Display resolution problem T8sg V2 Plus
13 Oct 2019 20:00 #75245 by Quemelias
Display resolution problem T8sg V2 Plus was created by Quemelias
Hello!! Buy a station, update the firmware and the screen will look like this. I don't know if the problem is with the screen or the firmware. Thanks for the help.
14 Oct 2019 03:45 #75246 by vlad_vy
Replied by vlad_vy on topic Display resolution problem T8sg V2 Plus
What firmware? It looks like Jumper changed LCD,since LCD has to be yellow.
14 Oct 2019 08:22 #75250 by Quemelias
Replied by Quemelias on topic Display resolution problem T8sg V2 Plus
The firmware is deviation-t8sg_v2_plus-v5.0.0-28ce50f. First use Dfuse Usb to enter the file .dfu. Then in USB mode, I introduced the files. It´s the carbon mode T8sg V2 plus. It is the first time I use this type of station and the seller does not know how to give me a solution. Thanx
14 Oct 2019 09:38 #75253 by vlad_vy
You can try different build, but I think it doesn't help:
www.deviationtx.com/forum/builds/8508-re...ild-deviation-v5-x-x
14 Oct 2019 13:54 #75255 by Quemelias
I have tried and the failure continues. Thanks for the help!!!
25 Oct 2019 00:31 #75312 by Vasilisf7
Replied by Vasilisf7 on topic Display resolution problem T8sg V2 Plus
Flash a firmware for a T8SG V2.0 not the plus version.
I had to contact jumper to figure it out.
This is what they did.
They made a jumper T8SG V2.0 plus carbon with lcd screen and a v3.0 board but it is not compatible with the plus version firmware in deviation tx.
31 Oct 2019 21:15 #75355 by Quemelias
I try it and tell you how it went. Thanx
04 Dec 2019 20:22 #75520 by Quemelias
That firmware does not work. I'm going to ask for an opinion on Jumper. I will inform
03 Apr 2020 16:56 #76133 by pepitoria
Replied by pepitoria on topic Display resolution problem T8sg V2 Plus
I am having the same issue. Did you manage to fix it?
15 May 2020 18:02 #76319 by cerox
Replied by cerox on topic Display resolution problem T8sg V2 Plus
Same for me... When I install firmware for V2 (not plus). The screen remains black. I think I have a T8SG V3 plus with oled display. Is it possible ?
15 May 2020 18:10 #76320 by Vasilisf7
Flash the firmware that dosen't say plus
15 May 2020 18:51 #76321 by cerox
I just installed deviation-t8sg_v2-v5.0.0-5efb6a2 and when I turn it on the screen remains black. Don't know what to do...
Time to create page: 0.815 seconds
