Support for walkera telemetry.
15 Oct 2012 14:36 - 15 Oct 2012 14:54 #2254 by Andrey
Replied by Andrey on topic Support for walkera telemetry.
I regret not being able to check before ...
FW: deviation-devo8-06a60453e371
WK-CTL01-D + 3 temperature sensors + 2 voltage sensor + 1 RPM sensor + GPS sensor
DEVIATION FW
WALKERA FW
Last edit: 15 Oct 2012 14:54 by Andrey.
15 Oct 2012 15:24 - 15 Oct 2012 15:44 #2257 by vlad_vy
Replied by vlad_vy on topic Support for walkera telemetry.
Rate R1
The two numbers on the bottom are
35000000000099009700f401 and
ffffffff0000000000000000.
Real RPM = 17800 rpm (optical tachometer)
Rate R1
35000000000057005500f401 and
Real RPM = 10000 rpm (optical tachometer)
Rate R1
3500000000002e002d00f401 and
Real RPM = 5400 rpm (optical tachometer)
Rate R2
Rate R2
Rate R2
Last edit: 15 Oct 2012 15:44 by vlad_vy.
15 Oct 2012 15:32 - 15 Oct 2012 15:36 #2258 by FDR
Replied by FDR on topic Support for walkera telemetry.
From Andrey's videos it looks like RPM value is a multiple of 120...
0x55 = 85
* 120 = 10200 (~10000)
0x97 = 151
* 120 = 18120 (~17800)
Last edit: 15 Oct 2012 15:36 by FDR.
15 Oct 2012 16:12 - 15 Oct 2012 16:19 #2259 by vlad_vy
I'm agree,
Rate sensor reading * 2 = rps, rps * 60 = rpm
I only wonder that R1 and R2 sensor readings are slightly different. Both sensor read 1 magnet on axis at dremel.
Last edit: 15 Oct 2012 16:19 by vlad_vy.
15 Oct 2012 16:14 #2260 by PhracturedBlue
Replied by PhracturedBlue on topic Support for walkera telemetry.
Thanks, this is very useful data. One thing I see is that we have no GPS data in this set. It must use another packet number. I'll build a release with 33, 34, 35 and see if that helps catch it.
15 Oct 2012 16:30 #2261 by Andrey
Turn the rotor speed to constant 2540 (use Castle Creations Phoenix Ice 50 in governer mode)
WALKERA FW: RPM2 2520-2540
DEVIATION FW: at the end of the penultimate line 1500-1600
15 Oct 2012 16:52 #2262 by PhracturedBlue
Here's a new DFU capturing 7 packets worth of data rather than just 2 which should hopefully identify the GPS info.
It also should properly display RPM (though obviously that is untested):
15 Oct 2012 17:14 - 15 Oct 2012 17:47 #2265 by vlad_vy
No result with GPS
35000000000000000000f401
333333333333333333333333
444444444444444444444444
555555555555555555555555
666666666666666666666666
777777777777777777777777
Sorry, have data, need more time to get
30333032302e383*********
353935342e37363*********
31303*********4d4d4e45fb
000000000000302e3*******
31373M3m3S3s313531303132
Red s incremented every second
Ret S incremented every 10 seconds
I think 12 digits of last line represent time.
All * sometimes changed.
Last edit: 15 Oct 2012 17:47 by vlad_vy.
15 Oct 2012 17:56 #2267 by vlad_vy
I haven't idea what to do with that data.
15 Oct 2012 18:03 #2268 by PhracturedBlue
I need to know the GPS coordinates reported by Walkera firmware to actually make anything of that.
15 Oct 2012 18:14 #2269 by vlad_vy
GPS Receiver 15-10-2012 22:09:43
Longitude: East 030°20.9158
Latitude: North 59°54.7051
Altitude: 106.0 m
Speed: 0.5 km/h
15 Oct 2012 18:14 - 15 Oct 2012 18:18 #2270 by PhracturedBlue
a large amount of the data seems to be in ascii.
your data looks something like:
03020.8***** (East)
5954.76***** (North)
10***** MMNE?
000000 0.****
17????151012 (time and date)
Last edit: 15 Oct 2012 18:18 by PhracturedBlue.
15 Oct 2012 18:16 #2271 by PhracturedBlue
Cool, so we have east and north position.
Can you fill in actual vaules for the '*' and '?' cases (even if they are changing, a single set would help)
especially the last 3 lines
15 Oct 2012 18:26 #2272 by vlad_vy
30333032302e3832373045fb
353935342e373737364e0700
31322e380000004d4d4e45fb
000000000000302e30300000
313832353532313531303132
15 Oct 2012 18:54 #2274 by PhracturedBlue
vlad_vy wrote: 30333032302e3832373045fb
So:
03020.8270E
5954.7776N
12.8 MMNE
0.00
182552151012
Or:
030°20.8270E
59°54.776N
12.8 MMNE (altitude maybe)?
0.00 (probably speed)
2012-10-15 18:25:52 (UTC time maybe? looks to be a few hours off)
15 Oct 2012 18:57 #2275 by vlad_vy
My local time: UTC + 4
15 Oct 2012 19:00 - 15 Oct 2012 19:01 #2276 by PhracturedBlue
Ok, then we've got almost everything. The altitude looks a bit odd (off by a factor of 10 compared to your stated info), and I'm not sure what 'MMNE' means, but otherwise it looks good.
Edit: Do you tell the Tx your timezone, or did it figure it out by the location?
Last edit: 15 Oct 2012 19:01 by PhracturedBlue.
15 Oct 2012 19:07 #2277 by vlad_vy
I set Timezone at GPS settings in Tx (UTC+04.00). Tomorrow I can make next try with GPS.
16 Oct 2012 12:34 - 16 Oct 2012 13:18 #2283 by vlad_vy
GPS Receiver 16-10-2012 15:47:43
Longitude: East 030°20.8309
Latitude: North 59°54.7674
Altitude: 28.9 m
Speed: 0.20 km/h
30333032302e3832303245fb - longitude
353935342e373738304e0700 - latitude
34312e360000004d4d4e45fb - altitude
000000000000302e36330000 - speed
313231323436313631303132 - time and date
Every switch on telemetry module with GPS altitude reading is different, from 10.0 to 95.0 m. For Walkera FW and Deviation FW.
Last edit: 16 Oct 2012 13:18 by vlad_vy.
16 Oct 2012 15:59 #2286 by PhracturedBlue
Thanks,
I've got it mostly coded up now. I'll build an updated dfu when I'm done for testing.
Time to create page: 0.305 seconds
