JJRC H8D (Protocol V202) missing fonctions
- Elric
24 Oct 2017 18:53 #65230
by Elric
TX chip:
Protocol:
V202 => Re-Bind Yes => 250kbps No
Tested functions :
CH1 : AIL : Simple : Reversed : ok
CH2 : ELE : Simple : Normal : ok
CH3 : THR : Simple : Normal : ok
CH4 : RUD : Simple : Reversed : ok
CH5 : AUX4 : Simple : Lights on (100) /off (other)
CH6 : Flip : does not work
CH7 : Pictures : ok
CH8 : Video : ok
CH9 : Headless : ok
CH10 : does not work
CH11 : does not work
CH12 : does not work
Return to home tested on channel 6, 10, 11 and 12: does not work.
How to wire the chip tx to capture the flip and return to home ?
JJRC H8D (Protocol V202) missing fonctions was created by Elric
TX chip:
Protocol:
Tested functions :
CH7 : Pictures : ok
CH8 : Video : ok
CH9 : Headless : ok
- goebish
- NRF Weirdo
24 Oct 2017 19:01 #65231
by goebish
Replied by goebish on topic JJRC H8D (Protocol V202) missing fonctions
Connect SI, SO, SCLK, CSN and of course GND.
- Elric
25 Oct 2017 20:20 #65265
by Elric
Replied by Elric on topic JJRC H8D (Protocol V202) missing fonctions
1drv.ms/u/s!AuNBpmXL1y0Rg8ti_39GH3SSHLn-TQ
Two 8MHz capture files : Flips and Return to Home.
OFF => ON => BINDING => FLIP FRONT => FLIP BEHIND => FLIP RIGHT => FLIP LEFT => FLIP FRONT => FLIP BEHIND => FLIP RIGHT => FLIP LEFT
OFF => ON => BINDING => ON RETURN TO HOME (bip bip bip... grrr) => OFF RETURN TO HOME
tell me if I have not made a mistake.
- goebish
- NRF Weirdo
25 Oct 2017 22:02 - 25 Oct 2017 22:23 #65268
by goebish
That's not fine, in both captures it looks like the transmitter is stuck in a bootloop (edit: no, that's the way it works ...), and there's also quite a bit of garbage.
Last edit: 25 Oct 2017 22:23 by goebish.
- goebish
- NRF Weirdo
25 Oct 2017 22:10 #65269
by goebish
Nevermind, I think I understand how it works anyway.
- goebish
- NRF Weirdo
25 Oct 2017 22:19 #65270
by goebish
Actually everything should already work with the V202 protocol, flip is the same flag than already implemented (packet[14], bit 2, channel 6), and RTH is just a scam, all it does is enabling headless (packet[10], bit 1, channel 9) and set elevator to bottom position while it's enabled
- Elric
25 Oct 2017 22:30 #65271
by Elric
1drv.ms/u/s!AuNBpmXL1y0Rg8tj7dJ5wvFqdTogwg
second capture with the throttle to half (disassembled propellers, I hear the engines change gears during flips and return to home)
- goebish
- NRF Weirdo
25 Oct 2017 22:37 #65272
by goebish
I confirm both functions (flip & headless) should work already.
Time to create page: 0.147 seconds
- JJRC H8D (Protocol V202) missing fonctions
