EAchine E012
28 May 2017 19:50 #62661 by SeByDocKy
Replied by SeByDocKy on topic EAchine E012
goebish wrote: The protocol seems simple... data address & hopping frequencies are sent in clear text during bind, shouldn't be hard to implement, also I've already written some code to emulate the HS6200 some time ago , I'm only missing a few scrambling bytes which I've to capture over the air.
Great :) so a future good news for any HS6200 other protocols if the scrambling is common
  • goebish
  • goebish's Avatar Topic Author
  • NRF Weirdo
28 May 2017 20:06 #62662 by goebish
Replied by goebish on topic EAchine E012
yes it should always be the same as we can't set an arbitrary scrambling seed.
  • goebish
  • NRF Weirdo
12 Jun 2017 12:15 - 12 Jun 2017 12:15 #62940 by goebish
Look at what I got in the mail this morning:
Ya plus qu'à ;)
Last edit: 12 Jun 2017 12:15 by goebish.
  • goebish
  • NRF Weirdo
12 Jun 2017 14:03 - 13 Jun 2017 11:56 #62942 by goebish
scrambling is defeated and the protocol is thoroughly understood, I "only" have to implement it now, expect a test build soon™.
raw packet: 55 55 3c 27 af 81 a0 ad bd 14 39 f3 e9 e0 fe e0 99 b3 59 7b fa
guard: 55 55
len: 15
pid: 0
no ack: 0
raw payload        : 4f 5f 03 41 5b 7a 28 73 e7 d3 c1 fd c1 33 66
unscrambled payload: cf aa 38 4c 36 50 d1 cf b6 5d 8d 00 00 56 b6
crc: b2 f7
raw packet: 55 55 3d 27 af 81 a0 ad bd 14 39 f3 e9 e0 fe e0 99 b3 79 4f 39
guard: 55 55
len: 15
pid: 1
no ack: 0
crc: f2 9e
raw packet: 55 55 3e 27 af 81 a0 ad bd 14 39 f3 e9 e0 fe e0 99 b3 19 12 fb
guard: 55 55
len: 15
pid: 2
no ack: 0
crc: 32 25
raw packet: 55 55 3f 27 af 81 a0 ad bd 14 39 f3 e9 e0 fe e0 99 b3 39 26 2b
guard: 55 55
len: 15
pid: 3
no ack: 0
crc: 72 4c
HS6200 rf frame: preamble (55/aa) | address (4-5 bytes) | guard (2 bytes, default = first byte of address) | PCF (6 bit payload length + 2 bit PID + 1 bit no_ack flag) | scrambled payload (0-32 bytes) | optional crc (1-2 bytes)
scramble (xor): 80 f5 3b 0d 6d 2a f9 bc 51 8e 4c fd c1 65 d0
crc: CRC16/CCITT-FALSE, LFSR fed with address in reverse order + PCF + scrambled payload
crc poly: 0x1021
crc init: 0xffff
crc xorout: none
bind:
address: 55 42 9C 8F C9
rf_ch: 3c
00 01 02 03 04 05 06 07 08 09 10 11 12 13 14
CF AA 38 4C 36 50 D1 CF B6 5D 8D 00 00 56 B6
00 address[1]
01 aa
02 rf_ch[0]
03 rf_ch[1]
04 rf_ch[2]
05 rf_ch[3]
06 address[0]
07 address[1]
08 address[2]
09 address[3]
10 address[4]
11 00
12 00
13 56
14 address[2]
data:
interval: 4525 us
address: sent during bind
rf channels: sent during bind
cf 01 64 64 64 00 aa 02 00 00 00 00 00 56 b6
00 address[1]
01   01
    |04 : right trigger (only if throttle > 0)
    |10 : left trigger
    |40 : flip
02 aileron 00 - c8
03 elevator 00 - c8
04 rudder 00 - c8
05 throttle 00 - c8
06 aa
07 02 high rate
08 00
09 00
10 00
11 00
12 00
13 56
14 address[2]
Last edit: 13 Jun 2017 11:56 by goebish.
12 Jun 2017 15:29 #62945 by SeByDocKy
Great !!!!! :)
Out of topic: I broke my E70 mini radio while soldering probes :( :( ... a short between two pads ... I can't remove :(
  • goebish
  • NRF Weirdo
12 Jun 2017 15:37 #62946 by goebish
Use a desoldering pump or desoldering braid, but depending of which pins were shorted it can be dead if you applied power ...
