSe mode, you need to hold down the back key and press briefly on the power.
Could install the wrong driver, remove it from device Manager along with the software. Then run "DFU USBDrv Installer-1.1" and choose there
"Install Walkera USB driver". And run again in DFuSe mode.
I had the same, apparently the driver was already standing but for another device
09 Aug 2018 18:17 #70187 by RCFUN0102@gmail.com
It worked!!! thanks so much everyone!!!!!.. I'm in the club...lol The only thing I noticed is I did not have to edit the .ini file on the T8SG as after it bound to the copter it binded with a 10 digit number that was in the second column on the spreadsheet... I simply turned it off and back on and I was golden, after configuring switches it is off the ground.. TYTYTY!!!
09 Aug 2018 18:30 #70188 by xalex75
On windows 10 I didn't have any problem or driver request, everything worked at first try. Also no ini edit, but probably that was for older firmwares.
Time to create page: 0.241 seconds
