VISUO XS809H-W-HD-G (Bayang X16 AH) capture
- Elric
22 Oct 2017 08:39 #65188
by Elric
VISUO XS809H-W-HD-G (Bayang X16 AH) capture was created by Elric
Capture 8MHz :
1drv.ms/u/s!AuNBpmXL1y0Rg8sNSfaqCRqGTLPG9w
VISUO_XM297LBX_1CSN_2SCK_3DATA_7VSS_8MHz_binding_start_motors_Land_Take-off.logicdata
CH11 : Land / Take-off not working with Bayang X16 AH.
Binding with Bayang X16 AH : ok
- goebish
- NRF Weirdo
22 Oct 2017 11:28 - 22 Oct 2017 11:35 #65194
by goebish
Replied by goebish on topic VISUO XS809H-W-HD-G (Bayang X16 AH) capture
I'm looking at that.
www.dropbox.com/s/jzqjpob3wzl0ymj/visuo_xs809H-W-HD-G.txt?dl=0
Last edit: 22 Oct 2017 11:35 by goebish.
- goebish
- NRF Weirdo
22 Oct 2017 11:46 #65195
by goebish
Can you better explain what you were doing during the capture ?
I can see an extra flag compared to the X16 AH, but I'm not sure when it's triggered.
Or just make another capture following this procedure exactly:
- tx off
- tx on / bind
- press take-off (only once)
- press landing (only once)
- press take-off twice in a row
- press landing twice in a row.
- tx off
- tx on / bind
- Elric
22 Oct 2017 14:17 - 22 Oct 2017 14:19 #65196
by Elric
Ooops !!! I do not have the same remote control as in the first message.
0. OFF
1. ON => the drone flashes very fast (I wait 3 to 5 seconds)
2. ARM => up an down => the remote control rings and the leds of the drone remain fixed in 1 at 2 seconds.
3. Start the engines with the STOP key.
4. take off with the Land - TakeOff key (the drone must climb to one meter from its position)
During my capture, there was no propeller. in step 4, I waited 3 to 4 seconds before pressing again TakeOff (4) then Stop (3).
I just finished flying tests with Bayang X16 AH that ended badly:
- CH11: ok it's an all-in-one channel: ignition of the engines and taking altitude at 50cm. the initial position down (-100): nothing happens. at the top (+100) engine start and takeoff. then maintain altitude. if crossing again down (-100): the drone goes down but it never cuts the engine!
All other functions are good (flips, headless, picture, video and return to home)
I lost an engine and / or the flight controller all in one => I'm down and it's my fault: I made a flip next to a tree (the drones do not like them trees
I just ordered two other flight controllers and four engines (delivery in 10 to 20 days from China)
Replied by Elric on topic VISUO XS809H-W-HD-G (Bayang X16 AH) capture
0. OFF
Last edit: 22 Oct 2017 14:19 by Elric.
- goebish
- NRF Weirdo
22 Oct 2017 14:22 #65197
by goebish
Ok, so this one requires separate channels for start/stop and take-off/landing, understood.
- goebish
- NRF Weirdo
22 Oct 2017 14:28 #65198
by goebish
After your crash, are you still able to test ? Should I make a test build now ?
- Elric
22 Oct 2017 14:31 - 22 Oct 2017 14:34 #65199
by Elric
Last edit: 22 Oct 2017 14:34 by Elric.
- goebish
- NRF Weirdo
22 Oct 2017 14:34 #65200
by goebish
No problem, just post again once you're ready
notes for myself: motors start/stop is emergency stop but it's using flag 0x08 instead of 0x04.
take-off / land flag is the same than X16 AH.
- manotroll
26 Apr 2018 22:59 #68874
by manotroll
Replied by manotroll on topic VISUO XS809H-W-HD-G (Bayang X16 AH) capture
I have this drone how do I capture protocols to help
- goebish
- NRF Weirdo
27 Apr 2018 08:04 #68880
by goebish
Perhaps I can already make a test build, which transmitter do you have ?
- manotroll
27 Apr 2018 15:13 #68889
by manotroll
Multiprotocol TX Module
www.banggood.com/2_4G-CC2500-A7105-Flysk...der&cur_warehouse=CN
Taranis X9D Plus
Taranis X9D Plus
- goebish
- NRF Weirdo
27 Apr 2018 15:30 #68890
by goebish
Elric, are you still following this thread ?
I'd prefer someone with Deviation to test first.
- manotroll
27 Apr 2018 19:53 #68893
by manotroll
Deviation what kind of transmitter would it be?
- goebish
- NRF Weirdo
27 Apr 2018 19:55 #68894
by goebish
Any compatible Walkera Devo transmitter + nrf24 module or Jumper T8SG / T8SG Plus.
- manotroll
27 Apr 2018 21:39 #68895
by manotroll
I only have the ones that I informed myself
the 4 in 1 module would not be enough?
- manotroll
03 May 2018 22:55 #69009
by manotroll
could you make the test file available?
- manotroll
16 May 2018 00:43 #69250
by manotroll
Bayang X16 AH
if you put both sticks diagonally inside the drone gun
- HaCo
08 Jun 2018 18:11 #69584
by HaCo
Replied by HaCo on topic VISUO XS809H-W-HD-G (Bayang X16 AH) capture
I ordered an XS809S and looking forward to have it delivered, I hope next week.
I have Deviation on a Devo 7e transmitter with NRF24L01 module. Would be awesome if I could use this Tx for my drone, so tell me how I can help please.
This is the drone I bought:
www.ebay.co.uk/itm/VISUO-XS809S-RC-Aircr...p2057872.m2749.l2649
- HaCo
09 Jun 2018 09:09 #69590
by HaCo
Ordered a logic analyser from Banggood in the mean time as well, so if I have to measure out something...
- saadasghar
31 Jul 2018 14:58 #70010
by saadasghar
Replied by saadasghar on topic VISUO XS809H-W-HD-G (Bayang X16 AH) capture
is it possible to flash H8 Mini acro fimrware? without any problem? because both have F130G6.
Time to create page: 0.814 seconds
- VISUO XS809H-W-HD-G (Bayang X16 AH) capture
