Jumper t8sg blank screen
10 Jan 2018 17:52 - 11 Jan 2018 14:16 #66814
Replied by vlad_vy on topic Jumper t8sg blank screen
Can you try the build with 6 times bigger contrast range? And report result.
File deleted...
File deleted...
Last edit: 11 Jan 2018 14:16 by vlad_vy.
- Moeder
10 Jan 2018 18:29 #66815
by Moeder
Replied by Moeder on topic Jumper t8sg blank screen
I reread the thread and wonder why this appeared only after flashing the firmware. Vlad, how does the screen on your jumper behave in firmware update mode? Same "almost black" screen? This would probably rule out hardware issues from the firmware update. On the other hand I think jumper would have informed us if they had display issues requiring to deliver their TX with a modified lcd.c
10 Jan 2018 18:55 #66816
Replied by FDR on topic Jumper t8sg blank screen
I'm not that certain about that...
- berserker_aerial
10 Jan 2018 19:02 #66817
by berserker_aerial
Replied by berserker_aerial on topic Jumper t8sg blank screen
Will do that when I get home from work thank you to those helping
10 Jan 2018 19:07 - 11 Jan 2018 14:17 #66818
One more build with corrected LCD_init(). Will be nice if it will fix the problem.
File deleted...
File deleted...
Last edit: 11 Jan 2018 14:17 by vlad_vy.
- Burns2000
10 Jan 2018 21:07 #66821
by Burns2000
Replied by Burns2000 on topic Jumper t8sg blank screen
Thank you, the build with 6 times more contrast works Perfect!
But my Problem with binding the Flysky Receiver with AFHDS-2A is still there. Can anybody Help with the right Settings?
Thank you!
Thank you!
10 Jan 2018 21:25 #66822
Is it really a new LCD module then?
If we can't detect it, one solution might be to put the contrast range into the hardware.ini file...
- berserker_aerial
10 Jan 2018 22:56 - 10 Jan 2018 22:57 #66826
by berserker_aerial
Ok I can not thank you all enough
The transmitter is functioning now Will setup and get back with the group
Thanks AGAIN
Thanks AGAIN
Last edit: 10 Jan 2018 22:57 by berserker_aerial. Reason: Spelling
- berserker_aerial
10 Jan 2018 23:17 #66828
by berserker_aerial
The file you sent me ..
Is that the new nightly build or should I leave it alone
11 Jan 2018 03:38 - 11 Jan 2018 03:43 #66833
Can you try second build with corrected LCD_init()? Will be better for all users if it will work for you.
Both builds based on Nightly Builds.
Burns2000, try to use AFHDS-2A protocol option "Freq Tune" with step 10-20, after successful bind change it to both sides up to lost bind and calculate sweet middle.
Last edit: 11 Jan 2018 03:43 by vlad_vy.
- berserker_aerial
11 Jan 2018 04:23 - 11 Jan 2018 04:23 #66835
by berserker_aerial
OK did both builds you listed
1 first build got it back on (lcd showed what I needed )
2 the second build was even better detail on screen ( Icons looked sharper and crisp )
Last edit: 11 Jan 2018 04:23 by berserker_aerial.
11 Jan 2018 04:40 #66836
Nice!!! So we can fix problem for all users.
I don't know why, but most T8SG LCD controllers has different, not default, value for "Internal Resistor Rate (Rb/Ra)" register, default value is 0x24, but my T8SG work as it should be only with value 0x26. So it has default value 0x26.
It looks like your T8SG LCD controller has default value 0x24.
11 Jan 2018 06:16 #66841
berserker_aerial,
I see your battery voltage is very low, with any voltage lower than 7.4V you can get in troubles. What battery do you use?
- dc59
11 Jan 2018 09:27 #66844
by dc59
Hi Burns2000,
Would you please check your T8SG battery door , is there a "+90" sticker on it?
It looks like this picture:
Thank you!
Hi vlad_vy, I sent you a PM.
Replied by dc59 on topic Jumper t8sg blank screen
Burns2000 wrote: Thank you, the build with 6 times more contrast works Perfect!
Thank you!
Hi Burns2000,
Thank you!
11 Jan 2018 09:35 - 11 Jan 2018 09:41 #66845
Can you share that in our Jumper forum?
Last edit: 11 Jan 2018 09:41 by FDR.
- dc59
11 Jan 2018 09:44 #66847
by dc59
Done!
FDR wrote: Can you share that in our Jumper forum?
Done!
- Burns2000
11 Jan 2018 10:31 #66854
by Burns2000
Yes on Battery door is a +90 sticker
But I can`t bind my transmitter to any Flysky Receiver. With my Flysky Radio all Receivers works perfect.
I think I got a "Monday" Model.
11 Jan 2018 12:49 - 11 Jan 2018 12:50 #66858
"Freq Tune" doesn't help?
Last edit: 11 Jan 2018 12:50 by vlad_vy.
- Burns2000
11 Jan 2018 17:42 #66866
by Burns2000
I tried to bind DSMX with a Blade Nano CP X that works without Freq Tune. Normal is 0 at Freq Tune. But with my Flysky no chance.
- Moeder
11 Jan 2018 18:09 #66867
by Moeder
Dsmx uses a different module and doesn't need fine tune, there isn't even a protocol option for it. Select afhds-2a, press ENT and try binding with different values in the freq tune setting (starting maybe with values +-20)
Time to create page: 1.002 seconds
Stock Firmware Help
- Jumper t8sg blank screen
