Support for walkera telemetry.
30 Apr 2015 05:18 - 30 Apr 2015 05:35 #31833
Replied by vlad_vy on topic Support for walkera telemetry.
By the way, my code also working fine with buffer overwrite disabled, it's a good way to detect any problems with receiving. If any data get stuck in the RX buffer, telemetry stop working.
devo_cyrf6936.c
dsm2_cyrf6936.c
devo_cyrf6936.c
CYRF_WriteRegister(CYRF_06_RX_CFG, 0x48);dsm2_cyrf6936.c
{CYRF_06_RX_CFG, 0x48},
Last edit: 30 Apr 2015 05:35 by vlad_vy.
- linux-user
30 Apr 2015 07:43 #31835
by linux-user
Replied by linux-user on topic Support for walkera telemetry.
vlad-deviation-devo10-v4.0.1-f628e56 has been running now for 18h without any problems.
- 4x 'RST CYRF' message what is expected on my TX
- connection still possible
- telemetry working prefect
- control working prefect
OT:
- when telemetry alarm is triggered it jumps to telemetry page (maybe debatable).
- data logging is not working since a long time ago.
OT:
30 Apr 2015 08:06 - 30 Apr 2015 08:14 #31836
I also don't like switching to Telemetry monitor screen in case any telemetry alarm. At least we need option to select if we want to switch or not. By default, definitely I don't want switch to any other screen from main screen.
Last edit: 30 Apr 2015 08:14 by vlad_vy.
- Gyrfalcon
30 Apr 2015 09:31 - 01 May 2015 03:47 #31838
by Gyrfalcon
Replied by Gyrfalcon on topic Support for walkera telemetry.
With additional testing ([PhracturedBlue]Vlad's Devo/DSM test #31794, deviation-devo12-v4.0.1-f628e56) has had a few Rst CYRF messages.
For the new tests, I separated the receiver and transmitter to about 3 meters and setup a parallel test system. Both systems are powered at 100uW and have had good telemetry and control reception. I think the Rst CYRF message occurs sometimes when I bind or re-bind one of the systems, or when I turn on an additional transmitter (Devo8S, 100mW). But I can not get a consistent response, so it may be something else.
I also noted that I can jam the telemetry signal with the addition transmitter (most of the time), once it is moved away or turned off, the telemetry is restored. The receivers do not seam to be affected by a third transmitter and I still see smooth servo functionality.
At the end my torcher testing, I did have a LOC to the RX2637. The RX1202, which was dual bound to the same transmitter was still connected, so I don't think it was caused by a transmitter problem.
BTW, I tested Indigo's latest build, deviation-devo12-v4.0.1-ee1b869 and it seams to perform about the same. Telemetry and receiver connections were good. Unfortunately, it also generates a few Rst CYRF messages, similar to Vlad's code. I had both versions running at the same time, and sometimes it appeared that they generated Rst CYRF messages at the same time, but other times they were independent. Wish I could get consistent, results.
I was happy to see that Indigo changed the alarm page jump code as I suggested, Thanks!
Last edit: 01 May 2015 03:47 by Gyrfalcon. Reason: updated build version
30 Apr 2015 09:43 - 30 Apr 2015 10:01 #31839
PB, probably will be better change code to version without reduced polling and test again? I don't like occasionally "Rst CYRF" messages.
or at least decrease delay
} else {
CYRF_SetTxRxMode(RX_EN); //Receive mode
CYRF_WriteRegister(CYRF_05_RX_CTRL, 0x80); //Prepare to receive (do not enable any IRQ)
//delay = 900;
//txState = 9;
}or at least decrease delay
} else {
delay = 800;
txState = 8;
Last edit: 30 Apr 2015 10:01 by vlad_vy.
- linux-user
30 Apr 2015 10:08 #31842
by linux-user
I like occasionally "Rst CYRF" messages
Every ~4h one "Rst CYRF" messages means to me a prevented LOC
30 Apr 2015 10:14 #31843
You still will have prevented LOC, but may be less occasionally "Rst CYRF" messages.
- Gyrfalcon
30 Apr 2015 17:08 #31854
by Gyrfalcon
Restarted the test with ([PhracturedBlue]Vlad's Devo/DSM test #31794, deviation-devo12-v4.0.1-f628e56) and let it run over night, by itself with no other interference (at least by me).
So far, after 9 Hrs, the Debug log is clean, with no "Rst CYRF' messages.
Telemetry looks good and no LOC to either the RX2637 or the RX1202. (Note, the Devo12S was set to 100uW, with about 3 meters distance between TX and RX, same as before.)
- Gyrfalcon
01 May 2015 02:39 - 01 May 2015 03:33 #31877
by Gyrfalcon
Repeated the same bench tests today with Indigo's latest build, deviation-devo12-v4.0.1-ee1b869 and all is good after 9 hrs of running. No "Rst CYRF" messages, both receivers are still connected and Telemetry is working well.
