C-17 Transport
- goebish
- NRF Weirdo
03 Jul 2019 17:24 #74667
by goebish
Replied by goebish on topic C-17 Transport
I don't understand, do you need a channel to set low rate mode because it doesn't work the same on V1 & ZC ?
- planger
03 Jul 2019 17:24 - 03 Jul 2019 17:31 #74668
by planger
Replied by planger on topic C-17 Transport
I see what you mean but can you make sure first it's not your badly calibrated sticks that creates what you are seeing.
Last edit: 03 Jul 2019 17:31 by planger.
- planger
03 Jul 2019 17:29 #74669
by planger
The ZC has a separated motor for propulsion that the GD does not have so rate could play a role on the speed of the main motor. But first he needs to calibrate the sticks to rule that out from the equation.goebish wrote: I don't understand, do you need a channel to set low rate mode because it doesn't work the same on V1 & ZC ?
- tianma780
03 Jul 2019 17:30 #74670
by tianma780
Replied by tianma780 on topic C-17 Transport
no ,I mean
when the throttle -100,
the aileron -1 or 1 the motor go not so fast! now is too fast
- planger
03 Jul 2019 17:33 #74672
by planger
This is the behavior of the model. If throttle is -100 and you turn the ailerons both motors go to high speed. The original remote is doing the same.tianma780 wrote: no ,I mean
- tianma780
03 Jul 2019 17:38 #74673
by tianma780
yes ,can you tell me how to change the code to put it down,I think it is hard to landing but good to role!
- tianma780
03 Jul 2019 17:40 #74674
by tianma780
Hello goebish and Pascal,can you check the code of V2,
the Throttle from -99 to -66 the motor speed not change.
- tianma780
09 Aug 2020 15:07 - 09 Aug 2020 15:09 #76664
by tianma780
Hello gobish and planger
Can you tell me how to change the code
So when the throttle is -100 and I turn the ailerons both motors do nothing (dont go to high speed,it is hard to land)
Thank you!
Thank you!
Last edit: 09 Aug 2020 15:09 by tianma780.
- gke
03 Mar 2023 08:29 #78232
by gke
Replied by gke on topic C-17 Transport
Very quick question. Did GD00X V1&V2 make it into the T8SGV2Plus builds? Thanks
- goebish
- NRF Weirdo
03 Mar 2023 09:10 #78233
by goebish
Hi gke, long time no see!
I had a quick look at the source code, looks like V2 has never made its way onto Deviation, shouldn't be hard to port from MPM tho.
- gke
03 Mar 2023 10:39 - 03 Mar 2023 10:41 #78234
by gke
Thanks goebish - yep still "alive and kicking" here. I will grab the latest source and adapt the MPM code I get Docker running with a local copy. I need to add an A120 V2 variant to MT9xxx or whatever as well. One of my mates has an ancient Jumper and would like to try that before just buying something sensible. Like many I am running MPM along with EdgeTx.
Last edit: 03 Mar 2023 10:41 by gke.
- gke
05 Mar 2023 21:47 #78235
by gke
Replied by gke on topic C-17 Transport (Rant)
Off topic mini rant.
I installed Docker etc and did a partial port of the GD00xx GD_V2 code from MPM - there has been a big change in coding style.
Deviation is an important step to where we are now but I have decided that the T8SG is pretty much dead. As for Docker it is just part of the continuing Tower of Babel tendency - entropy! Fortunately MPM elected to go with the contained chaos of Arduino where you can grab a local clone make some changes and you are done.
I have convinced my friend to go with MPM and probably a Tx16S or similar.
Time to create page: 0.212 seconds
- C-17 Transport
