JJrc345 drones as gift in return for protocol.
- Cdog31
12 Apr 2019 22:01 #73863
by Cdog31
Replied by Cdog31 on topic JJrc345 drones as gift in return for protocol.
- goebish
- NRF Weirdo
12 Apr 2019 22:04 - 13 Apr 2019 11:02 #73864
by goebish
Replied by goebish on topic JJrc345 drones as gift in return for protocol.
Ok, try my build, it should be fine.
There's something weird tho, can you tell when does the byte to the left of FF in the full throttle capture switch from 0A to 0E ?
(first number of the 2nd line) or maybe that's just a glitch of the picture due to slow lcd refresh rate.
Last edit: 13 Apr 2019 11:02 by goebish.
- goebish
- NRF Weirdo
12 Apr 2019 22:08 #73865
by goebish
note that xn297 dump isn't included in my build (modular)
- Moeder
13 Apr 2019 05:55 #73868
by Moeder
Replied by Moeder on topic JJrc345 drones as gift in return for protocol.
While you are dumping again, you might as well check the other buttons for us. According to jjrc ads the drone features return to home, headless, lights flip and one button start and landing. All those features should be captured for us.
- Cdog31
13 Apr 2019 07:04 #73869
by Cdog31
I will be happy to check the other buttons for you send the dumps soon. this drone has all of the buttons you mentioned except for the one button takeoff landing and LED control feature. It is a mistake in the advertisement. It does have headless, return to home, and the flip. I haven't had a chance to even try your test build because I just came home from work at 2 a.m. but I am excited to try I will do it shortly and also send the info on remaining buttons. Thank you for your help. Chris
- Cdog31
16 Apr 2019 21:15 #73929
by Cdog31
This evening I will capture pictures of the remaining buttons. So that it is complete. I thank you for your patience and your time. Chris
- Cdog31
16 Apr 2019 22:06 - 16 Apr 2019 22:08 #73930
by Cdog31
Last edit: 16 Apr 2019 22:08 by Cdog31.
- goebish
- NRF Weirdo
16 Apr 2019 22:08 #73931
by goebish
Thanks, can you try the test build please ?
- Cdog31
16 Apr 2019 22:09 #73932
by Cdog31
Yes I am on my way to try the test build
- goebish
- NRF Weirdo
16 Apr 2019 22:28 #73933
by goebish
I think your last 3 captures are wrong (no extra flags), you probably need to apply some throttle to enable those features.
- Cdog31
16 Apr 2019 22:28 #73934
by Cdog31
- goebish
- NRF Weirdo
16 Apr 2019 22:32 - 16 Apr 2019 22:33 #73935
by goebish
Ok good, seems the 0A -> 0E transition that I didn't understand is flip mode.
Try the test build, if it works I'll update it
Last edit: 16 Apr 2019 22:33 by goebish.
- Cdog31
16 Apr 2019 22:33 - 16 Apr 2019 22:40 #73936
by Cdog31
And yes it changes OE at full throttle.
Last edit: 16 Apr 2019 22:40 by goebish. Reason: oops, clicked the wrong button
- goebish
- NRF Weirdo
16 Apr 2019 22:36 - 16 Apr 2019 22:41 #73937
by goebish
Ok, you mean it's 0E only at full throttle (FF), nothing to do with flip mode ?
On the 2nd picture, seems throttle is full (FF) but the previous byte is 12, not 0E, is it only when RTH is enabled ?
Cdog31 wrote: And yes it changes OE at full throttle.
Last edit: 16 Apr 2019 22:41 by goebish.
- Cdog31
16 Apr 2019 22:44 #73938
by Cdog31
Yes OE. Only at full throttle nothing to do with RTH
- Cdog31
16 Apr 2019 22:48 #73939
by Cdog31
I am trying my best to understand your questions. Should I test return to home, headless, and flip when at full throttle only
- goebish
- NRF Weirdo
16 Apr 2019 22:51 #73940
by goebish
Just try the test build, I'll deal with the flags later.
- Cdog31
16 Apr 2019 22:53 #73941
by Cdog31
Okay will report back shortly
- Cdog31
16 Apr 2019 23:17 - 16 Apr 2019 23:18 #73943
by Cdog31
The drone binds. Response to throttle and elevator. However it flips on its own uncontrollably. I tried switches in each position. Still flips uncontrollably.
Last edit: 16 Apr 2019 23:18 by Cdog31.
- goebish
- NRF Weirdo
16 Apr 2019 23:26 #73944
by goebish
NIce
I'll try to understand what's wrong and update the build.
Time to create page: 0.345 seconds
- JJrc345 drones as gift in return for protocol.