Last edit: 01 May 2015 03:33 by Gyrfalcon. Reason: updated build version
01 May 2015 08:44 - 05 May 2015 09:52 #31883
New version of devo_telemetry_cb() without excessive poll. I have not "Rst CYRF" messages. So, probably this version be worth more extensive testing. For testing purpose I disabled buffer overwrite mode for both DEVO and DSM protocols. But it works with both buffer overwrite modes.
Changed files (printf(" Rst CYRF\n") commented out):
CYRF_WriteRegister(CYRF_06_RX_CFG, 0x48);static u16 devo_telemetry_cb()
int delay;
if (txState == 0) {
DEVO_BuildPacket();
CYRF_WriteDataPacket(packet);
txState = 1;
return 900;
if (txState == 1) {
int i = 0;
u8 reg;
while (! ((reg = CYRF_ReadRegister(0x04)) & 0x02)) {
if (++i >= NUM_WAIT_LOOPS)
break;
if (((reg & 0x22) == 0x20) || (CYRF_ReadRegister(0x02) & 0x80)) {
CYRF_Reset();
cyrf_init();
cyrf_set_bound_sop_code();
CYRF_ConfigRFChannel(*radio_ch_ptr);
//printf(" Rst CYRF\n");
delay = 1500;
txState = 3;
} else {
if (state == DEVO_BOUND) {
/* exit binding state */
state = DEVO_BOUND_3;
if(pkt_num == 0 || bind_counter > 0) {
delay = 1500;
txState = 3;
} else {
txState = 2;
return 1200;
if(txState == 2) { // this won't be true in emulator so we need to simulate it somehow
//Read telemetry if needed
if(CYRF_ReadDataPacketLen(packet) == 1) {
parse_telemetry_packet(packet);
#ifdef EMULATOR
u8 telem_bit = rand32() % 7; // random number in [0, 7)
packet[0] = TELEMETRY_ENABLE + telem_bit; // allow emulator to simulate telemetry parsing to prevent future bugs in the telemetry monitor
//printf("telem 1st packet: 0x%x\n", packet[0]);
for(int i = 1; i < 13; i++)
packet[i] = rand32() % 256;
for(int i = 0; i < TELEM_UPDATE_SIZE; i++)
Telemetry.updated[i] = 0xff;
#endif
delay = 300;
txState = 3;
if(txState == 3) {
CYRF_SetTxRxMode(TX_EN); //Write mode
if(pkt_num == 0) {
//Keep tx power updated
CYRF_WriteRegister(CYRF_03_TX_CFG, 0x08 | Model.tx_power);
radio_ch_ptr = radio_ch_ptr == &radio_ch[2] ? radio_ch : radio_ch_ptr + 1;
txState = 0;
return delay;
}Changed files (printf(" Rst CYRF\n") commented out):
Last edit: 05 May 2015 09:52 by vlad_vy.
- linux-user
01 May 2015 12:44 - 01 May 2015 12:48 #31886
by linux-user
indigo-deviation-devo10-v4.0.1-ee1b869 is now running for 18.5h without any problems this
test
- 1x 'RST CYRF' message what is expected on my TX
- telemetry alarm working as "advertised" (Gyrfalcon's hybrid)
So far with my limited test capabilities both versions are working
Last edit: 01 May 2015 12:48 by linux-user.
01 May 2015 15:55 #31889
So far I have not "Rst CYRF" messages, 4 hours of testing the new version of devo_telemetry_cb() without excessive poll.
02 May 2015 07:30 - 05 May 2015 09:53 #31922
I added CRC16 check for received packet. I don't know if CRC16 check will work with other CYRF protocols. Tested with DEVO and DSMX protocols only.
First time I see rock solid "Flight Log" values for DSMX protocol, without any sporadical erroneous values. But it can be illusion.
int CYRF_ReadDataPacketLen(u8 dpbuffer[])
u8 rx_state;
u8 length;
rx_state = CYRF_ReadRegister(CYRF_07_RX_IRQ_STATUS);
if (rx_state & 0x02) { // receive complete
if (!(rx_state & 0x01)) { // RXC=1, RXE=0 then 2nd check is required (debouncing)
rx_state |= CYRF_ReadRegister(CYRF_07_RX_IRQ_STATUS);
length = CYRF_ReadRegister(CYRF_09_RX_COUNT);
if ((rx_state & 0x05) || (CYRF_ReadRegister(CYRF_08_RX_STATUS) & 0x08)) { //if any error or CRC error
if( !(CYRF_ReadRegister(CYRF_06_RX_CFG) & 0x02)) { //if buffer overwrite disabled (RXOW bit = 0)
// bad data, empty buffer
CYRF_WriteRegister(CYRF_07_RX_IRQ_STATUS, 0x80); // need to set RXOW before data read
while (length) {
CYRF_ReadRegister(CYRF_21_RX_BUFFER);
length--;
return 2; //bad data
} else {
// good data (complete with no errors)
ReadRegisterMulti(CYRF_21_RX_BUFFER, dpbuffer, length);
return 1; //good data
return 0; //receive not complete
Last edit: 05 May 2015 09:53 by vlad_vy.
