Support for walkera telemetry.
08 Oct 2012 23:02 #2069 by PhracturedBlue
Replied by PhracturedBlue on topic Support for walkera telemetry.
flint723 wrote: I can also report that, with my ladybird, everything except the two numbers on the bottom of the telemetry page is reading 0.0. I did copy the media directory. The two numbers on the bottom are 00002900000000000000f401 and 313233343536373839303132. The model still functions correctly.
That at least is good. It means one of the voltages is 4.1V. It also means that only half of the expected data is being received. I'll make another build that doesn't update the sreen so often that should help.
08 Oct 2012 23:22 #2070 by PhracturedBlue
Here is a new build that will not constantly refresh the screen. Hopefully it will help. It doesn't really explain any of the other issues folks have reported though.
You will still need the filesystem from the above experimental release.
09 Oct 2012 00:21 #2072 by flint723
Replied by flint723 on topic Support for walkera telemetry.
I used that firmware and it did cure the jerkiness. And now voltage 2 is trying to display something but I can't tell what it is. It looks like it's putting the really long number in, it goes off the edge of the screen.
09 Oct 2012 02:52 - 09 Oct 2012 02:54 #2073 by flint723
Here's something a bit more interesting perhaps, the two digits circled in red are what changes with battery voltage, not the ones at the end. The first picture is at 4.2v resting, second is at 3.7v resting. With a full battery, it is 2a resting, but as soon as the motors start running it drops to 29. At the end of the pack it will drop as low as 22, which should be around 3.4v. Also about halfway through the pack the bottom number changed from what it was in the first picture to what it was in the 2nd picture. Hope this helps.
Last edit: 09 Oct 2012 02:54 by flint723.
09 Oct 2012 03:01 #2074 by PhracturedBlue
flint:
What model is it you are using? You seem to have one voltage (Voltage 2) which is what my Ladybird has, so I already know that position. But you aren't getting anything in the 2nd line (which is where temperature is sent) (the 313233... is the initialization value)
The display issues are at least partially due to not getting the proper fonts. I'm not sure what that is about. they work in the emulator, and I haven't changed the font code since the previous release where they were working.
09 Oct 2012 03:14 - 09 Oct 2012 03:17 #2075 by flint723
I am using the ladybird model that was posted in the model config forum. My ladybird was one of the first ones available so it probably has older firmware. It has never displayed temperature.
Just now I tried deleting my language and media folders and copying your newest ones over. And there was no difference in how anything is displayed.
Last edit: 09 Oct 2012 03:17 by flint723.
09 Oct 2012 03:19 #2076 by flint723
And yes my fonts were working right using 1.1.2, they weren't bold like they are now.
09 Oct 2012 03:48 #2077 by PhracturedBlue
Can you verify the dfu from here:
www.deviationtx.com/forum/5-news-announc...l-build-fab82a525bdb
just install the dfu, keep the filesystem you already have.
that build doesn't have telemetry, but it does use the new font code.
09 Oct 2012 03:54 #2078 by flint723
Yes, using that firmware it is back to normal, the same as 1.1.2.
09 Oct 2012 04:00 #2079 by vlad_vy
Replied by vlad_vy on topic Support for walkera telemetry.
PhracturedBlue wrote: I've posted an experimental build for folks with a devo8 here:
www.deviationtx.com/forum/5-news-announc...lemetry-7535ce7a8d0a
With this firmware bold fonts appears only for models with DEVO protocol. With all others protocol all looks normally. I've made reload after each change of protocol.
09 Oct 2012 04:04 #2080 by flint723
Yes vlad is right, if the transmitter is turned on with a model that uses a protocol other than devo, the font appears correctly.
09 Oct 2012 04:12 #2081 by PhracturedBlue
Ok, try this then. I found a buffer overflow in the devo initialization that may explain the font issue.
09 Oct 2012 04:18 #2082 by flint723
Yep, fixed the fonts. Although the voltage is still not displaying as a voltage.
09 Oct 2012 04:31 #2085 by PhracturedBlue
This should fix that problem:
09 Oct 2012 04:38 #2086 by flint723
Why yes it does fix it :)
09 Oct 2012 04:41 #2087 by flint723
And the Ladybird flies perfectly, even with the telemetry screen open. None of that uncontrolled 100% throttle I had before.
09 Oct 2012 04:43 - 09 Oct 2012 04:45 #2088 by PhracturedBlue
Ok, so now I need folks with different configurations to try this out.
Use the filesystem (specifically the media dir) from here:
with this dfu:
www.deviationtx.com/forum/3-feedback-que...etry/reply/2086#2085
Last edit: 09 Oct 2012 04:45 by PhracturedBlue.
09 Oct 2012 14:07 - 09 Oct 2012 15:22 #2105 by vlad_vy
Volt1=0.0V Volt2=0.0V Volt3=0.0V
Temp1=0C Temp2=0C Temp3=0C Temp4=0C
Volt1=0.0V and Volt3=0.0V don't changing.
Internal 5V
35000000000000000000f401 and
Real voltage = 5.35V
External V1
Volt2=3.8V
35002600000000000000f401 and
Real voltage = 3.88V
External V2
35000000260000000000f401 and
Strange behaviour of temperature sensors. Temperature sensors changing for some time after I heat up T1 sensor, next they freezed. Seems I need to exceed initial value 31 (29C) to start. Value of T1 sensor doesn't changing, always 29C (31...).
Temperature T1
Temp1=29C
312c302c0000000000000000.
Temperature T2
Temp2=24C
Temperature T3
Temp3=28C
Temperature T4
Temp4=24C
Boiling water at 749 mmHg
Temperature T4
Temp4=95C
312c2c730000000000000000.
Last edit: 09 Oct 2012 15:22 by vlad_vy.
09 Oct 2012 14:38 - 09 Oct 2012 14:50 #2107 by vlad_vy
flint723 wrote: Also I just noticed that once the transmitter has bound, if you turn off the tx without turning off the ladybird, the ladybird does a slow red flash and will not bind again. The only way to get it to bind again is to turn off both, turn on tx, then turn on ladybird. This was not the case before, you could turn off either one and have it rebind when turned back on without having to reboot both.
I also have such behaviour with telemetry module and Fixed ID.
Also, if I press 'Exit' button at telemetry page, Tx reboot with beep.
Last edit: 09 Oct 2012 14:50 by vlad_vy.
09 Oct 2012 16:59 #2112 by flint723
vlad_vy wrote: I also have such behaviour with telemetry module and Fixed ID.
Mine does nothing when the Exit button is pressed. But if it is held for 1-2 seconds it goes back to the home screen, which is normal I think.
Time to create page: 0.992 seconds
