VISUO XS809H-W-HD-G (Bayang X16 AH) capture
22 Nov 2018 23:34 #71846 by manotroll
Replied by manotroll on topic VISUO XS809H-W-HD-G (Bayang X16 AH) capture
any news about development?
22 Nov 2018 23:37 #71847 by goebish
Replied by goebish on topic VISUO XS809H-W-HD-G (Bayang X16 AH) capture
No, but if you've one I can make a test build during the week-end ...
23 Nov 2018 00:17 #71848 by manotroll
I have the compatible transmitter.
could create the firmware to put in it?
more has to be 4 in 1 module
github.com/pascallanger/DIY-Multiprotocol-TX-Module
23 Nov 2018 00:18 #71849 by goebish
Don't you have a Deviation transmitter ?
If you only have a 4in1 maybe Pascal can do it ?
23 Nov 2018 06:22 #71850 by planger
Replied by planger on topic VISUO XS809H-W-HD-G (Bayang X16 AH) capture
I can do whatever but you have to brief me on what I need to do;)
23 Nov 2018 08:01 #71851 by goebish
If I'm not mistaken that's the same protocol than the Bayang / X16-AH but it requires a different flag for motor start/stop:
www.deviationtx.com/forum/protocol-devel...apture?start=0#65200
23 Nov 2018 08:51 #71853 by planger
I'm wondering if I could do something as simple as replacing:
BAYANG_FLAG_EMG_STOP = 0x04,
with
BAYANG_FLAG_EMG_STOP = 0x04|0x08, // 0x08 for VISUO XS809H-W-HD-G
23 Nov 2018 08:55 #71854 by goebish
That's worth a try, note that I might be wrong, I only had a quick look at the dump and that was more than one year ago.
23 Nov 2018 09:06 #71855 by planger
Multi v1.2.1.21 on github with the proposed flag addition.
Please test and report.
Pascal
23 Nov 2018 20:41 #71861 by manotroll
Could you put the link?
23 Nov 2018 21:34 - 23 Nov 2018 21:35 #71862 by planger
It's on my GitHub, update your module as usual.
Last edit: 23 Nov 2018 21:35 by planger.
23 Nov 2018 22:09 #71864 by manotroll
i.imgur.com/spgXrSX.jpg
using the Bayang X16 AH
something works
I did 2 videos recording alone, I'm going to see you +/-
now I'll test with your file to see
Can you pass me the link from your GitHub?
24 Nov 2018 00:39 #71867 by manotroll
I got these files here and replacing them did I do right?
github.com/pascallanger/DIY-Multiprotoco...9d5d6dd5bdb495dd2fb5
but it is not working correctly yet
I'm going to record a decent video tomorrow to demonstrate
24 Nov 2018 13:08 #71870 by planger
I don't understand what's not working from the videos...
I don't understand either when you say you replaced the files...
Pascal
24 Nov 2018 13:29 #71871 by manotroll
synchronized more tilted to the sides and broke a gear: \
now it will take time to get new ones in Brazil when I get back to report here
24 Nov 2018 18:16 #71873 by planger
I still don't understand what's wrong.... Thanks for not answering...
07 Jan 2019 02:05 #72221 by JayDrone
Replied by JayDrone on topic VISUO XS809H-W-HD-G (Bayang X16 AH) capture
no issues here - havnt tested via sd card but pritty sure camera still n video also controlable
07 Jan 2019 02:19 #72222 by JayDrone
BAM
07 Jan 2019 09:52 #72225 by goebish
Can you confirm that Pascal's patch is working ?
(add 0x08 to the emergency stop command).
07 Jan 2019 17:45 #72232 by HaCo
Could you please tell which file you used, and which module you need?
Time to create page: 0.315 seconds
