Bayangtoys x16 new version (altitude hold)
- goebish
- NRF Weirdo
19 Oct 2017 20:03 #65136
by goebish
Replied by goebish on topic Bayangtoys x16 new version (altitude hold)
Ok, I'll take a look into that.
- goebish
- NRF Weirdo
19 Oct 2017 21:44 - 19 Oct 2017 21:51 #65137
by goebish
@cosmos, I added the X16_AH format to the Bayang protocol into the MM source code, here's my work branch:
github.com/goebish/DIY-Multiprotocol-TX-.../protocol_bayang_x16
diff only: github.com/goebish/DIY-Multiprotocol-TX-...3918c7c2fb4976a4b019
Of course you'll have to build and install it by yourself, I can't provide help, I don't have an iRangeX module but I checked that the code compiles fine.
Protocol: bayang
sub protocol ID: 2 (or 3, I'm not sure the index starts at 0).
Take off / Landing is AUX7 (channel 11)
Protocol: bayang
Last edit: 19 Oct 2017 21:51 by goebish.
- cosmos
19 Oct 2017 23:10 - 19 Oct 2017 23:14 #65139
by cosmos
Replied by cosmos on topic Bayangtoys x16 new version (altitude hold)
@goebish : Thank your help.
I will study and try import the protocol to my MM.
@Moeder : And thank also your effort.
Last edit: 19 Oct 2017 23:14 by cosmos.
- goebish
- NRF Weirdo
19 Oct 2017 23:16 - 19 Oct 2017 23:22 #65140
by goebish
If you've already flashed your own firmware to your module previously then it should be pretty straightforward.
Just something: I've a Taranis X9D + a STM32 module (not iRangeX though) and I've no idea how to set sub protocol to 2 in serial mode as I can only select the sub protocols that are already hardcoded into OpenTX (Bayang, H8S3D).
If you're using PPM mode then just select X16_AH as sub protocol in _Config.h
eg:
eg:
/*14*/ {MODE_BAYANG, X16_AH, 0, P_HIGH , NO_AUTOBIND, 0},
Last edit: 19 Oct 2017 23:22 by goebish.
- cosmos
20 Oct 2017 02:17 #65142
by cosmos
@goebish: Thank for your advice.
I will try edit header file and compile. If it will success, I try to import to my MM.
- cosmos
20 Oct 2017 05:03 #65143
by cosmos
@goebish:
1. Unfortunertly, I can't select "X16_AH" in sub_protocol.
The sub_protocol menu show "BAYANG" and "H8S3D". My TX is QX7.
2. And below editing is not work also.
3. In addition, I edit multiprotocol.h as below, that also not work in sub_protocol_menu.
enum BAYANG
BAYANG = 0,
X16_AH = 1, // edit by cosmos 20171020
H8S3D = 2,
Thank you.
enum BAYANG
BAYANG = 0,
H8S3D = 2,
Thank you.
- cosmos
20 Oct 2017 09:03 - 20 Oct 2017 09:04 #65146
by cosmos
@goebish:
It's good news. I success binding of X16 and QX7.
I edit your code as below.
filename : mutiprotocol.h
enum BAYANG
BAYANG = 0,
H8S3D = 2,
But still display "H8S3D" and chanel mapping is something wrong, so I try to set TARE/ARTE/....
I think that it need many try and error.
Thank your effort
enum BAYANG
BAYANG = 0,
H8S3D = 2,
Thank your effort
Last edit: 20 Oct 2017 09:04 by cosmos.
- goebish
- NRF Weirdo
20 Oct 2017 10:12 - 20 Oct 2017 10:48 #65147
by goebish
Great, I'll check with the OpenTX guys, I suppose there's a way for devs to test their protocols in serial mode.
Channel mapping should be as you set it in _Config.h (default=AETR), I didn't change anything here.
edit: asked on rcgroups
www.rcgroups.com/forums/showthread.php?2...page674#post38484765
Last edit: 20 Oct 2017 10:48 by goebish.
- cosmos
20 Oct 2017 11:00 #65149
by cosmos
@goebish:
I edit my QX7 chanel map. and it work very good(in situation : remove prop). the function takeoff/land key works good.
I will try to fly add prop's next Monday, and reply more contents here.
- goebish
- NRF Weirdo
20 Oct 2017 11:05 - 20 Oct 2017 11:06 #65150
by goebish
Ok, this is the first time I add a protocol to MM (I got a STM32 4-in-1 module only for that ...), I've to check what's the procedure to have it added into OpenTX.
Last edit: 20 Oct 2017 11:06 by goebish.
- goebish
- NRF Weirdo
20 Oct 2017 19:07 #65152
by goebish
@cosmos, Kilrah has replied:
So, select custom + ID 14 (MODE_BAYANG) + subID 2 (X16_AH).
OpenTX has "Custom" which lets you select both ID and subID by number.
- cosmos
20 Oct 2017 22:56 #65154
by cosmos
@goebish,
Thank you.
I understand and try this way.
Thank you.
- goebish
- NRF Weirdo
22 Oct 2017 11:00 #65192
by goebish
@Moeder, looks like the protocol is working fine:
www.deviationtx.com/forum/protocol-devel...297lbx-capture#65191
Can you make a pull request ?
I'm asking because I added yet another sub-protocol over X16 AH (IRDRONE) and I don't want to make a PR for your work
- Moeder
22 Oct 2017 15:00 #65202
by Moeder
Replied by Moeder on topic Bayangtoys x16 new version (altitude hold)
@goebish: First thing after returning from vacation was adding Arduino-based lighting to my son's RC boat
PR has been made, although I did it from only one set of captures, but since it is very similar to the original one I'm pretty sure it should be alright.
- goebish
- NRF Weirdo
22 Oct 2017 15:05 #65204
by goebish
Yes, seems that's fine, even if you missed some details that's not a big deal.
I'm working on 2 sub protocols that are pretty similar but not exactly the same (IRDRONE & VISUO).
- goebish
- NRF Weirdo
22 Oct 2017 15:09 #65205
by goebish
Ahah yesterday a friend of mine asked me if he could add lighting to his electric skateboard, 15 minutes later he was happy
Moeder wrote: @goebish: First thing after returning from vacation was adding Arduino-based lighting to my son's RC boat
- cosmos
23 Oct 2017 04:03 #65211
by cosmos
@goebish,
I test binding X16=QX7 by "custom + ID 14 (MODE_BAYANG) + subID 2 (X16_AH)" with your original protocol code.
It works well, but I can not test when adding prop on my X16.
Thank you.
Thank you.
- goebish
- NRF Weirdo
23 Oct 2017 11:20 #65216
by goebish
No problem, just tell me once you've tested with propellers on, I'll make a pull request to the MM repo then.
I don't know when (if?) it get merged though as it seems Pascal is taking a break from the project.
- Moeder
23 Oct 2017 14:56 #65219
by Moeder
Protocol is now available in nightlies and Vlads custom 5.0.0 build. Manual and supported model list in the wiki are updated accordingly.
- cosmos
24 Oct 2017 08:16 #65225
by cosmos
@goebish,
I test flying on prop by X16=QX7 binding.
It works well and move gentle.
Thanks for your support .
Time to create page: 0.710 seconds
- Bayangtoys x16 new version (altitude hold)
