Mjx Bugs 3
09 Aug 2018 19:25 #70190 by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Mjx Bugs 3
So happy for you bro, deviation turned this bugs into a beast,I appreciate the help and support from those who chimed into help rcfun.I hope the b3 mini gets violated by deviation also ..
10 Aug 2018 13:02 - 10 Aug 2018 13:08 #70201 by kaseym
Replied by kaseym on topic Mjx Bugs 3
SG wrote: To turn on the DFuSe mode, you need to hold down the back key and press briefly on the power.
Could install the wrong driver, remove it from device Manager along with the software. Then run "DFU USBDrv Installer-1.1" and choose there
"Install Walkera USB driver". And run again in DFuSe mode.
I had the same, apparently the driver was already standing but for another device
This worked for me. Have 50f6e42 working on the bench with V2 plus and bugs 3. Will fly later. Thanks everybody.
Last edit: 10 Aug 2018 13:08 by kaseym.
12 Aug 2018 20:49 #70229 by SG
Replied by SG on topic Mjx Bugs 3
Did a range test in ideal conditions, came about 800 m, the remote did not swear, but on the way back something went wrong. Either the trees blocked the signal or the antenna fell off its feet and the wind changed the angle. Started to lose control, it's seen in the video, and then just fell off, this time is not recorded.
15 Aug 2018 09:29 #70253 by Risqi
Replied by Risqi on topic Mjx Bugs 3
hexfet wrote: Test build is updated (dc7544a). This build incorporates mmakai's code (thanks!) for automatically setting the radio id.
This works with my receiver, though it sets a different radio id than the one found manually. Please try binding your aircraft with the procedure below and make sure it works for you. Thanks!
"Hence, the binding procedure changes as follows:
1) In the bugs3 model delete all the digits of the fixed id. The display should say fixed id None.
2) Click Bind on the model screen.
3) Apply power to the bugs3. The bugs3 should react but deviation bind dialog will remain.
4) Turn the transmitter off (this saves the model with radioid stored in the fixed id).
5) Turn the transmitter on, go to the model screen, the fixed id should be the radioid.
6) With the right radioid bind should succeed. Click Bind on the model screen.
7) Apply power to the bugs3. Now it should connect. (If not, then repeat 6-7)."
Thank you very much, now i can fly my bugs 3 with t8sg v2 plus.. Terima kasih banyak
17 Aug 2018 21:38 #70312 by Bugs3Bugs8ProFPV
Replied by Bugs3Bugs8ProFPV on topic Mjx Bugs 3
A question regarding channels:
Channel 5 is for arming the motors
Channel 6 is for toggling the lights
Channel 7 is for flips
What about the channels for taking a photo and starting / stopping video recording when using the C5820 and C5830 FPV cameras with built in DVR?
I'm planning on installing the Bugs protocol on a Jumper T8SG V2.0 PLUS
Thanks,
19 Aug 2018 15:47 #70344 by Jimbuck
Replied by Jimbuck on topic Mjx Bugs 3
i tried all that it works with my b8 but wont work on the b3
21 Aug 2018 15:42 #70370 by rmoosreiner
Replied by rmoosreiner on topic Mjx Bugs 3
First of all all my appreciation for this fantastic work! I love flying my Bugs3 with my T8SG. Just a question? Will the latest Test Build be included in the Nighly Builds?
21 Aug 2018 19:26 #70373 by hexfet
Replied by hexfet on topic Mjx Bugs 3
No, bugs3 is not yet in the nightly builds.
Test build is updated (5122995). Added support for video and picture controls.
Found the info in Cockpitvue's original captures.
CHANNEL_ARM         CHANNEL5
CHANNEL_LED         CHANNEL6
CHANNEL_FLIP        CHANNEL7
CHANNEL_PICTURE     CHANNEL8
CHANNEL_VIDEO       CHANNEL9
22 Aug 2018 00:19 #70375 by JayDrone
Replied by JayDrone on topic Mjx Bugs 3
u r the man bro -- so after tackling this daunting task u have hit a home run in my book -- if you could if it is not to much -- the KAIDENG K70C Sky Warrior is running on the 010 protocol and binds -- I hve gotten the lights on off -- picture n video and what I think is headless mode figured out -- the drone stock controller had a button to fire the motors and never offered down and out to fire them -- I have gone thru every channel and none will fire the motors -- any ideas -- i dont know how daunting of a task it it to ceat a new protocol but id think in this manner as it is on the 010 it may be something simple idk get at me man video here for you to see whats going on
22 Aug 2018 00:27 #70376 by goebish
Replied by goebish on topic Mjx Bugs 3
Get a logic analyzer then post some captures, shouldn't be hard to make it work if it binds already.
