WFLY protocol
- planger
21 Aug 2018 16:07 #70371
by planger
WFLY protocol was created by planger
The WFLY protocol is now reversed.
It is available on github in the new Multi version 1.2.0.32: github.com/pascallanger/DIY-Multiprotoco...ol/WFLY_cyrf6936.ino
Details:
The WFLY protocol is using the CYRF6936 RF component.
No sub protocols.
4 to 9 channels can be transmitted based on config.
Extended limits are supported.
Receivers:
WFR04S, WFR07S, WFR09S (others?)
Tested ok on: WFR04S and WFR07S
Pascal
Details:
No sub protocols.
Receivers:
Pascal
- 52dgj
23 Aug 2018 14:49 #70409
by 52dgj
Replied by 52dgj on topic WFLY protocol
When can I increase the deviation?
- planger
30 Aug 2018 22:10 #70566
by planger
Replied by planger on topic WFLY protocol
No one to port this protocol to Deviation?
- goebish
- NRF Weirdo
- goebish
- NRF Weirdo
31 Aug 2018 08:20 #70574
by goebish
Replied by goebish on topic WFLY protocol
Almost done, Pascal, can you confirm that:
- rx_tx_addr[0:3] can be filled with arbitrary values
- stick data is 151-847 for 1000-2000 (can be extended)
I have to change a few stuffs in the callback then it should be fine.
- planger
31 Aug 2018 09:07 #70575
by planger
- Only rx_tx_addr[1..3] are used. From what I've seen they can be anything but I haven't tested all the possibilities just picked a few here and there to test...
- stick data 151-847 is for 100%, 500 is centered. I've tested 125% (max that multi takes) with no issues.
Pascal
Pascal
- goebish
- NRF Weirdo
31 Aug 2018 10:31 #70578
by goebish
Thanks, 151-847 range makes the center 499, probably not a big deal ...
Here are a few test builds:
www.dropbox.com/sh/aocbgjqa8esd0p9/AABxd...WtWwZSFhiAa5Cxa?dl=0
New protocol: WFLY
source:
github.com/goebish/deviation/blob/protoc...ocol/wfly_cyrf6936.c
52dgj, can you check if it works please ?
(let me know if you need a build for a different transmitter)
New protocol: WFLY
source:
- planger
31 Aug 2018 13:22 #70587
by planger
Pascal
Yeah I know it gives 499.5. I haven't bothered rounding it... When you see the jitter the TX module has when reading the PPM input signal, anything is better anyway...goebish wrote: Thanks, 151-847 range makes the center 499, probably not a big deal ...
Pascal
- planger
31 Aug 2018 13:47 #70588
by planger
1. power setting:
//Keep transmit power in sync
if(tx_power != Model.tx_power) {
tx_power = Model.tx_power;
CYRF_WriteRegister(CYRF_03_TX_CFG, 0x08 | tx_power); // 8DR Mode, 32 chip codes
but a few lines later you have:
CYRF_SetPower(0x08);
which sets power to 0.
I recommend to do: CYRF_SetPower(tx_power); in the Keep transmit power in sync instead of the CYRF_WriteRegister(CYRF_03_TX_CFG... and remove the other line.
2.On the original TX, the start channel is changing at every power up. If I'm not mistaken, here you are always forcing it to the same value. It's not a big deal but that's how it works...
//Random start channel
u8 ch=0x0A+lfsr%0x0E;
if(ch%3==0)
ch++;
Pascal
I've noticed 2 things:goebish wrote: source: github.com/goebish/deviation/blob/protoc...ocol/wfly_cyrf6936.c
1. power setting:
if(ch%3==0)
ch++;
Pascal
- goebish
- NRF Weirdo
31 Aug 2018 14:59 #70591
by goebish
Thanks for the review, fixed and test builds updated.
- 52dgj
05 Sep 2018 03:33 #70653
by 52dgj
hello,I successfully bind WFLY, but I found the distance to be very close,version:31803f0
- goebish
- NRF Weirdo
05 Sep 2018 07:02 #70657
by goebish
please try updated version (1aeac1d)
- 52dgj
05 Sep 2018 12:21 #70659
by 52dgj
Thank you very much, it is much better.
- goebish
- NRF Weirdo
05 Sep 2018 14:56 #70661
by goebish
Ok, it should be available in the nightly builds soon then
- planger
05 Sep 2018 15:12 #70662
by planger
Something I should port back?
- goebish
- NRF Weirdo
05 Sep 2018 15:13 - 05 Sep 2018 19:32 #70663
by goebish
No, that's almost a copy/paste of your code.
github.com/DeviationTX/deviation/pull/435
Last edit: 05 Sep 2018 19:32 by goebish.
- Nimo2019
19 Mar 2020 09:38 #76079
by Nimo2019
Replied by Nimo2019 on topic WFLY protocol
hi, I have a T8SG V2 plus and WFLY wfr06s receiver
deviation-t8sg_v2_plus-v5.0.0-28ce50f version binding is ok but after longtime used i lost connection:silly:
but all version after that i have binding trouble , sometimes bind and disconnect for short time then lost binding , I see sometimes my wifi not working , I am not sure but is it interference ? why the first version no problem for binding / interference ?
could someone guide me or help me please
thanks
thanks
19 Mar 2020 10:22 #76080
Replied by vlad_vy on topic WFLY protocol
Try "Freq-Fine" protocol option.
- Nimo2019
19 Mar 2020 13:13 #76081
by Nimo2019
thanks, freq-fine value from -1000 to 1000
what mean ? and what best value ?
19 Mar 2020 13:18 #76082
If you can bind, change value up and down up to lost connection, then calculate and set the middle value. Middle = (Down + Up) / 2
Time to create page: 0.208 seconds
- WFLY protocol
