devo f7
17 Sep 2015 07:26 #37815 by pathma82
devo f7 was created by pathma82
my transmitter devo f7 working fine till morning due to devil in my mind i uploaded to version 4.0.1 and formatted my transmitter from 0.3B as shown in the video
when i switched on the transmitter display showing USB connected and nothing happening
again i reinstall to 0.3b version this time when i switch on its showing throttle warning inspite of all the switches in proper position and couldnt able to access any other menu
please help
17 Sep 2015 19:41 #37831 by FDR
Replied by FDR on topic devo f7
Try to lower the elevator stick. You might have wrong stick mode after the update...
18 Sep 2015 14:11 #37849 by pathma82
Replied by pathma82 on topic devo f7
i ve tried it but result same.
during uploading to version 4.0.1 i formatted my transmitter but i couldnt able to load any data as the memory on my transmitter shows only 64kb
18 Sep 2015 15:10 #37850 by pathma82
i ve tried as per your below msg now found switching on normal, found mode changed from from 2 to 1.,i have to check for other functions
thanks for your help
27 Feb 2016 04:30 #43752 by darthnugget
Replied by darthnugget on topic devo f7
I got 4.0.1 on my f12e and you might use a similar method for the f7.
www.deviationtx.com/forum/how-to/5471-ho...with-deviation#43744
27 Feb 2016 23:27 #43799 by mwm
Replied by mwm on topic devo f7
darthnugget wrote: I got 4.0.1 on my f12e and you might use a similar method for the f7.
Since 4.0.1 doesn't have support for the F12E in it, that's either pretty amazing or a mistake on your part. The nightly builds have support for the F12E, but they are 4.0.1-XXXXXXX (bunch of hex digits), so it's an easy mistake to make. However, the difference is important - different config files, different module connections, some major bug fixes and features.
Thanks for the write up. I'll try and incorporate it into the manual over the weekend.
Time to create page: 0.096 seconds
