Support for walkera telemetry.
25 Apr 2015 04:44 #31587
Replied by vlad_vy on topic Support for walkera telemetry.
Indigo, why you write to NULL? I think it's not "black hole", it's something like (void *)0L. Results can be unpredictable.
- Indigo
25 Apr 2015 06:03 - 25 Apr 2015 06:05 #31589
by Indigo
Thanks for reviewing my code.
I'm not writing to NULL, in an earlier commit I changed ReadRegisterMulti() to enable dummy reads.
ReadRegisterMulti() is now this:
That's OK, isn't it? If data is NULL, the byte(s) read is not stored.
Replied by Indigo on topic Support for walkera telemetry.
vlad_vy wrote: Indigo, why you write to NULL? I think it's not "black hole", it's something like (void *)0L. Results can be unpredictable.
static void ReadRegisterMulti(u8 address, u8 data[], u8 length)
CS_LO();
PROTOSPI_xfer(address);
for(u8 i = 0; i < length; i++)
u8 byte = PROTOSPI_xfer(0);
if (data != NULL)
data[i] = byte;
CS_HI();
}That's OK, isn't it? If data is NULL, the byte(s) read is not stored.
Last edit: 25 Apr 2015 06:05 by Indigo.
25 Apr 2015 06:30 - 25 Apr 2015 06:50 #31590
Build a9e60ff, Devo GPS Speed always invariable with red background. If reboot Tx, value changed, but remains invariable with red background.
Last edit: 25 Apr 2015 06:50 by vlad_vy.
25 Apr 2015 07:11 - 25 Apr 2015 07:12 #31592
Replied by PhracturedBlue on topic Support for walkera telemetry.
Where is this all going?
I have to admit I'm very skeptical of the process at the moment. When I look at Indigo's code, it has a lot of change compared to the trunk in DSM and Devo protocols. I don't really understand what much of that change is buying me. In Devo, it may result in eliminating the 'Reboot' condition, but at least at the moment, it will come at the cost of major refactoring of the callback loop, and the Reboot condition itself is not causing any issues (any more). In DSM2 the code refactor may reduce Holds? I belive the original intent was to improve reception rate (eliminate invalids and bogus data)? What else does it achieve? All of that change comes with inherent stability risk to the most commonly used protocols. It makes me very nervous, especially with 9 out of 10 builds seeming to have major issues that make it unusable. I really need to see concrete gains, and then I will wonder whether those gains can be had with less change to the protocol code.
Last edit: 25 Apr 2015 07:12 by PhracturedBlue.
- Francisco
25 Apr 2015 14:15 - 25 Apr 2015 14:16 #31608
by Francisco
Replied by Francisco on topic Support for walkera telemetry.
Hi, i have a SuperCP and v120d2s both with updated firmware for telemetry.
The telemetry works, but sometimes turn to inverted( black/White) and the voltaje dont change anymore, especially when the voltaje is low.
I use the 4.01, tried with build from yesterday but the problem persists.
Last edit: 25 Apr 2015 14:16 by Francisco.
25 Apr 2015 17:04 - 27 Apr 2015 05:24 #31611
deleted
Last edit: 27 Apr 2015 05:24 by vlad_vy.
25 Apr 2015 17:41 #31612
PB, can you at least revert back code in main trunk, telemetry will work much better.
} else {
if(CYRF_ReadRegister(0x07) & 0x20) { // this won't be true in emulator so we need to simulate it somehow
CYRF_ReadDataPacket(packet);
parse_telemetry_packet(packet);
delay = 100 * (16 - txState);
txState = 15;
}- PhracturedBlue
25 Apr 2015 17:53 #31613
why?
The current code uses a strict rule set: must have received a complete 16byte packet without any errors. It may be necessary to change the check to be more robust (which I think is what Indigo has been working on), but changing that line without anything else will make it more likelythat bad packets get to the telemetry parser which doesn't seem very helpful.
25 Apr 2015 18:02 #31614
I don't know why, but it works much better than current code.
- Indigo
25 Apr 2015 20:26 #31618
by Indigo
Yes, you need to check and respond to bit 1 "receive complete" because if it receives a packet less than 16 bytes then it will stop receiving data unless overwrite enable bit is set in RX_CTRL register, in which case you might get a valid packet of less than 16 bytes, followed by half on next packet and then it will overflow. Bit 5 (buffer full) will then be true, but you have bad data.
