Jumper t8sg blank screen
12 Jan 2018 10:15 #66876
Replied by vlad_vy on topic Jumper t8sg blank screen
The LCD problem fixed, can you try latest Nightly Build?
- berserker_aerial
12 Jan 2018 11:26 #66877
by berserker_aerial
Replied by berserker_aerial on topic Jumper t8sg blank screen
Will try today
And post findings
And post findings
- berserker_aerial
13 Jan 2018 03:17 #66883
by berserker_aerial
Sorry for late
Everything is working with the 1/12/18 build
Thanks again
Thanks again
15 Jan 2018 04:35 #66886
It look like all fine now with LCD, no complaints from all users.
- albatross
22 Mar 2019 17:07 #73512
by albatross
Replied by albatross on topic Jumper t8sg blank screen
Need help here, I have upgrade my t8sg from quite old firmware t8sg-v5.0.0-e50fce3 to last nite build t8sg-v5.0.0-d21bf92, and blank screen occur, I can do nothing now, even old firmware e50fce3 was removed on download list, plase help. thanks.
- dheku
23 Mar 2019 11:08 #73516
by dheku
Replied by dheku on topic Jumper t8sg blank screen
I encountered the same situation.
Work as USBmode(USBdisk),so connect to PC.
Format that USBdisk by slow format and copy file system to disk from back up or firmware archive.
Turn on that again.
Have a good time!
Turn on that again.
Have a good time!
- albatross
24 Mar 2019 03:55 #73529
by albatross
Finally, I've found a old version firmware (deviation-t8sg-v5.0.0-8ab3744) to solve this blank screen, now my T8SG back to normal, however, still has problem to receive the RSSI info. from Frsky or FrskyX protocol, anyone can give me a suggestion? or its old firmware bugs?
- MerMer21
12 Apr 2019 22:12 #73866
by MerMer21
Replied by MerMer21 on topic Jumper t8sg blank screen
Which file did you use to get your screen contrast working? I am now having this problem after flashing the control. I just got it and i manage to connect the control to a SIM and used it a bit but then the Pitch started to stay in -100 position although the stick was back to center i thought maybe the firmware needed updating now i have the controls not working and the screen with very low contrast.
Time to create page: 0.046 seconds
Stock Firmware Help
- Jumper t8sg blank screen