www.deviationtx.com/forum/protocol-devel...95-spi-capture-guide
Please use the E010 thread ;)
www.deviationtx.com/forum/protocol-devel...a-captures?start=280
22 Aug 2018 01:38 #70377 by JayDrone
ok just looked at how to do what u asked and it is all a diff language for me i am not a tech guy at all -- i think this hobby found me by accadent lol-- I can fly very well but as far as the tech and doing as instructed in the video I just watched not for me guess I will have to wait for some one more copable to do what u need till then stock controller i guess thanx for reply tho
22 Aug 2018 08:06 - 22 Aug 2018 08:40 #70381 by goebish
As you wish, but if you can solder a wire (x4) you can do it ;)
You don't have to understand the video actually, just get a logic analyzer ($5), take a picture of the inside of the stock transmitter and we'll tell you where to attach the probes.
Last edit: 22 Aug 2018 08:40 by goebish.
22 Aug 2018 10:54 #70382 by rmoosreiner
Thanx, will try out the latest Test Build today. Sorry for another Beginners Question, when you compile a new Test Build is it based on the latest (at that moment available) Nightly Build?
22 Aug 2018 12:05 #70383 by hexfet
Yes, the test builds are up to date with the nightly builds.
22 Aug 2018 20:20 #70390 by planger
Replied by planger on topic Mjx Bugs 3
@HexFET
It looks like this protocol is almost ready. So I'm thinking it's time to port it on Multi. Do you agree?
Can you point me to the source location?
Thanks, Pascal
22 Aug 2018 20:40 #70391 by Ninou33540
Replied by Ninou33540 on topic Mjx Bugs 3
hello its my firts post and my english is bad.y want to said a big big thank you to hexfet for the bug3 protocol,it works perfectly whit the drocon blue bug 3
.i have just a little problem whit the telemetri voltage :it fixed to 8.4 volts and didnt move .Y think its a setup problem and y will find the problem.
22 Aug 2018 20:58 #70392 by hexfet
The bugs3 receiver does not send the real battery voltage. It just sends a good or low setting. Deviation reports good as 8.4V and low as 6.0V. The bugs3 seems to change from good to low at a battery voltage about 6.4V, so you could set an alarm for that value. When the alarm activates the bugs battery should be around 6.4V.
22 Aug 2018 21:02 #70393 by hexfet
Pascal, I'm not planning any more changes unless some issue comes up. Source is here . Also just updated the manual , getting ready for PR.
22 Aug 2018 21:06 #70394 by Ninou33540
thank you for the answer, ist works great :)
22 Aug 2018 22:09 - 22 Aug 2018 22:14 #70395 by planger
hexfet wrote: Pascal, I'm not planning any more changes unless some issue comes up. Source is here . Also just updated the manual , getting ready for PR.
Thanks.
I've looked at the code and I'm puzzled about the need to launch the bind twice.
Please correct me if I'm wrong but it looks to me that you could be all set during the 1st bind sequence.
To do this, you'll need to replace this part of the code:
       // if fixed_id not set, put rxid there
        // then user must look up radio id and store in fixed id
        if (Model.fixed_id > RXID_MAX) {
            set_radio_data(1);
            A7105_WriteID(Model.fixed_id);
        } else {
            u16 rxid = (packet[1] << 8) + packet[2];
            u32 radioid = rxid_to_radioid(rxid);
            Model.fixed_id = radioid;
            break;
by
       // set fixed_id to radio_id
       A7105_WriteID(radioid);
       set_radio_data(1);
It would make it easier for the users since you don't need to delete all the digits of the fixed id (they are getting replaced by the latest bind) and you only have to launch 1 bind sequence to get a working model.
Pascal
Last edit: 22 Aug 2018 22:14 by planger.
Time to create page: 0.604 seconds