If you want to keep it simple use same rule as dsm protocol:
Whenever complete bit (0x02) is set you should read it to clear the buffer ready for next packet.
if((CYRF_ReadRegister(0x07) & 0x07) == 0x02) // complete with no errors.Whenever complete bit (0x02) is set you should read it to clear the buffer ready for next packet.
- Indigo
26 Apr 2015 15:23 - 26 Apr 2015 21:25 #31646
by Indigo
Here is new version of CYRF_ReadDataPacketLen((), aka CYRF_RxPacketIsGood()
A second check of CYRF_07_RX_IRQ_STATUS is illegal if RXC=1 and RXE=1, and is only needed if RXC=1 and RXE=0 so that check we need.
if status is zero, nothing has happened and buffer will still be empty.
CYRF_09_RX_COUNT can only be used if receive complete or error has occured. Next best length field is
CYRF_0A_RX_LENGTH updated after reception of a new length field (shortly after start of packet detected)
int CYRF_ReadDataPacketLen(u8 dpbuffer[], u8 len)
unsigned rx_state = CYRF_ReadRegister(CYRF_07_RX_IRQ_STATUS);
if ((rx_state & 0x03) == 0x02) {
// RXC=1, RXE=0 then 2nd check is required (debouncing)
rx_state |= CYRF_ReadRegister(CYRF_07_RX_IRQ_STATUS);
if (rx_state) {
CYRF_WriteRegister(CYRF_07_RX_IRQ_STATUS, 0x80); // need to set RXOW before data read.
u8 length;
if (rx_state & 0x07)
// if complete or error, we can get the actual count
length = CYRF_ReadRegister(CYRF_09_RX_COUNT);
else
// otherwise, use length reported by start of packet
length = CYRF_ReadRegister(CYRF_0A_RX_LENGTH);
if (!length)
length = 1;
else if (((rx_state & 0x87) == 0x02) && length == len) {
ReadRegisterMulti(CYRF_21_RX_BUFFER, dpbuffer, length);
return 1;
// else, empty buffer
ReadRegisterMulti(CYRF_21_RX_BUFFER, NULL, length);
return 0;
}A second check of CYRF_07_RX_IRQ_STATUS is illegal if RXC=1 and RXE=1, and is only needed if RXC=1 and RXE=0 so that check we need.
Last edit: 26 Apr 2015 21:25 by Indigo. Reason: Restore original post
- Indigo
26 Apr 2015 21:28 - 26 Apr 2015 21:40 #31678
by Indigo
Here is new version with added parameter exit receiving for final call (buffer clean-up).
The Devo protocol calls this multiple times, the final call is when state == 15
int CYRF_ReadDataPacketLen(u8 dpbuffer[], u8 len, int exit)
unsigned length;
// if receive complete, any error, or exit receiving
if ((rx_state & 0x07) || exit) {
if (rx_state) {
if (length) {
CYRF_WriteRegister(CYRF_07_RX_IRQ_STATUS, rx_state | 0x80);
// if RXE=0 then 2nd check is required to get true value of RXE
if (!(rx_state & 0x01))
if (((rx_state & 0x07) == 0x02) && length == len) {
// good data (complete with no errors)
return 1;
// else empty buffer (clean-up)
return 0;
}The Devo protocol calls this multiple times, the final call is when state == 15
if (CYRF_ReadDataPacketLen(packet, 0x10, txState == 15)) {
Last edit: 26 Apr 2015 21:40 by Indigo.
27 Apr 2015 09:28 #31695
At first glance build 342e9de working with Devo protocol.
27 Apr 2015 15:26 - 30 Apr 2015 05:33 #31699
It seems that I was able to get an alternative version of the code that works really well. I had several flights with Ladybird without any problems. DSMX protocol also tested with telemetry, but on bench only.
