TDR Phoenix Mini (Eachine E010 clone?)
- goebish
- NRF Weirdo
25 Mar 2019 16:41 #73550
by goebish
Replied by goebish on topic TDR Phoenix Mini (Eachine E010 clone?)
Start with low rate (should be the default), then mid, then high, then stop capture.
- Joms
25 Mar 2019 17:48 #73551
by Joms
Replied by Joms on topic TDR Phoenix Mini (Eachine E010 clone?)
OK, but to clarify, when you say "rate" you mean the motor speed, right? On this controller, that's pressing in on the right stick.
I'll get this to you soon as I can today.
- goebish
- NRF Weirdo
25 Mar 2019 17:50 - 25 Mar 2019 17:51 #73552
by goebish
That's it, it's usually called "beginner", "intermediate" and "expert" modes in the manual, only the fastest mode is implemented in Deviation.
Last edit: 25 Mar 2019 17:51 by goebish.
- Joms
26 Mar 2019 03:31 #73559
by Joms
Welp, looks like I just broke the quad, now it won't connect to either the T8SG or its original controller. I'll try to revive it as best I can.
- Joms
28 Mar 2019 01:25 #73576
by Joms
I got it, capture starts bound already, at low rate, then mid, then high, and back to low.
mega.nz/#!fQgG1YyS!fxdeV6CuiIxfsuxu38bpQvC8Wws88iO1HJhHswLgpnc
- goebish
- NRF Weirdo
28 Mar 2019 07:46 - 28 Mar 2019 09:27 #73580
by goebish
Seems there's no CLK in this capture.
(but a "ghost" of the Data channel instead)
Last edit: 28 Mar 2019 09:27 by goebish.
- Joms
29 Mar 2019 04:28 #73590
by Joms
I reran the capture, channel 0 and 1 still seems a bit close but definitely different.
Here's the reran capture: mega.nz/#!qVxn3QbC!BkN0ZkAXp-hKIYp_0r3s2hGi8yT2pUQWc0LflSvZd50
- goebish
- NRF Weirdo
29 Mar 2019 07:54 - 29 Mar 2019 09:34 #73595
by goebish
Last edit: 29 Mar 2019 09:34 by goebish.
- goebish
- NRF Weirdo
29 Mar 2019 12:03 #73598
by goebish
Are you sure GND is connected properly ?
- Joms
30 Mar 2019 14:52 #73616
by Joms
Had to resolder, hopefully this one makes the cut...
mega.nz/#!CcJHkKiB!yMcu-Vrntf0Fau5t5gr8WlQHXzGbSV4aTHLOrRXYzuc
- goebish
- NRF Weirdo
30 Mar 2019 15:12 #73617
by goebish
Yes, this one is fine, thanks
- goebish
- NRF Weirdo
16 Apr 2019 12:43 #73918
by goebish
Hold on, I'm now able to use the cc2500 instead of the nrf24l01 for xn297@250kbps, I believe that should fix this issue, I'll give you a test build soon.
Joms wrote: Wow, it's finally started to work! It would only bind when TX power is set to 1mW only, and would not connect in any other power. It would not maintain a stable bind as well, and when armed, the motors would spin and turn off when connection is lost and automatically spin when connection comes back. Arm on channel 5 definitely working now!
- goebish
- NRF Weirdo
16 Apr 2019 14:12 #73919
by goebish
Please try this build:
www.dropbox.com/sh/7k5f9f62ifucnd7/AACN4...pU_AMWWIKzdXOTa?dl=0
It has an E010 protocol with E010 and Phoenix sub-formats.
- Joms
16 Apr 2019 14:51 #73921
by Joms
Sweet, I'll try this tonight!
16 Apr 2019 22:59 #73942
Replied by hexfet on topic TDR Phoenix Mini (Eachine E010 clone?)
Yay! My E010 that was gathering dust seems to be working well. More testing after battery charging.
Very nice work goebish
- Joms
18 Apr 2019 01:12 #73977
by Joms
It connects flawlessly no matter what power setting I choose now, arming works as well. Just need to calibrate controls and throttle--which apparently idles at maybe 25% power on arm, and moving throttle past mid sets it to 100% power. I'll check with the mixer if it tames it.
Thanks for this build!
- goebish
- NRF Weirdo
18 Apr 2019 06:54 - 18 Apr 2019 08:43 #73983
by goebish
Nice, seems the XN297L emulation with CC2500 is working 100% according to the reports !
Phoenix protocol is supposed to work properly with default settings (new model).
If you're sure your sticks are calibrated properly then maybe this quad has different throttle scaling than E010, I'd need a capture in which you set throttle from low to high position to check that.
If it has altitude hold I suppose it has a spring centered throttle stick ?
Last edit: 18 Apr 2019 08:43 by goebish.
Time to create page: 0.686 seconds
- TDR Phoenix Mini (Eachine E010 clone?)
