FHSS
22 Dec 2018 17:40 #72100 by thyng@att,net
FHSS was created by thyng@att,net
Has anybody developed a protocol for the Futaba FHSS mode. the S-FHSS that comes with the 8G will not work with an FHSS only receiver.
09 Jan 2019 23:09 #72260 by Fer
Replied by Fer on topic FHSS
As far as i know no... I too have a few RTF planes using the FHSS protocol, and i would very much be interested, but if i remember correctly in another discusion, the FHSS protocol is considered to be too old, and with low channel count (only up to four i think), and it is not worth researching. Still, i would love to fly those planes with the advanced features the Deviation provides... Maybe one day...
09 Jan 2019 23:52 #72261 by goebish
Replied by goebish on topic FHSS
It's not that it's not worth researching, just that no developer has a FHSS transmitter in his hands, and nobody has posted SPI dumps of a FHSS transmitter either.
16 Jan 2019 17:32 #72342 by Alf-1234
Replied by Alf-1234 on topic FHSS
Ich habe hier ebenfalls das Problem.
Ich habe hier einen kleinen Hubi mit FHSS Protokoll stehen.
Den würde ich auch gerne mit meinem Jumper T8SG binden. Leider klappt das nicht mit dem SFHSS Protokoll welches im T8 Sender ist.
Es wäre schön, wenn sich einer dieses Problems annehmen würde.
Ich wäre euch sehr dankbar.
I also have the problem here.
I have a small Hubi with FHSS protocol here.
I would also like to tie with my Jumper T8SG. Unfortunately, this does not work with the SFHSS protocol which is in the T8 transmitter.
It would be nice if someone would take care of this problem.
I would be very thankful.
17 Jan 2019 09:00 #72355 by planger
Replied by planger on topic FHSS
You need either to dump yourself the SPI bus and help testing, or send your TX & RX to one of us so we can work on it.
17 Jan 2019 11:13 #72358 by Alf-1234
Ich danke Ihnen für die Antwort, auch wenn mir das im Moment nicht weiter hilft.
Der Hubschrauber ist der Carson Zermatt ein Koax Hubi der nicht mehr im Programm ist.
Zum Verschicken ist der mir etwas zu gross. Der Empfänger der da drin ist, ist ein 4 in 1 Empfänger.
Thank you for the answer, even if that does not help me at the moment.
The helicopter is the Carson Zermatt a Koax Hubi is no longer in the program.
To send me something is too big. The receiver in there is a 4 in 1 receiver.
17 Jan 2019 11:19 #72359 by goebish
If you don't want to send a TX+RX (Pascal & I are located in France, not too far away from your place ;)) you can help by dumping the SPI bus in the transmitter:
www.deviationtx.com/forum/protocol-devel...95-spi-capture-guide
17 Jan 2019 11:29 #72360 by Alf-1234
Ich bin jetzt leider nicht der Elektronik Fachmann.
Und wie lade ich den SPI Bus in den Sender??
Wo bekomme ich den SPI Bus her?
Unfortunately, I'm not the electronics specialist right now.
And how do I load the SPI bus into the transmitter ??
Where can I get the SPI bus?
17 Jan 2019 11:32 #72361 by goebish
That is explained in the video in the topic I linked, You only need a 5€ logic analyzer then solder a few wires into the transmitter.
17 Jan 2019 11:36 #72362 by goebish
Can you take a picture of the inside of your transmitter, so I can tell you if and how it can be done ?
17 Jan 2019 14:20 #72363 by Alf-1234
Ich soll also meinen Sender Jumper T8SG aufschrauben und dann von der Rückseite der Platine ein Foto machen und hier hochladen.
Habe ich das richtig verstanden??
So I'm going to screw on my transmitter Jumper T8SG and then take a picture from the back of the board and upload it here.
Have I understood that correctly??
17 Jan 2019 14:28 #72364 by goebish
No, the inside of the FHSS transmitter.
17 Jan 2019 14:43 #72366 by Alf-1234
Der Sender T8SG ist ein Open Scource Sender der über 40 versch. Funkprotokolle kann. Und eines von diesen Funkprotokollen die ich da einstellen kann ist S-FHSS.
Welchen Logik Analyser soll man sich denn kaufen. Was soll der alles können?
Welchen würden Sie mir empfehlen?
The transmitter T8SG is an open source sender of more than 40 different radio protocols. And one of those radio protocols that I can adjust is S-FHSS.
Which logic analyzer should one buy? What should he do?
Which one would you recommend to me?
17 Jan 2019 14:46 - 17 Jan 2019 14:50 #72367 by goebish
I know what a T8SG is and I do not need any picture of it ;)
I need a picture of the inside of your original FHSS controller.
For an analyzer, just go to ebay and search for "8ch logic analyzer", it should cost about 5€ ...
Last edit: 17 Jan 2019 14:50 by goebish.
17 Jan 2019 14:55 #72369 by Moeder
Replied by Moeder on topic FHSS
Where in Germany are you located? You need to open up the transmitter which came with the helicopter and show us pictures from the inside, NOT the Jumper.
17 Jan 2019 15:01 #72370 by goebish
Moeder, if you speak German please tell him what I'm trying to say, I'm sorry but I don't understand a single word of German and I think he has the same issue with English ;)
17 Jan 2019 15:06 #72371 by planger
I'm also worried that this protocol discussion has started with Futaba FHSS and he is talking about something else since FHSS is usually written on a lot of different systems...
17 Jan 2019 21:59 #72379 by Alf-1234
Sorry, mein Fehler
Wir reden hier von Futaba FHSS.
Ich habe hier einen Carson FHSS und das ist scheinbar wohl nicht dasselbe wie Futaba.
Nach so einem Logik Analyzer werde ich schauen.
Sorry, my mistake
We are talking about Futaba FHSS here.
I have a Carson FHSS here and that does not seem to be the same as Futaba.
I'll look for such a logic analyzer.
17 Jan 2019 22:03 #72380 by goebish
Even if it's Carson branded perhaps it's using the Futuba FHSS protocol, we've already seen Carson stuffs using the AFHDS-2 protocol.
17 Jan 2019 22:11 #72381 by Alf-1234
Danke für die Info.
Ich werde das morgen mal mit dem AFHDS-2 Protokol und meinem Cason Modell testen.
Werde morgen berichten.
Thanks for the information.
I will test it tomorrow with the AFHDS-2 protocol and my Cason model.
Will report tomorrow.
Time to create page: 0.197 seconds
