Mjx Bugs 3
31 Aug 2018 12:01 - 31 Aug 2018 12:02 #70584 by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Mjx Bugs 3
It's in the latest nightly...
Last edit: 31 Aug 2018 12:02 by C0ckpitvue 777.
31 Aug 2018 12:12 - 31 Aug 2018 12:12 #70585 by C0ckpitvue 777
Another awesome job,big shout outs to hexfet and planger for allowing this acro mode to be implemented in the latest build,just took her out on a quick test flight and the acro works flawlesslyI didn't check the b8 pro flips on channel 7 and I didn't check the transition between acro/angle modes during flights because my channel 10 was also mapped to my arm and disarm switches,I remapped the switches so I'll give it a go later and will update,thanks again for the hard work,it's greatly appreciated..
Last edit: 31 Aug 2018 12:12 by C0ckpitvue 777.
31 Aug 2018 14:53 #70590 by C0ckpitvue 777
Just took it out for a flight,it doesn't look like you can between acro/angle during flight with the bugs 8 pro,I think you got to take out the jumper and rebind it to fly it in angle,I tried every switch and it continues in acro during flight...
01 Sep 2018 00:24 #70601 by ScottyK
Replied by ScottyK on topic Mjx Bugs 3
Yes I too must give all you guys at Deviation a big shout out. You guys have made this hobby so mutch more fun with your efforts Its a real pleasure knowing that there are people out there willing to be patient and help people with the kindness you have shown. Prably should have posted this on the main page but it just became verry clear to me Thanks
06 Sep 2018 01:40 #70673 by RCFUN0102@gmail.com
Replied by RCFUN0102@gmail.com on topic Mjx Bugs 3
Gentlemen,
I have an issue..so I was able to bind the Bugs-3 using a late dfu....not sure if it’s the latest or not right now and the bugs flys great with the jumper and I can turn on and off the lights..but here is the problem...I have installed an fpv cam that plugs into the board..and can record when pressing the right shoulder button on stock remote..but I cannot program the jumper to do that as o believe it’s because it only shows 7 channels on mixer? So basically I can’t record my flight using the mjx C5830 cam with jumper..which stinks because as you know I can get more range with jumper...smh Any help would be appricieated... thanks in advance...
RCFun’s Diversions (On YT)
06 Sep 2018 15:55 #70687 by RCFUN0102@gmail.com
So, I seen this may be covered from a reply from Hexfet which was stated (22Aug18) Test Build Updated (5122995) to support video and picture controls... But, how do I find this. under test builds I do not see that number..
Thanks for helping a noob..
Vr
RCFuns Diversions
06 Sep 2018 15:58 #70688 by C0ckpitvue 777
It's in the nightly builds now..
06 Sep 2018 15:58 #70689 by vlad_vy
Replied by vlad_vy on topic Mjx Bugs 3
Use nightly build.
06 Sep 2018 17:07 #70690 by Noramas
Replied by Noramas on topic Mjx Bugs 3
Just bought a Jumper T8SG and would like to run it on a Bugs3 Mini. Are there any plans to create the code for the Bugs 3 Mini?
06 Sep 2018 18:19 - 06 Sep 2018 18:20 #70693 by RCFUN0102@gmail.com
When I got to nightly builds I see stuff like:
deviation-t8sg-v5.0.0-1cf0866
for download but I do not see the one hexfet stated added support for video and picture controls as in the forum he stated it was test build (5122995) ... should the download name match the numbers he provided?? I am probably nuking this but any assistance is appreciated..
Thanks,
RCFun's Diversions
Last edit: 06 Sep 2018 18:20 by RCFUN0102@gmail.com.
06 Sep 2018 18:31 #70694 by C0ckpitvue 777
You can use that 1cf0866 it's in there.
06 Sep 2018 19:38 - 06 Sep 2018 19:38 #70696 by goebish
Replied by goebish on topic Mjx Bugs 3
Noramas wrote: Just bought a Jumper T8SG and would like to run it on a Bugs3 Mini. Are there any plans to create the code for the Bugs 3 Mini?