PB, can you build test version?
cyrf6936.c
devo_cyrf6936.c
dsm2_cyrf6936_b45.c
Changed files:
cyrf6936.c
int CYRF_ReadDataPacketLen(u8 dpbuffer[])
u8 rx_state;
u8 length;
if (rx_state & 0x02) { // receive complete
if (!(rx_state & 0x01)) { // RXC=1, RXE=0 then 2nd check is required (debouncing)
if (rx_state & 0x05) { //if any error
// bad data, empty buffer
while (length) {
CYRF_ReadRegister(CYRF_21_RX_BUFFER);
length--;
return 2; //bad data
} else {
return 1; //good data
return 0; //receive not complete
}devo_cyrf6936.c
} else { // this won't be true in emulator so we need to simulate it somehow
u8 rx_state = CYRF_ReadDataPacketLen(packet);
if(rx_state) {
if(rx_state == 1) {
txState = 15;
#ifdef EMULATORdsm2_cyrf6936_b45.c
} else if(state == DSM2_CH2_READ_A || state == DSM2_CH2_READ_B) {
//Read telemetry if needed
if(rx_state == 1) {
if (state == DSM2_CH2_READ_A && num_channels < 8) {Changed files:
Last edit: 30 Apr 2015 05:33 by vlad_vy.
27 Apr 2015 16:09 - 27 Apr 2015 16:10 #31702
Done:
www.deviationtx.com/downloads-new/catego...vlad-s-devo-dsm-test
If you want, I can give you access that you can make your own test builds. It only requires that you have 'curl' installed, and can run 'make zip'
Last edit: 27 Apr 2015 16:10 by PhracturedBlue.
- Indigo
27 Apr 2015 16:23 #31704
by Indigo
Looks good
And it will work even better if we use:
and don't waste time manually emptying the receive buffer.
CYRF_WriteRegister(CYRF_06_RX_CFG, 0x4A);and don't waste time manually emptying the receive buffer.
27 Apr 2015 16:32 #31706
Unfortunately we have to do it with DSMX protocol. Therefore will be better to have the same setup for all CYRF protocols.
PB, i have the local build environment only, all other is dark forest for me.
27 Apr 2015 16:46 #31707
Given your involvement, maybe it is time to move to the next level then
Learning to use HG to keep up to date, and to create diffs is pretty easy.
Just let me know if you are interested and I'll give you developers permissions which will give you upload access
Assuming you are using windows, all you'd need would be curl from here (get Win32-Generic or Win64-Generic as needed):
curl.haxx.se/download.html
and put it in your /usr/bin directory in MSYS
then just follow the instructions here:
www.deviationtx.com/forum/7-development/...ly-to-the-test#30367
- Indigo
27 Apr 2015 19:10 #31716
by Indigo
Looks good
And it will work even better if we use:so we don't waste cpu time emptying the receive buffer.
cyrf6936.c:
devo_cyrf6936.c:
dsm2_cyrf6936.c:
Updated build 342e9de with this has been uploaded to Test Builds
Source
CYRF_WriteRegister(CYRF_06_RX_CFG, 0x4A);cyrf6936.c:
int CYRF_ReadDataPacket(u8 dpbuffer[])
u8 rx_state = CYRF_ReadRegister(CYRF_07_RX_IRQ_STATUS);
return -1; // bad data
CYRF_WriteRegister(CYRF_07_RX_IRQ_STATUS, 0x80); // set RXOW before data read
u8 length = CYRF_ReadRegister(CYRF_09_RX_COUNT);
return 1;
return 0; // no data
}devo_cyrf6936.c:
} else {
int status = CYRF_ReadDataPacket(packet);
if (status) {
if (status == 1) {
scramble_pkt(); //This will unscramble the packet
if ((packet[0] & 0xF0) == TELEMETRY_ENABLE && (fixed_id & 0x00ffffff) ==
(((u32)packet[15] << 16) | ((u32)packet[14] << 8) | packet[13]))
parse_telemetry_packet();
txState = 15;
#ifdef EMULATORdsm2_cyrf6936.c:
if (CYRF_ReadDataPacket(packet) == 1)
if (state == DSM2_CH2_READ_A && num_channels < 8) {Updated build 342e9de with this has been uploaded to Test Builds
Source
28 Apr 2015 07:20 - 28 Apr 2015 07:23 #31734
By the way, disable buffer overwrite bit is a good way to test that receiving work without any problems. If anything get stuck in the buffer, telemetry stop working. The next code will work with any setup:
u8 rx_state;
u8 length;
if( !(CYRF_ReadRegister(CYRF_06_RX_CFG) & 0x02)) { //if buffer overwrite disabled (RXOW bit)
while (length) {
length--;
} else {
Last edit: 28 Apr 2015 07:23 by vlad_vy.
Time to create page: 0.313 seconds
- Support for walkera telemetry.
