Furibee F36 protocol attempt
28 May 2017 08:05 #62621 by martonmiklos
Replied by martonmiklos on topic Furibee F36 protocol attempt
Could you please share a pinout for the TX IC? Power, GND, XTAL, antenna and analog pins would be interesting. Let's assume they are using the same vendor's IC is in the TX.
02 Jun 2017 07:01 #62754 by martonmiklos
I have asked the NST for datasheets, and I got a package from them which (of course) did not contained any more comprehensive material, but shown some hints.
www.dropbox.com/s/v4p6pfhgl55lhpa/NST_Pack.zip?dl=0
I have realized that the same chip also manufactured/sold by the company called Levetop:
www.levetop.com/ch/product1_5916.html
Their available datasheet seems to be less comprehensive:
www.levetop.com/data/LT5916_SS.pdf
At least the have a dev tool package available. I am still downloading it to see if they have some interesting headers or whatever inside. Stay tuned!
02 Jun 2017 08:36 #62755 by xxx
Replied by xxx on topic Furibee F36 protocol attempt
Interesting stuff
In the zip there are some hex encoded files, and they have what appears to be a similar encoding to the on-air protocol.
Since they have both in and output files ( I think ) perhaps they can be used to figure out how it's done. They call it "encryption" but I don't see why anyone would need it for programming the chip
silverxxx
02 Jun 2017 11:43 #62759 by martonmiklos
If my understanding is correct there is a standalone device used for factory programming and you can download the "SSL" encrypted firmware files to it.
BTW: Have you had a chance to lookup the TX IC pinout?
I have installed the development tools available at the Levetop's website, and there are not so much interesting stuff (regmaps, datasheets whatever).
It installs an Eclipse based IDE, mcore-elf-gcc and gdb, and STLINK drivers :D
The toolchain vendors seems to be the C*Core (chinacore: www.china-core.com )
02 Jun 2017 12:44 - 02 Jun 2017 12:44 #62764 by xxx
It might support st-link too, there is a INT/SWD pin.
The tx chip is a different kind, most likely a 8 bit OTP.
It seems the quadcopter's IC might have been designed for quads in particular, it has 4 pwm pins, and their development board has gyro and a motor driver on it.
silverxxx
Last edit: 02 Jun 2017 12:44 by xxx.
02 Jun 2017 13:08 #62765 by martonmiklos
Where have you found this dev board?
02 Jun 2017 16:20 #62768 by bikemike
Replied by bikemike on topic Furibee F36 protocol attempt
Is that the "Co_Setup" development tools that you downloaded? Is there any reference to the LT5916 in it? The reason I'm asking is that the download description says it is for the LT32 series.
02 Jun 2017 16:26 #62769 by martonmiklos
Correct, I have mentioned the Co_Setup. There are not any references to the LT5916 series in it.
If I think well our subject (LT5916) uses the same core so there were a chance that it would be also supported.
03 Jun 2017 03:36 #62800 by xxx
In the nst_pack.zip there is LT5910 demo board schematic pdf.
silverxxx
03 Jun 2017 08:13 #62804 by martonmiklos
Ah okay, but that schematic has LT5910S-SO16 in the title, which is confusing because that MCU look like a bigger one in QFN48 package.
27 Jun 2017 07:20 - 27 Jun 2017 07:46 #63165 by martonmiklos
Good news guys!
I have not stopped pinging our friends at NST, so they have given me what I (we) wanted.
It turned out that the LT5916 is basically a LT32A01 and an LT8920 packaged together:
This is LT5916 detailed data sheet, where 5916内核 is the mcu part of LT5916, where LT8920 is the RF part of LT5916.
They were kind enough to provide a Chinese datasheet for the LT32A01 (marked with NDA labels even if I have not signed anything with them), and an English datasheet of the LT8920.
I have found LT8920 on the ebay in small quantities:
www.ebay.com/itm/5PCS-X-LT8920-LT8920TSS...7:g:1F8AAOSwIWVY-a3M
My first Furibee seems to be lost on the long way from China, but I am expecting the next one to arrive this week. I will order some from these LT8920 and design some breakout board for them.
Stay tuned!
Last edit: 27 Jun 2017 07:46 by martonmiklos.
27 Jun 2017 07:45 #63166 by yets
Replied by yets on topic Furibee F36 protocol attempt
Fingers crossed! Thanks for not giving up
27 Jun 2017 15:32 - 27 Jun 2017 15:39 #63172 by wasp09
Replied by wasp09 on topic Furibee F36 protocol attempt
I have a F36. If you can find the pins that we can tap on, I would do the capture.
LT8920 Datasheet in Chinese:
www.wlxmall.com/images/stock_item/att/AT1698357.pdf
Last edit: 27 Jun 2017 15:39 by wasp09.
27 Jun 2017 18:03 #63176 by martonmiklos
Hi wasp09,
Unfortunately you cannot access the SPI physically because basically they have integrated the radio and MCU dies into one package.
The datasheet what you have linked is the same what I have attached in the previous post in English, just this is an older one and in Chinese.
I have "diffed" the LT8910 (which was tried by @goebish before) datasheet with the LT8920 and found the following differences:
** The register 32 [5:4] is marked as reserved in the LT8910 while in the LT8920 it could be used for the FEC mode. If I recall correctly goebish already played with these fields with an LT8910, and I have found some references to it in the following library: github.com/534659123/LT8910
So somehow this information has it's roots.
** The register 41 14th bit is SCRAMBLE_ON instead of reserved. It is interesting because there is a Scrambling data register in the LT8910.
** The register 45 is documented with some "best values" for separate data rates.
The most fun is the fact that the LT8920 datasheet you have linked marks the mentioned bits reserved too.
27 Jun 2017 19:21 #63179 by wasp09
I see.
LT8920 is supposed to be the improved version of LT8910.
Found a link to sample code but it may require membership and Chinese to download and browse:
en.pudn.com/downloads787/sourcecode/comm//detail3112239_en.html
27 Jun 2017 20:52 #63182 by martonmiklos
I have pudn account but the download links says invalid ID at both mirrors.
Anyway all necessary information is in the datasheet, and mainly seems to be compatible with the LT8910 where libraries already exists.
30 Jun 2017 14:48 #63220 by wasp09
Perhaps you can try asking the uploader:
s.pudn.com/upload_log_en.asp?e=3066051
30 Jun 2017 18:15 - 30 Jun 2017 18:52 #63225 by martonmiklos
I have commented about the issue because the private message sending seems to be broken there.
But anyway, I assume that is just an example code how to use the LT8920 with an STM8, which might reveal some things, but the most important things should be available from the datasheet attached before.
Last edit: 30 Jun 2017 18:52 by martonmiklos.
12 Jul 2017 19:52 - 12 Jul 2017 21:46 #63411 by martonmiklos
I am still waiting to my Furibee to arrive. My LT8910 and LT8920 SMD pack is on it's way too.
BTW I have found a nice LT8920 module on Amazon:
www.amazon.com/Icstation-Wireless-Transc...erface/dp/B01N7CY6TT
Unfortunately it does not ship to my country :(
Last edit: 12 Jul 2017 21:46 by martonmiklos.
12 Jul 2017 21:03 #63415 by martonmiklos
Ah it seems to be that the ebay is full of these XY-WA and XY-WB modules which seems to be populated with LT8920, for price ~1 USD.
I think I have also found above mentioned STM8 sources. I have added them to my NST pack in the case if anyone would be interested:
Time to create page: 1.318 seconds
