Stock firmeware
13 Apr 2016 11:53 #46413 by bmw2444
Stock firmeware was created by bmw2444
Just curious when replacing the original firmware for devo 10 I noticed that there are two dfu files A and B. Is there a difference between the two and are you supposed to reload them both in order? A then B? Just wanted to make sure I did everything correctly. I'm feeling that my problems are with the loading of the firmware correctly, possibly? Also what role do the boot loaders play? Thanks anyone.
13 Apr 2016 12:31 #46415 by mwm
Replied by mwm on topic Stock firmeware
IIUC, they support two different power output levels to meet legal requirements in different jurisdictions. You only load one.
13 Apr 2016 15:49 #46430 by PhracturedBlue
Replied by PhracturedBlue on topic Stock firmeware
specifically A is 100mW and B is 10mW. your transmitter is likely marked in the battery box with whether it needs an A or B. A 'B' transmitter will not accept an 'A' firmware, I don't know about the other way around.
14 Apr 2016 00:40 #46456 by bmw2444
Replied by bmw2444 on topic Stock firmeware
Thanks again.
14 Apr 2016 00:41 #46457 by bmw2444
Thank you.
Time to create page: 0.181 seconds