02 May 2015 17:19 #31967
With the help of next test code I can say that timing 900+1200+300 is quite good. With timing 900+1180+320 I can sometimes get "Delay:1" messages. With any higher timing I don't see these messages.
int delay;
if (txState == 0) {
DEVO_BuildPacket();
txState = 1;
return 900;
if (txState == 1) {
int i = 0;
u8 reg;
break;
CYRF_Reset();
cyrf_init();
printf("Rst CYRF\n");
delay = 1500;
txState = 3;
} else {
delay = 1500;
txState = 3;
} else {
txState = 2;
return 1180;
int i = 0;
u8 rx_status;
while ( !((rx_status = CYRF_ReadRegister(0x07)) & 0x20)) {
if (++i > NUM_WAIT_LOOPS)
break;
if((rx_status & 0x03) == 0x02) { // RXC=1, RXE=0 then 2nd check is required (debouncing)
rx_status |= CYRF_ReadRegister(0x07);
if ((rx_status & 0x27) == 0x22) { // good data (complete with no errors)
CYRF_WriteRegister(CYRF_07_RX_IRQ_STATUS, 0x80); //Prepare to read buffer
CYRF_ReadDataPacket(packet);
if(i) printf(" Delay: %d\n", i);
#ifdef EMULATOR
#endif
delay = 320;
txState = 3;
if(txState == 3) {
if(pkt_num == 0) {
txState = 0;
return delay;
}- PhracturedBlue
02 May 2015 18:50 #31974
Replied by PhracturedBlue on topic Support for walkera telemetry.
20 micreoseconds is not very much. I think you are right on the edge, and it is unlikely to be the same for all receivers
02 May 2015 19:28 #31976
Most of telemetry packets ended with timing 900+1140+360, with timing 900+1180+320 I can get only one "Delay: 1" message in 1-2 minutes. I will test it with all my Devo receivers.
- Indigo
02 May 2015 22:27 #31990
by Indigo
Replied by Indigo on topic Support for walkera telemetry.
Try checking RXGO,
devo_cyrf6936.c
devo_cyrf6936.c
if (!(CYRF_ReadRegister(CYRF_05_RX_CTRL) & 0x80)) {
// RXGO has cleared so "something" has been received
if (CYRF_ReadDataPacket(packet) == 1) {
...- Indigo
02 May 2015 22:42 #31991
by Indigo
CRC16 check is already included in error bit of RX_IRQ_STATUS but only after receive is complete.
So if RXC=1 and RXE=0, we check RX_IRQ_STATUS again to get final value of RXE which includes CRC16 error.
vlad_vy wrote: I added CRC16 check for received packet. I don't know if CRC16 check will work with other CYRF protocols. Tested with DEVO and DSMX protocols only.
}- Indigo
03 May 2015 03:40 - 03 May 2015 03:42 #31996
by Indigo
I've created a simplified version of ReadDataPacket() that also supports buffer emptying required for DSM protocol.
This new version only checks 2 bits: RXE receive data error, and RXC receive complete.
cyrf6936.c
A new test version 5c9ff36 using the above is available in Test Builds . DSM protocol is using "force" buffer emptying.
Previous test version ee1b869 was all cyrf protocols (DSMx, Devo, J6pro) using buffer overwrite enabled.
cyrf6936.c
int CYRF_ReadDataPacket(int force, u8 dpbuffer[]) // use "force" if not set RXOW EN in RX_CFG
int ok = 0;
u8 rx_state = CYRF_ReadRegister(CYRF_07_RX_IRQ_STATUS);
if (rx_state & 0x01) // RXE=1 bad data
ok = -1;
else if (rx_state & 0x02) // receive complete
ok = (CYRF_ReadRegister(CYRF_07_RX_IRQ_STATUS) & 0x01) ? -1 : 1;
if (ok == 1 || (ok && force)) {
CYRF_WriteRegister(CYRF_07_RX_IRQ_STATUS, 0x80); // set RXOW before data read
u8 length = CYRF_ReadRegister(CYRF_09_RX_COUNT);
return ok;
}A new test version 5c9ff36 using the above is available in Test Builds . DSM protocol is using "force" buffer emptying.
Last edit: 03 May 2015 03:42 by Indigo.
03 May 2015 04:31 - 03 May 2015 04:32 #31998
If you use it with "force" option, you can read buffer while receive is not completed, but error rise. I have bad experience with such reading.
Last edit: 03 May 2015 04:32 by vlad_vy.
Time to create page: 0.599 seconds
- Support for walkera telemetry.
