DEVO 12s HELP
- smileyusmc
08 Feb 2015 08:23 - 08 Feb 2015 08:27 #28447
by smileyusmc
DEVO 12s HELP was created by smileyusmc
Last edit: 08 Feb 2015 08:27 by smileyusmc. Reason: pic
08 Feb 2015 10:46 #28449
Replied by vlad_vy on topic DEVO 12s HELP
Do you flash library file (devo12-lib.dfu) and write filesystem to Tx?
- smileyusmc
08 Feb 2015 11:05 #28450
by smileyusmc
Replied by smileyusmc on topic DEVO 12s HELP
yes i used these files
v1.5a.dfu firmware update
lib v1.0.8.dfu
lib v1.0.8.dfu
- smileyusmc
08 Feb 2015 11:08 #28451
by smileyusmc
on transmitter works with uploader 1.4
my other transmitter can not get downloader it to work on my win 7 computer
08 Feb 2015 19:40 #28470
Replied by FDR on topic DEVO 12s HELP
If I'm not mistaken you are trying to upgrade the stock Walkera devention firmware, however this site is about a 3rd party replacement fimware called deviation.
Anyway, try to download a fresh copy (or simply unzip it again if you still have zip file), and make sure you use the UPGRADE button, otherwise the DfuSe ruins the files...
Time to create page: 0.190 seconds
Stock Firmware Help
- DEVO 12s HELP
