ESKY 150 V2
- captjack01
04 Jan 2019 22:28 #72204
by captjack01
ESKY 150 V2 was created by captjack01
Will deviation work with ESKY 150 V2 or will it require a different protocol? I tried the 2 available esky ones in 5.0 but no luck. What other protocol and module?
05 Jan 2019 00:37 #72205
Replied by hexfet on topic ESKY 150 V2
From the pic of the transmitter it says "compatible with Gwy ahss" on the label. Not a protocol I'm familiar with.
If you can get a pic of the label on the radio chip on the receiver or transmitter we can see if it's a supported type.
See this thread for the information needed to reverse-engineer the protocol.
If it has an FCC ID number might be able to get a little more info from the FCC website.
- captjack01
06 Jan 2019 22:11 - 06 Jan 2019 22:13 #72219
by captjack01
Replied by captjack01 on topic ESKY 150 V2
Actually its a blade 70s tx and has fhss transmitter on front. Supposedly its a rebranded esky 150 v2. Go figure. Is FHSS compatible with S-FHSS ?
FCCID:2ANYZ-ESKY007324 IC:23279-BLH4217 these are numbers on back of tx.
Thank you
tried sending pics but wouldn't go through.
Thank you
Attachment not found
Last edit: 06 Jan 2019 22:13 by captjack01.
- Gerhard_H
19 Jan 2019 18:46 #72420
by Gerhard_H
Therefore no chance . . .
Replied by Gerhard_H on topic ESKY 150 V2
The transmitter of the mentioned Esky heli has a chip inside which isn't part of neither Deviation nor 4in1 unit. It's a N51822.captjack01 wrote: Will deviation work with ESKY 150 V2 or will it require a different protocol?
- planger
08 May 2020 17:57 #76278
by planger
Replied by planger on topic ESKY 150 V2
This protocol has now been reversed. I've used the CC2500 to emulate the N51822.
The code is available here: github.com/pascallanger/DIY-Multiprotoco...ESky150v2_cc2500.ino
Pascal
Pascal
- fin
15 Jul 2020 13:06 #76590
by fin
Replied by fin on topic ESKY 150 V2
I am always grateful to Pascal. Thank you.
Will this Esky150V2 protocol ever be included in Nightly Build?
I also use OpenTx, but I'm an avid Deviation fan.
- LittleBird
12 Aug 2020 07:04 - 12 Aug 2020 07:07 #76676
by LittleBird
Hello Pascal,
I build the latest Multiprotocol with arduino 1.85 and burn to the STM32 module successful. My Tx is Taranis X9D+ with OpenTX 2.2. When I loaded the Lua, it warning "No multi module is configured". And I could not select the ESKY150V2 protocol from the "Model setup - External RF - Mode". From the selection list, it has esky and esky150, but no esky150v2.
Then I tried the precomplied FW "multi-stm-opentx-taer-inv-v1.3.1.49.bin" from the github site and the problem still remain.
I searched on google and tried many many time these two days and could not solve my problem.
Could you kindly please give me an advice?
Thank you in advance!
LittleBird
Replied by LittleBird on topic ESKY 150 V2
planger wrote: This protocol has now been reversed. I've used the CC2500 to emulate the N51822.
Pascal
Hello Pascal,
LittleBird
Last edit: 12 Aug 2020 07:07 by LittleBird.
- Lumaflap
06 Jun 2021 00:00 #77421
by Lumaflap
Replied by Lumaflap on topic ESKY 150 V2
Hi Everyone,
Is there any chance that the Esky 150 V2 protocol will be added some day ? It seems that planger has reversed the protocol to make it work on Deviation. It would be great, the rtf radio with the 150v2 is pure crap with an incredible deadzone and these little helis requires precision in order to fly well !
Thank you in advance !
Time to create page: 0.713 seconds
- ESKY 150 V2
