Jumper T8SG V2 Plus and Crossfire
13 Dec 2019 16:04 #75574 by Hans-Udo
Replied by Hans-Udo on topic Jumper T8SG V2 Plus and Crossfire
Hi Konatsu, I did not remove the first pin. I took it just so as it was.
13 Dec 2019 16:29 - 13 Dec 2019 16:38 #75575 by Konatsu
Replied by Konatsu on topic Jumper T8SG V2 Plus and Crossfire
Hans-Udo wrote: Hi Konatsu, I did not remove the first pin. I took it just so as it was.
I did restore that pin, but behavior is the same;/
Last edit: 13 Dec 2019 16:38 by Konatsu. Reason: new video link
13 Dec 2019 17:37 #75576 by Hans-Udo
you have to push the button on the crossfire module for binding. the button in the middle of the LED.
13 Dec 2019 17:48 #75577 by Konatsu
Hans-Udo wrote: you have to push the button on the crossfire module for binding. the button in the middle of the LED.
And how can i configure it after binding?
14 Dec 2019 09:53 #75584 by Hans-Udo
after binding you can configure it normaly in model and mixer menu
18 Dec 2019 16:29 - 18 Dec 2019 18:34 #75599 by Konatsu
I can't. CRSF menu is not working. RX is only working when i change it to PPM ;/
On deviation-t8sg_v2_plus-v5.0.0-e0ab3bc i can enter CRSF menu but it is empty
Update
I've removed pin 1 and it is now working on this build.
Last edit: 18 Dec 2019 18:34 by Konatsu.
19 Dec 2019 05:54 - 19 Dec 2019 05:55 #75601 by Denis
Replied by Denis on topic Jumper T8SG V2 Plus and Crossfire
Konatsu wrote: I can't. CRSF menu is not working. RX is only working when i change it to PPM ;/
Update
did you do the last night build? deviation-t8sg_v2_plus-v5.0.0-2b4606e. (18.12.2019) Does crossfire work with her?
Last edit: 19 Dec 2019 05:55 by Denis.
19 Dec 2019 16:03 #75602 by Konatsu
I've installed deviation-t8sg_v2_plus-v5.0.0-2b4606e but i can't get into CRSF menu. Nothing is happening when i press enter on it.
19 Dec 2019 16:37 #75603 by vlad_vy
Replied by vlad_vy on topic Jumper T8SG V2 Plus and Crossfire
It doesn't implemented in nightly builds. PR #840
19 Dec 2019 16:56 #75604 by vlad_vy
PR #840 merged, you can test it with next nightly build.
19 Dec 2019 22:29 #75605 by Denis
vlad_vy wrote: PR #840 merged, you can test it with next nightly build.
how to enable rssi?
21 Dec 2019 09:50 #75608 by Konatsu
OK, everything is working on latest build deviation-t8sg_v2_plus-v5.0.0-1ec5369
Thank all for help
05 Jan 2020 01:43 #75662 by Grajek
Replied by Grajek on topic Jumper T8SG V2 Plus and Crossfire
Can you bind with the Jumper T8SG V2 plus, Crossfire Micro TX and nano Rx? Is there a binding feature within Deviation? Everything Im finding says you have to bind on another Transmitter first. I don't have a Taranis. Could I buy the Crossfire TX Lite and wire it and bind?
05 Jan 2020 07:30 #75665 by Konatsu
Now you can do all this things from menu on t8sg. Also you can change vtx settings by Smart audio :)
05 Jan 2020 08:56 - 05 Jan 2020 08:57 #75666 by Konatsu
What should I enable to get betaflight menu working?
Now it is a empty tab.
Last edit: 05 Jan 2020 08:57 by Konatsu.
14 Jan 2020 03:09 #75707 by Frazam
Replied by Frazam on topic Jumper T8SG V2 Plus and Crossfire
Konatsu wrote: Now you can do all this things from menu on t8sg. Also you can change vtx settings by Smart audio :)
Does this mean after the hardware mod and inserting the crossfire module, the t8sg v2 plus has full functionality?
I ask because i have a t8sg v2 plus carbon on the way but after reading about the limited crossfire support, I'm thinking if I should return it and get the t16 instead. I'd rather not cause I like the smaller size of the t8sg carbon, but if crossfire has limited functions I'll have no choice. I'd rather pay a little extra to have full functionality than be crippled. Thanks.
Btw, I joined specifically to learn more about crossfire compatibility.
22 Jan 2020 14:44 #75796 by Denis
Should vtx be tbs, or any other manufacturer?
22 Jan 2020 16:43 #75797 by Konatsu
Any other supporting Smart Audio. I was using akk fx3-ultimate
26 Jan 2020 18:11 #75821 by WhoopassFPV
Replied by WhoopassFPV on topic Jumper T8SG V2 Plus and Crossfire
Would someone kindly post complete and EXACT processes with connecting T8SG V2 Plus and crossfire micro tx please.
From start, to finish including this so-called "hardware mod" (if it's necessary) which no one here directly links to.
Simply plugging in the crossfire module brings ZERO results and also no power going to the crossfire micro tx, in my case.
The module works if I plug in USB, then LED lights and breaths.
***Giving me a link to a video showing it working for someone else doesn't really provide a solution. (thanks for Nix Team Blacksheep)
Thanks in advance!
29 Jan 2020 08:42 #75847 by Konatsu
Just remove first top pin and connect lower part of this pin to lower part of last pin. Make sure that You are on latest build and id should work fine
Time to create page: 0.608 seconds
