EAchine E012
- goebish
- NRF Weirdo
28 May 2017 12:38 - 28 May 2017 12:44 #62635
by goebish
EAchine E012 was created by goebish
Hi there !
SeByDocKy has found that the new EAchine E012 Tx is using an HS6200 transceiver, I might be able to emulate it with the nrf24l01, only if the protocol is not using 500kbps bitrate.
Can someone make a dump of the SPI bus in the stock Tx so I can check that ?
Here's the pinout:
I need CE, CSN, SCK, MISO, MOSI and IRQ (GND = VSS)
If it's using 1Mbps or 2Mbps bitrate I should be able to add it to Deviation once I get one (I'll need one because captures over the air are necessary to reverse the scrambling).
Here's the pinout:
Last edit: 28 May 2017 12:44 by goebish.
- SeByDocKy
28 May 2017 13:27 #62637
by SeByDocKy
Replied by SeByDocKy on topic EAchine E012
Ok I will try to solder ..... I can't promise .... yet ...
- goebish
- NRF Weirdo
28 May 2017 13:28 #62638
by goebish
Replied by goebish on topic EAchine E012
As I said, don't ruin your Tx if you're not confident enough with the soldering job, nobody is in a hurry, right ?
- goebish
- NRF Weirdo
28 May 2017 13:32 #62639
by goebish
Note that if it's using 500kbps I might still be able to emulate it with the A7105, it will just take more time as I've less expertise with this transceiver than the nrf24l01.
- SeByDocKy
28 May 2017 15:20 #62640
by SeByDocKy
It''s Under process ... I think I done the hardest part ... but I don't want to cry victory now
- SeByDocKy
- goebish
- NRF Weirdo
28 May 2017 16:05 - 28 May 2017 16:11 #62642
by goebish
Seems clock & enable are wrong, maybe their wires are shorted with other pins somehow ?
Also, enable in Logic should be connected to CSN (Chip Select when Negative), not CE.
Last edit: 28 May 2017 16:11 by goebish.
- goebish
- NRF Weirdo
28 May 2017 16:08 - 28 May 2017 16:09 #62643
by goebish
if there are too many wires, capture only CSN, MOSI & CLK (+GND connected, of course, you can connect it to battery -), that should be enough for what I want to check.
Last edit: 28 May 2017 16:09 by goebish.
- SeByDocKy
- goebish
- NRF Weirdo
28 May 2017 16:29 #62645
by goebish
Clock seems almost Ok (but it's not), but csn is definitively wrong, you should see 1 negative pulse on CSN for 16 pulses on CLK.
Can you post a picture of your wiring ?
- goebish
- NRF Weirdo
28 May 2017 16:51 #62646
by goebish
Also, capture at 20 or 24 MHz as the max SPI clock rate for HS6200 is 10MHz.
- SeByDocKy
- goebish
- NRF Weirdo
28 May 2017 17:00 - 28 May 2017 17:17 #62649
by goebish
Well, don't spend too much time on that (and don't kill your Tx!) directly connect ground to battery - and try to keep the wires as short as possible as it seems it's using a rather high clock rate.... and the kind of wires you're using, wrapping wire, is far from being ideal for this job (you should get some stranded 30awg silicone wires such as
www.ebay.com/itm/1M-3-3ft-30AWG-Flexible...6color-/252562300800
I'll just order one
I'll just order one
Last edit: 28 May 2017 17:17 by goebish.
- SeByDocKy
28 May 2017 17:04 #62650
by SeByDocKy
Maybe my wires are too long ... coz I had to make a kind of double extension to solder these flucking duponts wires....
goebish wrote: Well, don't spend too much time on that (and don't kill your Tx!) directly connect ground to battery - and try to keep the wires as short as possible as it seems it's using a rather high clock rate.
I'll just order one
- SeByDocKy
28 May 2017 17:18 #62651
by SeByDocKy
Solved
the GND was guilty
- goebish
- NRF Weirdo
28 May 2017 17:27 - 28 May 2017 17:29 #62652
by goebish
Last edit: 28 May 2017 17:29 by goebish.
- SeByDocKy
- goebish
- NRF Weirdo
28 May 2017 17:50 - 28 May 2017 18:08 #62655
by goebish
Ok thanks,
0x26 0x40 = 1 Mbps bitrate, so it can be emulated with a nrf24l01.
I'll order one because dump over the air is required to capture and implement the whitening ...
Meanwhile I'll write a HS6200 decoding script ...
Last edit: 28 May 2017 18:08 by goebish.
- goebish
- NRF Weirdo
28 May 2017 18:23 #62656
by goebish
Ordered ... should take 2-3 weeks to arrive.
- goebish
- NRF Weirdo
28 May 2017 18:38 - 28 May 2017 18:39 #62657
by goebish
The protocol seems simple... data address & hopping frequencies are sent in clear text during bind, shouldn't be hard to implement, also I've already written some code to emulate the HS6200
some time ago
, I'm only missing a few scrambling bytes which I've to capture over the air.
Last edit: 28 May 2017 18:39 by goebish.
Time to create page: 0.318 seconds
- EAchine E012
