JJrc345 drones as gift in return for protocol.
- Cdog31
12 Apr 2019 07:59 #73830
by Cdog31
Replied by Cdog31 on topic JJrc345 drones as gift in return for protocol.
- Moeder
12 Apr 2019 08:03 - 12 Apr 2019 08:04 #73831
by Moeder
Replied by Moeder on topic JJrc345 drones as gift in return for protocol.
Which channels have valid data? 71,73, any other ones? Also, when in bound mode without any stick movements, do any of the packets permanently change? We'll look at the data and get back at you. Thank you for staying up late for us, there is already lot's of thing for us to see
Last edit: 12 Apr 2019 08:04 by Moeder.
- Cdog31
12 Apr 2019 08:58 #73834
by Cdog31
The channel that displays almost every time at the point of binding is 71. I saw a 73 only a few times out of many. And I saw 72 one time. The packets on 71 are the same every time it lands on 71 and they don't change from there. I don't know if that helps. But I will redo any step that you request. And by the way I stay up this late more often than I should anyway. Night owl all the way. May I ask what country you are in. I'm just curious. this is the most fascinating and technical thing I have ever done with deviationtx by the way and I thank you so much. Please let me know how I can help the most. Chris
- Moeder
12 Apr 2019 09:19 - 12 Apr 2019 09:27 #73836
by Moeder
once bound and finishing the first scan, press ENT again to continue scanning. The TX should then stop on the next valid channel. you can repeat this any time you like. But from your bind information it is likely that only channels 71 and 73 are used. Also, could you rerun the interval test once for every valid channel please? To do so, set get intel in protocol options to 20, then go to the channel before the one used (70), then start scanning (it will stop on 71 and measure intervals. Then do the same for 73 and any other channel you think is used. Goebish is working on a first implementation for deviation already.
edit: also we now need to see which packets are affected by buttons. Check if any of the buttons (I don't know the features of your drone) has an effect on any packets. Note that you pushing activating two functions on the tx may have a combined effect on a single packet (for your information: each button may set a so called flag, and a couple of flags can be carried in a single packet).
edit 2: one more thing: also check how packets are affected by pressing the trim buttons.
Last edit: 12 Apr 2019 09:27 by Moeder. Reason: flags
- goebish
- NRF Weirdo
12 Apr 2019 09:21 #73837
by goebish
Replied by goebish on topic JJrc345 drones as gift in return for protocol.
I think 63 might be used as well, can you check if you get valid CRC when it's selected ?
- Cdog31
12 Apr 2019 09:49 #73838
by Cdog31
- Cdog31
12 Apr 2019 09:51 #73839
by Cdog31
- Cdog31
12 Apr 2019 09:55 #73840
by Cdog31
- Cdog31
12 Apr 2019 09:56 #73841
by Cdog31
And finally yes the trim buttons do have an effect on the third line of packets with each click. Do you need me to photograph the effect from clicking trim buttons. And how many times in each direction would you like. You guys are awesome. I hope I'm doing a good job and accommodating your requests. Chris
- Cdog31
12 Apr 2019 10:00 #73842
by Cdog31
- Moeder
12 Apr 2019 10:01 - 12 Apr 2019 10:15 #73843
by Moeder
Yes you are doing a great job. Just tell us which trim button affects which packt and what the minimum and maximum values are, that should be sufficient.
edit: we are also still missing throttle stick, you didn't record that yet. We are getting very close.
Last edit: 12 Apr 2019 10:15 by Moeder.
- goebish
- NRF Weirdo
12 Apr 2019 10:17 #73844
by goebish
Just to make sure, when you're on Ch 63 (without scanning), does it show "invalid CRC" ?
- Cdog31
12 Apr 2019 10:27 #73845
by Cdog31
- Cdog31
12 Apr 2019 10:29 #73846
by Cdog31
My friends the sun is coming up over my North Carolina Beach town. I am in desperate need of coffee and will need to take a break. I appreciate how hard you are working on figuring this out. I will be back soon to check for further messages from you. Thank you. Chris
- Cdog31
12 Apr 2019 10:35 #73847
by Cdog31
- Cdog31
12 Apr 2019 10:36 #73848
by Cdog31
I will be back soon to see if there is progress and how I can help. My brain hurts now. Haha
- goebish
- NRF Weirdo
12 Apr 2019 11:22 #73850
by goebish
I'll soon have a test build for you
- Cdog31
12 Apr 2019 11:26 - 12 Apr 2019 11:28 #73851
by Cdog31
I'm looking forward to your creation. I must work today at 9 a.m. but will surely be in touch when I return home. Thank You. Merci beaucoup. Chris
Last edit: 12 Apr 2019 11:28 by Cdog31.
- goebish
- NRF Weirdo
12 Apr 2019 11:44 - 12 Apr 2019 13:53 #73853
by goebish
Test build for Devo 7e:
www.dropbox.com/sh/eo6r2goddsomod1/AACJc...9Ok39dS2TpAFmHa?dl=0
Protocol: JJRC345
If it works but there's some latency in the controls, try to play with the "Period" protocol option, it can be set in realtime, no need to rebind.
source:
github.com/DeviationTX/deviation/pull/853/files
(not sure throttle scaling is fine, you haven't posted a dump with full throttle)
Protocol: JJRC345
source:
Last edit: 12 Apr 2019 13:53 by goebish.
- Cdog31
12 Apr 2019 14:30 #73855
by Cdog31
You are correct I completely forgot to relay full throttle information. When I get home today I will gladly do that. Will you then incorporate it into the test build. Thank you for all of your effort. I admire the tech skills that you have. Chris
Time to create page: 1.485 seconds
- JJrc345 drones as gift in return for protocol.
