Flydream V3 Captures
22 Mar 2018 05:37 #68265 by vlad_vy
Replied by vlad_vy on topic Flydream V3 Captures
With devo7e protocol module size = 4 bytes.
22 Mar 2018 11:45 #68271 by hexfet
Replied by hexfet on topic Flydream V3 Captures
Thanks vlad. Fix from goebish is merged.
23 Mar 2018 20:22 #68315 by Fernandez
Replied by Fernandez on topic Flydream V3 Captures
Sorry to tell but flydream v3 does not work in the nightly builds, it doesn't matter which id used also id0 no bind.
Strange thing the led on receveir flashes fast indicating succefull bind, however at restart, the rx does not lock on, led stay off, no connection.......
23 Mar 2018 21:50 #68316 by hexfet
That's not good. Can you confirm the version string for the last version you tested working? And if it's not v5.0.0-840448c please try that version - just restored that test build directory. Thanks.
23 Mar 2018 23:17 #68318 by Fernandez
Yes can confirm latest test build 840448c works, latest nightly although FDV3 protocol is inside, it does not work.
24 Mar 2018 00:56 #68319 by hexfet
Please try the new test build (f8c709c). Found a problem with the change I made for windows emulator build.
24 Mar 2018 07:04 #68321 by Fernandez
I can confirm this test build f8c709c, binds and controls
25 Mar 2018 03:56 #68337 by hexfet
Thanks Fernandez. The fix will be in the next nightly.
07 May 2018 12:28 #69096 by Fernandez
I did some packs of flying with a foam delta wing and 4 channel flydream RX and did not have any controls problems, thanks hexfet!
20 Jul 2018 17:09 #69905 by planger
Replied by planger on topic Flydream V3 Captures
hexfet wrote: Thanks Fernandez. The fix will be in the next nightly.
Corona is broken in the current code.
Since you are not separating the packet build from the transmission in the latest code then you have to remove CORONA_CHANNEL_TIMING by either putting it to 0 or removing it completly.
- Pascal
30 Jul 2018 02:13 #69988 by hexfet
Thanks Pascal. I have pushed a fix for this problem.
Time to create page: 0.084 seconds