C0ckpitvue 777 has sent one to me, I haven't received it yet and I'm leaving home until October.
Stay tuned to this topic: www.deviationtx.com/forum/protocol-development/7850-bugs-3-mini
Last edit: 06 Sep 2018 19:38 by goebish.
07 Sep 2018 00:00 #70697 by C0ckpitvue 777
Has anybody managed to switch from angle to acro mode while in flight with the bugs 8 pro,or do you have to shutdown and rebind to switch modes,any feedback is greatly appreciated.
07 Sep 2018 18:18 #70728 by RCFUN0102@gmail.com
Awesome thanks S! I will work on it this weekend.. I'm real excited to get some good FPV video while using the controllability and range of the jumper... lastly what are your thoughts on the new editions of the jumper? a must have?? or is old gray and black good for now.. thanks again...
lata
RCFun
07 Sep 2018 18:44 #70729 by C0ckpitvue 777
I don't have any of the Jumpers,I'm pro Devo's,lol.
09 Sep 2018 22:57 #70767 by aszasza
Replied by aszasza on topic Mjx Bugs 3
Hi guys, total noob here just found this brilliant forum and I have to say I'm stunned by the knowledge of the people here. Thats enough rambling, I'm writing here because I'm about to get my bugs 3h, this is the new model with altitude hold function. I'm pretty good with electronics as a hobbyist so I thought I could collaborate with you guys to see if the protocol is any different on this model. I haven't found any info on the 3h so far, so I think its a good idea.
On the other hand, I'd love to fly on a frsky x-lite, and the only option I found is the vantac mpm module. Is that the only multi protocol tx module that fits the x-lite? If so, I would give it a try to design a pcb for a diy version, but I would need a bit of help with that.
Ok I think this is enough for my very first post in this forum. :)
Have a nice day!
10 Sep 2018 09:01 #70770 by Einsteins
Replied by Einsteins on topic Mjx Bugs 3
hellow guys, thank you so much for build new protocol for mjx bugs3
im using jumper silver and jumper v2 plus,
with nighly build 8 september, i just found this will work on mjx bugs3 new, bugs 6, bugs8, bugs 3mini, bugs 8 pro
but not working on bugs 3 first edition(maybe first batch production), mjx b3h, mjx b5w, mjx b3pro and mjx b2w
but anyway, thank you so much for all working here
im really apreciate for you all :cheer:
10 Sep 2018 10:21 #70771 by doittom
Replied by doittom on topic Mjx Bugs 3
Einsteins wrote: hellow guys, thank you so much for build new protocol for mjx bugs3
With nighly build 9sept( ~21674bd), bugs3 first edition works well.
I have 2 pieces of b3 first edition, is there any method for 2 auto binding with i modeling , not seperately modeling ?
10 Sep 2018 13:03 #70773 by ncfom
Replied by ncfom on topic Mjx Bugs 3
I have a Bugs 3 bought in Jan 2017. Transmitter is Devo 7e modded with NRF24L01 , A7105 modules and 2-3x2 switches. I can only get the motors to arm and disarm , no other inputs seem to work. I am using the model23.ini from COckpitvue.
I have used the Devo 7e to fly WL Toys 686g. SymaX8, Frankenspider, JJRC 1000 and a 450 Flamewheell
Any suggestions would be appreciated.
Jerry
10 Sep 2018 18:03 #70774 by C0ckpitvue 777
ncfom wrote: I have a Bugs 3 bought in Jan 2017. Transmitter is Devo 7e modded with NRF24L01 , A7105 modules and 2-3x2 switches. I can only get the motors to arm and disarm , no other inputs seem to work. I am using the model23.ini from COckpitvue.
Jerry
Did you update the protocol folder when you updated the dfu?
Time to create page: 0.282 seconds
