Recent Flash Recovery to OEM Firmware on Devo 12S
07 Nov 2016 05:37 #55765 by babyhugh
I recently Flashed My Devo 12s to Deviation Firmware. I opted to go back to OEM Firmware and now I can only use One theme that works. The other 2 themes are scramble and unusable. Anyone else have this issue and is there a way to fix it. Transmitter work fine I just sucks it suck on the worst theme. I hate it.
Any help would be greatly appreciated.
GR
07 Nov 2016 05:40 #55766 by vlad_vy
You need flash back original library file, at DFuse 'Library' tab.
07 Nov 2016 15:46 #55775 by babyhugh
vlad_vy wrote: You need flash back original library file, at DFuse 'Library' tab.
I have used the available libraries I could go find for the devil 12s. I still have the same results. Any ideas where the find a clean OEM library?
08 Nov 2016 02:00 #55791 by babyhugh
Thank You so much. My problem was I was trying to flash the firmware and the library at the same time. Flash the library file separately worked perfect. Woooooo Whooooo!!!!! Happy Camper here.
Thanks Again
Time to create page: 0.073 seconds