12 Jun 2017 15:39 #62947 by SeByDocKy
CLK & CSN .... if I am not wrong ... I tried with pomp ect ... I will retry one more time
  • goebish
  • NRF Weirdo
12 Jun 2017 15:45 #62948 by goebish
just add more leaded solder on the short, then it will be easier to remove ;)
  • goebish
  • NRF Weirdo
12 Jun 2017 15:50 #62949 by goebish
Also, set your soldering iron to 380°C or so if possible.
12 Jun 2017 16:05 #62950 by SeByDocKy
The problem the short is done at the perpendicular part between the daughter RF board and the main PCB :( Hard to collect at this corner :(
  • goebish
  • NRF Weirdo
12 Jun 2017 16:13 #62951 by goebish
Send it to me if you're really desperate, but shipping it forth and back might cost almost as much as ordering a new one ;)
  • goebish
  • NRF Weirdo
12 Jun 2017 16:29 #62952 by goebish
You should get one of those, that makes desoldering super easy:
www.amazon.fr/Pistolet-BK-858D-Station-S...amsung/dp/B013XBKE2Q
  • goebish
  • NRF Weirdo
13 Jun 2017 16:11 - 13 Jun 2017 19:30 #62970 by goebish
It works ...
*but* the hs6200 has a hard time decoding the packets sent by a nrf24l01 (that's the same the other way round), they're supposed to use the same center frequencies and gfsk deviation (±160 kHz at 1 Mbps), but I suppose they're using inaccurate crystal oscillators and loading capacitors (if any...).
To mitigate this issue I use only 1 frequency instead of 4 for frequency hopping, and as with other machines which have the same problem you've to set Tx Power to a lower value (eg 1mW30mW), expect some lag in control if you don't. As there's no way to set a frequency drift with the nrf24l01 I can't do anything better.
Source:
github.com/goebish/deviation/blob/protoc...ocol/e012_nrf24l01.c
Test builds:
www.dropbox.com/sh/8dd1hvli0qt7fw4/AABlW...kQJymHNNEfjViga?dl=0
New protocol: E012
Channel 5: flip
Channel 9: headless
Channel 10: RTH
Please report, check range if you can.
Last edit: 13 Jun 2017 19:30 by goebish.
13 Jun 2017 16:28 #62971 by SeByDocKy
goebish wrote: It works ...
To mitigate this issue I use only 1 frequency instead of 4 for frequency hopping, and as with other machines which have the same problem you've to set Tx Power to a lower value (eg 1mW), expect some lag in control if you don't. As there's no way to set a frequency drift with the nrf24l01 I can't do anything better.
Source:
Test builds:
New protocol: E012
Channel 5: flip
Channel 9: headless
Channel 10: RTH
13 Jun 2017 16:29 #62972 by SeByDocKy
Whaooohhhh good and bad news in the same time :( :( You tested with a 3-in-1 module or a genuine nRF23L01+ chip ?
  • goebish
  • NRF Weirdo
13 Jun 2017 16:31 #62973 by goebish
"Genuine" board, the one that works the best usually, I do not use a x-in-1 module.
13 Jun 2017 16:36 #62974 by SeByDocKy
The Devo7E is crashing just before to select the new protocol E12 .... :(
  • goebish
  • NRF Weirdo
13 Jun 2017 16:39 - 22 Jul 2017 16:16 #62975 by goebish
Oops, I made a mistake with the 7e build, as usual, I'll fix that ;)
Last edit: 22 Jul 2017 16:16 by goebish.
  • goebish
  • NRF Weirdo
13 Jun 2017 16:42 #62976 by goebish
It should be fixed, re-download from the same link.
  • goebish
  • NRF Weirdo
13 Jun 2017 18:16 #62977 by goebish
I uploaded new test builds to try to mitigate the HS6200 Rx issue:
- decrease packet interval, so the Rx has more chance to decode packets
- Tx power from 3mW to 150mW are the same for this protocol now, actually this is ~13dBm (20mW) if using the "simple" nrf24l01 module with its RFX2401C PA, it should be about the same transmit power than the stock transmitter.
Please test outdoor if you can, I can't right now.
Time to create page: 2.192 seconds
