Firmware Update Jumper T8SG Plus
22 May 2018 15:22 #69368 by jpnews
Firmware Update Jumper T8SG Plus was created by jpnews
Hello ,
I received my Jumper T8SG Plus radio with the following firmware version: t8sg_v2_plus-v5.x.x-2018-04-19.
I would like to know where is the latest firmware version for this radio. How to perform this firmware update.
23 May 2018 00:06 - 23 May 2018 04:01 #69370 by theandrewmillett
Replied by theandrewmillett on topic Firmware Update Jumper T8SG Plus
Use DeviationUploader-0.9.0 to update the firmware: link
Here's the latest firmware: Jumper T8SG V2 builds
Last edit: 23 May 2018 04:01 by FDR. Reason: correcting the link
23 May 2018 14:54 #69381 by Ask1me
Replied by Ask1me on topic Firmware Update Jumper T8SG Plus
For upgrade latest firmware t8sg v2+, Im using windows 10, what program should I install? is it deviation uploader 0.9 or Dfuse USB upgrade tools 2.31.exe?
01 Jun 2018 00:42 #69492 by danncaidwayne
Replied by danncaidwayne on topic Firmware Update Jumper T8SG Plus
im having a problwmm too,my t8sg+ doesn’t work i haven’t use it even once,im trying to upgrade it but my windows ten cannot read the device so i unplugged the usb,then my transmitter didn’t work it has an empty screeen until now i don’t know what to do
01 Jun 2018 03:39 #69493 by vlad_vy
Replied by vlad_vy on topic Firmware Update Jumper T8SG Plus
Almost impossible to kill transmitter by firmware upgrade. Probably you flash wrong firmware. Try to start firmware upgrade mode and flash proper firmware for "t8sg_v2_plus".
18 Jun 2018 18:04 - 10 Sep 2018 18:14 #69670 by popad
Replied by popad on topic Firmware Update Jumper T8SG Plus
Hi, on Ubuntu 16.04 how can upgrade firmware for T8SG V2.0 Plus ? Can you help me with some direction, please.
I connect via USB cable. I open T8SG V2 Plus with Ent on power up. I see USB symbol on station's screen, but Ubuntu do not see.
lsusb do not see.
If I open with ESC on power up, on screen nothing. DeviationUpload-0.9.0.jar work, but not see T8SG.
What to do ? Thank you for your help. I need it. I want to can access via USB, and write the last firmware.
With stock firmware is not possible to connect to PC (Ubuntu) ?
Last edit: 10 Sep 2018 18:14 by popad.
10 Sep 2018 18:21 #70775 by popad
Hi, on Ubuntu 16.04 or other Linux, how can upgrade firmware for T8SG V2.0 Plus ? Can you help me with some direction, please.
27 Sep 2018 07:53 - 27 Sep 2018 07:54 #71057 by popad
I have tried on Windows XP and 7, all drivers. Just "defective USB device" I receive. What can I check on motherboard to see if USB connection can be made with success ?
Any advice ? Must change the motherboard for that ? All functions are right, only USB connection to any PC is not possible.
Last edit: 27 Sep 2018 07:54 by popad.
27 Sep 2018 15:25 #71068 by pulpfiction15
Replied by pulpfiction15 on topic Firmware Update Jumper T8SG Plus
Popad,
in linux terminal try : lsusb
first without connection your transmitter, after that connect the transmitter and see if your usb is detected.
28 Sep 2018 12:37 - 28 Sep 2018 12:52 #71079 by popad
Thank you.
I have tried lsusb, but I don't see my T8SG V2 Plus.
I will try on Ubuntu 18.04.1, again, but from what I already saw, it's something flawed with USB part on my station.
I don't know how and what I can check about that. In rest station works fine, no problem. All this summer I flew my micro dlg gliders with it.
It's frustrating that I can not connect it to my PC :(
Last edit: 28 Sep 2018 12:52 by popad.
25 Jan 2019 19:05 #72528 by popad
No progress for me. dfu-tool list, report nothing. lsusb don't see T8SG V2+. I try on windows XP (old laptop), no success.
What to check ? Station work well, only USB connection seem to be a problem :(
23 Feb 2019 08:58 #72980 by Alghisi
Replied by Alghisi on topic Firmware Update Jumper T8SG Plus
Hi, I wanted to update FW to solve blank screen problem.
At the beginning I was not able to go through FW update on Windows 10, I just changed PC, all good on 7.
But I'm still stuck on screen problem, FW update did not solve the problem, do you have any idea?
screen is not totally dead because it can display USB logo.
Need help, thank you
23 Feb 2019 09:22 #72985 by vlad_vy
Try to format USB drive and write filesystem from firmware archive.
23 Feb 2019 10:17 #72988 by Alghisi
vlad_vy wrote: Try to format USB drive and write filesystem from firmware archive.
thank you
07 Mar 2019 13:38 #73253 by Gar
Does anyone know what it is
09 Mar 2019 16:35 #73285 by Alr
Replied by Alr on topic Firmware Update Jumper T8SG Plus
I got my T8SG plus today and I try it for some drone like FQ series, JJRC, Eachine series. I can't bind JJRC series H36 and Eachine EO01. Anyone know what the protocol series for bind it.
The issue didn't see for T8SG V2 with the same protocol
17 Mar 2022 23:10 #77911 by dinho.limno
Replied by dinho.limno on topic Firmware Update Jumper T8SG Plus
I'm in the same boat. Did you have any success in solve it?
Time to create page: 0.180 seconds
