Realacc R11 Mini
09 Jun 2020 21:24 - 10 Jun 2020 14:41 #76445 by unknown
Realacc R11 Mini was created by unknown
Have got Realacc R11 mini drone, would like to pair it with my DEVO 7E, any ideas which protocol used?
UPD transmitter based on MX5323 chip
MX5323 is a low-cost, highly integrated 2.4G wireless transceiver chip that uses GFSK modulation. chip Integrated RF transceiver, data link and low power MCU. The user issues instructions to the chip through the I/O port of the MCU Order, the chip automatically completes the transceiver configuration to communicate, and automatically determines whether the data transmission/reception is successful according to the response information Power, so as to retransmit, lose packets, continue to send and wait for operations, simplifying the user program. Transmitter support power Adjustable, the receiver adopts superheterodyne structure, the peripheral circuit is simple, only a few peripheral passive devices are needed. The chip uses SOP16L The package of the pin conforms to the RoHS standard.characteristic● 2.4GHz general ISM band operation;● Single chip completes sending and receiving;● Support 10 I/O port communication:● I/O port supports sleep wake-up function;● Support automatic data packet processing;● Support 33mm wire antenna;● Support single panel;● Support pin function customization;● Built-in 6 data channels, support self-organizing network;● 2.5V~3.6V power supply;● MCU memory FLASH: 2K bytes RAM: 208 bytes (40 dedicated RAM + 168 general RAM)● MCU features AD detection, PWM output, built-in up/down resistance, key wake up
Pin description
Pin name Pin description
PA0-PA4 Programmable as: input port, input port with pull-up resistor, push-pull output port; can also be used as A/D conversion mode
PA6,PA7 Intended input port, external interrupt input port, PWM output port, with sleep wake-up function
PB5 Programmable as: input port;
PC0, PC1 Programmable as: input port, up/down resistance input port, push-pull output port, open drain output port, programming communication mouth
VDD1 Digital power port
GND Chip ground port
VDD2 Analog power port
ANT Antenna port
XC1, XC2 Crystal port
RB4 Internal pin of MCU, connect to CE pin of RF chip
RB3 MCU internal pin, connect to RF chip CSN pin
RB2 MCU internal pin, connected to SCK pin of RF chip
RB1 MCU internal pin, connect to RF chip MOSI pin
RB0 MCU internal pin, connect to MISO pin of RF chip
RC2 MCU internal pin, connect to RF chip IRQ pin
Last edit: 10 Jun 2020 14:41 by unknown. Reason: chip info added
27 Jun 2020 13:10 - 07 Aug 2020 14:07 #76533 by unknown
Replied by unknown on topic Realacc R11 Mini
Finally I save dump using XN297Dump firmware for DEVO7e, need help to recognize protocol.
Warning: Spoiler! [ Click to expand ]
UDP Dump firmware for 7e give wrong data, right data obtained via XN297dump firmware for MultuTX
Last edit: 07 Aug 2020 14:07 by unknown. Reason: wrong data
11 Aug 2020 10:37 #76670 by unknown
UPD
Bind packets:
Bitrate=1Mbps
Type = Enhanced
Scramble = Yes
Address = 4D 41 49 4E = 'MAIN'
Channel = 80
P(10) = B1 99 06 00 00 55 59 5A 5A 62
B1 indicates bind packet
99 06 00 00 = ID = address of normal packets
55 59 5A 5A 62 = 85, 89, 90, 90, 98 = RF channels to be used
Normal packets:
Bitrate=1Mbps
Type = Enhanced
Scramble = Yes
Address = 99 06 00 00
Channels = 84, 89, 90, 90, 98 (guess from bind)
P(13)= DC 80 80 32 80 20 20 20 20 58 04 00 00
DC = normal packet
80 80 32 80 : AETR 00..80..FF
20 20 20 20 : Trims
58 : changing every time the TX restart
04 : |0x20=headless, |0x01=rate2, |0x02=rate3
00 : |0x01=calib, |0x20=return, |0x80=unknown
00 : |0x80=light, |0x01=flip
Source: github.com/pascallanger/DIY-Multiprotocol-TX-Module/issues/407
11 Aug 2020 11:02 #76671 by propnut
Replied by propnut on topic Realacc R11 Mini
I think you may find that development on this project has all but ceased. You may be better off migrating to a OpenTX system that has a multi-protocol module.
Would love for one of the Deviation developers to tell me I am wrong but I haven't seen any activity here for a very long time. I think Pascal still pops in from time to time but I would think he spends most of his time on the MP module.
Time to create page: 0.191 seconds
