ir8x irangex
01 Jun 2018 15:26 #69506 by paul9156
ir8x irangex was created by paul9156
Got one of these at Christmas time and have finally tried to set it up with an Echine Lizard. To cut a long story short, I reflashed the firmware with deviation-t8sg-v5.0.0-f31c081, the original file in the unit was deviation-t8sg-v5.x.x-2017-09-19. however I noticed that the DFU and the deviation loaders recognised the transmitter as a Devo 7e instead of an ir8 ?
After flashing the transmitter the LCD went black I looked on your forums and some references were made to hardware changes and consequently firmware changes were made. sometime in Jan 2018. So I have two issues. I need a firmware file that will change the contrast on the transmitter to make it readable (it's black at the moment). I also need someone to confirm the firmware file I am using (ts8g...) is the correct firmware for the ir8x. Is it possible to get a copy of the t8sg-v5.x.x-2017-09-19 from an archive?
Many thanks in anticipation
02 Jun 2018 06:23 #69517 by vlad_vy
Replied by vlad_vy on topic ir8x irangex
Use Nightly builds "ir8m" firmware. All devo7e-256 clones (iRangeX IR8M, Jumper T8SG) recognised as devo7e.
For example:
www.deviationtx.com/downloads-new/catego...m-v5-0-0-f31c081-zip
03 Jun 2018 22:32 #69530 by paul9156
Replied by paul9156 on topic ir8x irangex
Cheers thankyou.
I have re-flashed with the latest ir8x build and I have finally got back to where I started.:)
17 Dec 2018 07:10 #72080 by kluts
Replied by kluts on topic ir8x irangex
hi how can i download this file, i dont have the acces to download
17 Dec 2018 07:51 #72081 by vlad_vy
Time to create page: 0.191 seconds
